temasek's UNOFFICIAL BUILD - V86
Quote:
cm-10-20121030-UNOFFICIAL-i9300-V86.zip
MD5SUM: 5b3363cdb3543e736d49b3cab59c5a64
CHANGELOG
MERGED COMMITS UP TO
Change I8040f71b: msm8960-common: re-enable secure flag usage
http://review.cyanogenmod.com/#q,sta...:jellybean,n,z
CHERRY-PICKS
# [General]
# NEW - Change I4132ca09: i9300: allow mass storage mode for external sdcard
# Change Id24995ed: Handle locations with more than 30 chars for lat/lon.
# Change I5b93a2e6: Fixes exif corruption issues in jhead.
# REVERTED - Change I82c8ba66: Proper handling of setting sys.usb.config to mass_storage
# Change I0423fd58: bionic: Add ARMv7 optimized string handling routines
# Change I624b5f6d: Add group mms threading (3/3)
# Change Idd8cd277: Update tcp buffersize with CAF values
# Change I2cfce9d9: LatinIME: Add Bulgarian predictive dictionary
# [CM KERNEL]
# Change I02e2b76a: Enable DOCK support in MAX77693
# [Framework]
# Change I4c4aad62: LockScreen: option to enable torch with home button long-press (1/2)
# Change I1a68f822: DevicePolicy: Fix lockNow() failing to turn off screen
# Change I67277749: Allow the statusbar to show both network technology and signal strength text
# MERGED - Change I45b37e24: Expanded desktop capability (2/2)
# Change I5e921d23: core and telephony: Additional HSPAP support
# Change Ia6cd4a39: Add group mms threading (2/3)
# Change I87f12bb1: optional encryption password sync
# Change I4a4ec23c: frameworks/base: Implementation of AtCmdFwdService
# Change I23a508fa: Navigation Bar: Ability to enable on every device 1/2
# [Settings]
# NEW - Change I917f1ff4: Add Recife timezone (1/2)
# Change Iafeede49: LockScreen: option to enable torch with home button long-press (2/2)
# Change Id5b9a811: Add Center Clock-Settings Part
# Change Id6628200: Allow the statusbar to show both network technology and signal strength text
# MERGED - Change Ie35719f7: Allow to hide Expanded Desktop (1/2)
# Change I71a31e7a: optional encryption password sync
# Change If44de6dd: Wi-Fi: Region Code: Added Brazil (code BR: 25)
# Change I5716f8c4: Navigation Bar: Ability to enable on every device 2/2
# [Apps]
# NEW - Change Ie4bef0b5: Add Recife timezone (2/2)
# Change I4aa0b4ba: Fix for NPE in showAllAppsCling
# UPDATED - Change I2a95e142: Cleanup and improve T9 search code.
# UPDATED - Change Ia2a92c59: Also search nickname and organization in T9 search.
# Change Ied9440ec: Make keyboard hints a better visible
# Change I8a24a7bc: Browser: Add a menu item to close the browser
# Change I84aada70: restore soundrecorder interface
# Change I21f6a461: Trebuchet : Add a pref to set hotseat icon's number
# Change I1de4d2b0: Add option to hide AlarmClock Icon in StatusBar
# Change I339c1956: Add group mms threading (1/3)
# Change Id143325b: Zero Shutter Lag Mode on Front Camera
# [EXTERNAL SOURCES]
# Overlay for i9300 - Show Expanded Desktop preference
# - https://github.com/temasek/android_d...3c666edb5f4bd8
# Change-Id: I63f133d8: Makes the add button for new APNs appear in the action bar.
# - https://github.com/temasek/android_p...c69ca6e64603da
# Change-Id: I80cfef86: Add Center Clock-Framework Part by erezak
# - https://github.com/temasek/android_f...395b26b330bb58
# Nav Bar Height (frameworks) by Francesco Foresta
# - https://github.com/temasek/android_f...cf9cc4b113a33b
# Nav Bar Height (settings) by Francesco Foresta
# - ttps://github.com/temasek/android_packages_apps_Settings/commit/b148d56c60707879b8cec180f429e0d368fddc0d
DOWNLOAD SITES:
http://temasek.hopto.org
http://d-h.st/users/temasek
gewürzwiesel;4361713 schrieb:Das gleiche wie immer: alles individuell
I am Weasel
and you've been SPANK'd by an S3
temasek's UNOFFICIAL BUILD - V89
[*]Picked ability to save to sdcard (camera). Camera may require a reset to default in the camera settings.[*]Picked ability to bean files in CM File Manager
Quote:
cm-10-20121104-UNOFFICIAL-i9300-V89.zip
MD5SUM: 7a12e992a4a99a2231cf6c79a4c1cad8
CHANGELOG
Change I1bc48b69: Revert "Czech: fixed transaltion, unified strings, added missing strings"
Gerrit Code Review
CHERRY-PICKS
# [General]
# Change I3976ee4a: UMS support with any volume, not only primary (1/3)
# Change I4132ca09: i9300: allow mass storage mode for external sdcard
# [CM KERNEL]
# [Framework]
# Change I67431f29: Frameworks/av: Fix for mediaserver crash in AudioFlinger
# Change I00a8338a: UMS support with any volume, not only primary (2/3)
# MERGED - Change I5e921d23: core and telephony: Additional HSPAP support
# [Settings]
# Change Ief89c994: UMS support with any volume, not only primary (3/3)
# Change I917f1ff4: Add Recife timezone (1/2)
# MERGED - Change If44de6dd: Wi-Fi: Region Code: Added Brazil (code BR: 25)
# [Apps]
# NEW - Change Ib786586a: add option to select storage location in camera
# NEW - Change I005db2eb: CMFileManager : Beam to send files
# NEW - Change Ibe52f0a0: CMFileManager : Allow rotation
# Change I824c7b48: GsmDataConnectionTracker: Allow automatic data connection to APN_TYPE_MMS
# Change Ie4bef0b5: Add Recife timezone (2/2)
# MERGED - Change I4aa0b4ba: Fix for NPE in showAllAppsCling
# MERGED - Change I2a95e142: Cleanup and improve T9 search code.
# MERGED - Change Ia2a92c59: Also search nickname and organization in T9 search.
DOWNLOAD SITES:
Temasek
Dev-Host - The Ultimate Free File Hosting / File Sharing Service
