minimalbensn
The fuckin fastest Weasel in the S3 Galaxy
U R OwneD by my S3 Dro¡D
amo66 schrieb:Die paranoia! Ich bin auch von der temaseks Cm10 gewechsetlt und will nicht mehr zurück!
via paranoid S3
gewürzwiesel;4421709 schrieb:Gründe - ich hab sie empfohlen![]()
I am Weasl
and you've been SPANK'd by an S3
Gorg schrieb:V90 ist rausWer möchte sie testen?
temasek's UNOFFICIAL BUILD - V91
Several new cherry-pickings
New "Clear All" feature to clear all recent apps (top right corner)
I tried to remove CMUpdater strings but seems I missed one string so in the "About Phone" u see see one liner "@2131429622". I'll try to fix it in next release if not I'll revert back to original.
Quote:
cm-10-20121108-UNOFFICIAL-i9300-V91.zip
MD5SUM: 89bb9069a480f08bdfaef5b4a76105c6
CHANGELOG
MERGED COMMITS UP TO
Change Ia3508f50: Fix switching running/cached apps with memory bar
Gerrit Code Review
CHERRY-PICKS
# [General]
# NEW - Change Ic042a435: Fix encoding of Ç character.
# Change I0423fd58: bionic: Add ARMv7 optimized string handling routines
# Change I624b5f6d: Add group mms threading (3/3)
# [CM KERNEL]
# Change I02e2b76a: Enable DOCK support in MAX77693
# [Framework]
# NEW - Change Ice0249a4: add option to select storage location in camera
# NEW - Change Iceb86eef: "Clear all" button on recent apps
# Change I1a68f822: DevicePolicy: Fix lockNow() failing to turn off screen
# Change I67277749: Allow the statusbar to show both network technology and signal strength text
# Change Ia6cd4a39: Add group mms threading (2/3)
# Change I87f12bb1: optional encryption password sync
# Change I4a4ec23c: frameworks/base: Implementation of AtCmdFwdService
# Change I23a508fa: Navigation Bar: Ability to enable on every device 1/2
# [Settings]
# Change Id5b9a811: Add Center Clock-Settings Part
# Change Id6628200: Allow the statusbar to show both network technology and signal strength text
# Change I71a31e7a: optional encryption password sync
# Change I5716f8c4: Navigation Bar: Ability to enable on every device 2/2
# [Apps]
# NEW - Change Ic9c8b121: Send out a broadcast intent when BT voice dialing is shut down.
# NEW - Change I6d3145d8: Added support for Filter parameter for PBAP function PullPhoneBook
# NEW - Change Id2f1e33b: Fix possible null-pointer exception (Port from CM7)
# Change Ib786586a: add option to select storage location in camera
# Change I824c7b48: GsmDataConnectionTracker: Allow automatic data connection to APN_TYPE_MMS
# Change I8a24a7bc: Browser: Add a menu item to close the browser
# Change I1de4d2b0: Add option to hide AlarmClock Icon in StatusBar
# Change I339c1956: Add group mms threading (1/3)
# Change Id143325b: Zero Shutter Lag Mode on Front Camera
# [EXTERNAL SOURCES]
# Overlay for i9300 - Show Expanded Desktop preference
# - https://github.com/temasek/android_d...3c666edb5f4bd8
# Change-Id: I63f133d8: Makes the add button for new APNs appear in the action bar.
# - https://github.com/temasek/android_p...c69ca6e64603da
# Change-Id: I80cfef86: Add Center Clock-Framework Part by erezak
# - https://github.com/temasek/android_f...395b26b330bb58
# Nav Bar Height (frameworks) by Francesco Foresta
# - https://github.com/temasek/android_f...cf9cc4b113a33b
# Nav Bar Height (settings) by Francesco Foresta
# - ttps://github.com/temasek/android_packages_apps_Settings/commit/b148d56c60707879b8cec180f429e0d368fddc0d
DOWNLOAD SITES:
Temasek
Dev-Host - The Ultimate Free File Hosting / File Sharing Service
http://www.mediafire.com/temasek
