gewürzwiesel
Philosoph
- 2.055
Ein Mod in meinem Thread...Skandal
Hmm...ich hab meine seit gestern morgen laufen, 2x in die Recovery gebootet wegen Kernel flash, aber ansonsten läuft alles rund hier...
Das Speichermanagement ist ja momentan eh noch der Pferdefuss von CM10. Aber ich denke Codeworkx bekommt auch das noch in den Griff...
Der ursprüngliche Beitrag von 10:25 Uhr wurde um 10:33 Uhr ergänzt:
temasek's UNOFFICIAL BUILD - V11
BUILDING IN-PROGRESS
- Going for dinner, will upload when I'm back![]()
- hwcomposer.smdk4x12.so is the same as Official Preview #14 dated 1 Aug (md5sum checked)
Quote:
cm-10-20120802-UNOFFICIAL-i9300-V11.zip
MD5SUM: TBA
CHANGELOG
MERGED COMMITS UP TO
Change I9224f796: Linux 3.0.39
http://review.cyanogenmod.com/#q,sta...:jellybean,n,z
NOTABLE MERGED COMMITS
- Change I6e680315: audio: enable +30db boost for headset mic
- Change I72f38c6a: s3cfb: gamma corrections from hardcore/speedmod
CHERRY-PICKS
# [General]
# NEW - Change I9364e948: Use SSL_OP_NO_TLSv1_1 SSL_OP_NO_TLSv1_2 SSL_OP_NO_TICKET for better wpa_supplicant_8 interoperability
# NEW - Change I14c83f51: Use SSL_OP_NO_TLSv1_1 SSL_OP_NO_TLSv1_2 SSL_OP_NO_TICKET for better wpa_supplicant_6 interoperability
# Change I9b2eae1a: charger: suspend when not animating
# Change Iff1fccc6: apns: Clean up Bulgarian APNs
# Change I2cfce9d9: LatinIME: Add Bulgarian predictive dictionary
# Change I74b3df38: camera: allow focusing on zsl mode (i9300)
# [Framework]
# NEW - Change I6e97f5fb: OMXCodec: prevent codec/quirks mismatch
# NEW - Change I2f4592f9: Fix the Icons in the Expanded Volume Overlay
# NEW - Change Ida88dabc: Notification Widgets : Fix vibration
# NEW - Change I00ebccf9: Make notification header settings icon align with the text
# NEW - Change I4cc1a14b: SystemUI: Fix data activity overlay not being removed when data is disabled
# MERGED - Change I112c35cf: Fix all upscaled lockscreen drawables and add a few
# Change I94beeed5: systemui: fix samsung's 3g with config_showmore3g.
# Change Iae3890e7: Framework: Add ability to disable Power menu screenshot (Part 1/2)
# Change Iaa2de02c: Kill app back-button : Don't kill default launcher
# MERGED - Change Icb5b3300: Fix display of mobile status bar icon when using airplane mode
# Change Id0bff630: Remove power widget background
# Change Ibc11b9af: Allow mounting of multiple volumes via mass storage (framework part)
# Change If790aae7: Hardware key custom rebinding (1/2) WIP
# Change I7bd7c64d: Status Bar Brightness Control: Set brightness by long press the status bar
# Change I80cfef86: Add Center Clock-Framework Part
# Change I1fdbaad9: Improve scrolling cache
# [Settings]
# NEW - Change I45c919ad: PowerWidget : TouchInterceptor updates
# MERGED - Change I683d9c22: Add the new lockscreen drawables to the picker list
# Change I44f948bb: Settings: Add ability to disable Power menu screenshot (Part 2/2)
# Change If3aab16b: Settings: Removed system update option
# Change I2f53dc11: Hardware key custom rebinding (2/2) WIP
# Change Id5b9a811: Add Center Clock-Settings Part
# [Apps]
# Change I6b9f0e85: Additional notification action to call sender
# Change I01154b5b: Fixing Stk app crash, System service created too early.
# Change Ifa5a5152: add increasing volume option for alarm clocks
# Change Icdf39ea8: Browser: Increased tab limit
# Change Ia1eee36d: zsl: allow initial autofocus, t2f and refocus on longpress shutter
# Change I4c4b611c: Browser: New navbar buttons
# Change I5af00f1c: Added a menu item in Browser called Close other tabs
# Change Iba8e7446: Browser : Open in incognito tab
# [LOCAL FILES REPLACED]
# Fix Video in Landscape by Codeworkx (hwcomposer.smdk4x12.so)
# - http://forum.xda-developers.com/show...postcount=1986
