[ROM - CM10 - Jelly Bean 4.1.2] Helly Bean - based off sources of cm10, Build 11/15
  • 39 Antworten
Q
quasimodo
Gast
Ich, Android-Hilfe.de oder die Entwickler/Publisher der ROM oder Mods,
übernehmen keine Haftung für mögliche Schäden an eurem Gerät!
Ihr seid daher für euer Handeln selbst verantwortlich!!!
[ROM] Helly_Bean [4.1.2], based off sources of cm10
Port by Developer DerTeufel
hellybean.com & xda
If you like my work, please donate to me
Dieser Port wird von Mir schon für das SGS Betreut: Das Helly Bean [JB Mod] basiert auf der offiziellen CM10
Bei diesem Mod findet Hauptsächlich eine Kernel -Anpassung statt,
zusätzliches entnehmt Ihr der Change log in Post 3
Aus meiner Sicht & Anwendererfahrung
vom SGS Release:derzeit eines der am besten laufenden CM10 Release
zitat DerTeufel
Originaltext Engl.
This is my Jellybean 4.1.2 Rom. Till now it only was available for sgs1 devices, but I got asked to release it for sgs3, too...well, here it is
This Rom always is build from latest cm10 sources, with many additional changes.
Installationshinweise & Downloads
Post 2
Change Log
Post 3
many thanks to (in no particular order):
- all the people who commit to cm10 gerrit
- krarvind
- stratosk
- mialwe (i hope you'll try my rom)
- Rootax (for hosting)
please write to me, if i have forgotten you.
Reaktionen: -stephan- und mareis1973
Additional changes, compared to cm10 (this list might not be complete)
Weitere Änderungen
- facebook sync integrated
- option to enable high end gfx effects
- possibility to activate and customize navigation bar (color of background, glow effect, transparency)
- possibility to customize statusbar (color of background, transparency)
- transparent lockscreen (taken from paranoid android, coded by jesus david)
- edge swipe navigation (ported from sgt7)
- ability to enable tablet_ui (ported from aokp)
- kill-all button at recents panel (ported from aokp)
- task manger button at recents panel linked to the built-in running apps service
- customizable long-press-back-kill timeout (from 500ms to 3000ms)
- added option to toggle lockscreen styles (jb, ics, gb, eclair)
- option to use sense4 recents panel
- misc settings in settings menu
- added kill-all and taskmanager button to sense4 recents panel
- added the possibility to set lockscreen text/image colors
- added possibility to change the colors of the statusbar toggles
- added option to enable/disable coloring of toggles
- added option to display a small bar below the toggles as indicator for toggle state
- added possibility to display additional volume slider (similar to brighness slider from aokp)
- pdroid compatible (settings --> security)
pdroid app can be found at this thread:
http://forum.xda-developers.com/show....php?t=1923576
Unterschiede zu Base CM10
- option to enable high end gfx effects, on lower end devices
- possibility to disable high end gfx effects, on higher end devices
- task manger button at recents panel (this needs os monitor to be installed, otherwise nothing happens...still wip)
- pdroid patched, if app installed, reachable at: settings --> system --> security
- added the possibility to search for contacts by nick or company name (with dialpad T9, has to be activated at dialpad settings), cherry-picked from AOKP
- more to come ...
Ich bin sehr gespannt, wie die ROM auf dem S3 sein wird. Auf dem S1 gehörte sie meiner Meinung nach zum Besten.
Bin auch gespannt, vor allem auf den integrierten Kernel.
Habe allerdings noch kein Feedback, wann es los geht.
Es geht los: [ROM] Helly_Bean [4.1.2], based off sources of cm10, 11/02 - xda-developers
Additional changes, compared to cm10 (this list might not be complete):
unlike my rom for the sgs1, this one is coming with the stock cm10 kernel/recovery, as i don't own this device.
download:
Helly Bean
- krarvind
- stratosk
Der Upload müsste so gegen 2000 Uhr abgeschlossen sein. Edit: Die ROM ist immer noch nicht auf der Website verfügbar.
Downloaden kann man´s aber immer noch nicht.
Edit: Jetzt geht´s. Download läuft.
Klasse, jetzt geht es endlich los. Besten Dank an dieser Stelle an DerTeufel!
Eingangspost Aktualisiert
Download Link - Siehe Post 2!
Reaktionen: mareis1973
Bisher sehr zufrieden. Habe sie als 2te mit Dual laufen, klein aber gut.
Auf jeden Fall zu empfehlen.
Matze
Welches Modem nutzt ihr denn?
DLID bei mir
hi,
ich habe hier eine neue test rom für euch:
Dev-Host - helly_bean_i9300_20121103.zip - The Ultimate Free File Hosting / File Sharing Service
sie ist fast identisch mit der bisherigen, aber ich habe den "neuen" blackberry10 lockscreen hinzugefügt. da ich selbst kein s3 habe, dieses aber ein wesentlich größeres display/andere auflösung als das s1 hat, muss ich wissen, ob es funktioniert.
bitte macht vor dem testen des lockscreens ein nandroid, und stellt zumindest "unlock mit menu taste" ein, falls sich der lockscreen nicht entsperren lässt.
ihr findet den lockscreen unter:
bildschirmsprre --> Style -->Blackberry10
danke
Hmm scheint nicht zu funktionieren . Muss mit home entsperren .
Reaktionen: DerTeufel
funktionieren die übrigen lockscreens normal?
passiert bei dem blackberry irgendwas? oder hast du einfach nur ein dunkles bild?
Ja die anderen funktionieren einwandfrei .
Nee nicht schwarz ganz normal sehe ich den lockscreen kann halt nicht entsperren oder sehe was zum entsperren :D
benutzt du ein eigenes hintergrundbild? oder hast du eine farbe für den hintergrund des lockscreen eingestellt?
wenn eines davon zutrifft, stell bitte auf "standardbild" und zusätzlich noch "durchsichtiger hintergrund" anhaken.
Hab eigenes Bild ich teste mal
Ne geht gar nicht hat man dann in der Mitte ein Fenster was schwarz ist .
Hallo DerTeufel, Ich hoffe Dich auch Hier in deinem Interesse zu vertreten!
kannst Du Mir bitte alle Eckdaten, wie Installationsanleitung, Change Log, etc; in Deutsch zukommen lassen, so das ich diese in die Eingangspost kopieren kann. Besten Dank!
Habe dein erstes Rom auch schon seit gestern drauf und bin begeistert von der Performance. Bin ja von Dir nicht anderes gewohnt!
Weiter so mein Guter, :thumbup:
DerTeufel schrieb:
hi,
danke
