ehrles
Ikone
- 1.888
Das musst du nach jedem Flash wiederholen.
Sch***-AppCanök;3880412 schrieb:Ein Tipp vll noch wegen dem Memory Fix:
Hohlt euch die App Autokiller Memory Optimizer und stellt dort "Optimum" ein, funktioniert jetzt seit paar Stunden perfekt![]()
Gruß Alex
if busybox [ $FREE_MEM_AT_BOOT -eq 1 ]; then
busybox echo $FOREGROUND_APP_MEM,$VISIBLE_APP_MEM,$PERCEPTIBLE_APP_MEM,$SECONDARY_SERVER_MEM,$HIDDEN_APP_MEM,$EMPTY_APP_MEM > /sys/module/lowmemorykiller/parameters/minfree
setprop ro.FOREGROUND_APP_MEM $FOREGROUND_APP_MEM
setprop ro.VISIBLE_APP_MEM $VISIBLE_APP_MEM
setprop ro.PERCEPTIBLE_APP_MEM $PERCEPTIBLE_APP_MEM
setprop ro.HEAVY_WEIGHT_APP_MEM $HEAVY_WEIGHT_APP_MEM
setprop ro.SECONDARY_SERVER_MEM $SECONDARY_SERVER_MEM
setprop ro.BACKUP_APP_MEM $BACKUP_APP_MEM
setprop ro.HOME_APP_MEM $HOME_APP_MEM
setprop ro.HIDDEN_APP_MEM $HIDDEN_APP_MEM
setprop ro.EMPTY_APP_MEM $EMPTY_APP_MEM
RAM_FREE=` busybox expr $EMPTY_APP_MEM \* 4 / 1024 `
log -p i -t boot "Set ${RAM_FREE}mb of RAM free."
fi
Sakaschi schrieb:was mein fix macht:
im grunde macht das nichts anderes als die nicht gebrauchten apps schneller aus dem ram zu schmeißen und die prioritäten neu zu setzten.Code:if busybox [ $FREE_MEM_AT_BOOT -eq 1 ]; then busybox echo $FOREGROUND_APP_MEM,$VISIBLE_APP_MEM,$PERCEPTIBLE_APP_MEM,$SECONDARY_SERVER_MEM,$HIDDEN_APP_MEM,$EMPTY_APP_MEM > /sys/module/lowmemorykiller/parameters/minfree setprop ro.FOREGROUND_APP_MEM $FOREGROUND_APP_MEM setprop ro.VISIBLE_APP_MEM $VISIBLE_APP_MEM setprop ro.PERCEPTIBLE_APP_MEM $PERCEPTIBLE_APP_MEM setprop ro.HEAVY_WEIGHT_APP_MEM $HEAVY_WEIGHT_APP_MEM setprop ro.SECONDARY_SERVER_MEM $SECONDARY_SERVER_MEM setprop ro.BACKUP_APP_MEM $BACKUP_APP_MEM setprop ro.HOME_APP_MEM $HOME_APP_MEM setprop ro.HIDDEN_APP_MEM $HIDDEN_APP_MEM setprop ro.EMPTY_APP_MEM $EMPTY_APP_MEM RAM_FREE=` busybox expr $EMPTY_APP_MEM \* 4 / 1024 ` log -p i -t boot "Set ${RAM_FREE}mb of RAM free." fi
ich nutze nur den ohne andere fixes und tjoa -> läuft^^
aber auch die anderen fixes könnt ihr drinne lassen stören sollten die sich gegenseitig nicht.
stephan1977 schrieb:Hast du die rechte neu gesetzt?
Gesendet von meinem A1_07 mit Tapatalk 2
