gogixx
Stamm-User
- 375
Danke dir für den Versuch mir zu helfen.
gewürzwiesel;4246851 schrieb:Und nu:
I am Weasel
and you've been SPANK'd by a S3
temasek's UNOFFICIAL BUILD - V73
Cyanogenmod Circle Battery implementation
Some new cherry-picks
These few days merged commits read by your own if u interested
If anyone using built-in superuser and has root problems do the following
1. Download Superuser-3.2-RC3-arm-signed.zip
2. Reboot back to recovery
3. Flash the above file.
Quote:
GENTLE REMINDER
If you chooses to use my unofficial build here, pls DO NOT post your issues and/or request support from the official cm10 thread. My builds contains yet-to-approved commits and MAY affect codeworkx's debugging process. Pls understand and I hope to get your support on this.
cm-10-20121013-UNOFFICIAL-i9300-V73.zip
MD5SUM: e02346fbdc3557ed538d3cc9d19fac84
CHANGELOG
MERGED COMMITS UP TO
Change I45224476: German: initial translation for CM Updater
http://review.cyanogenmod.com/#q,sta...:jellybean,n,z
CHERRY-PICKS
# [General]
# NEW - Change If148410d: i9300: gps.conf: don't assume NA server (i9300)
# NEW - Change Idd8cd277: Update tcp buffersize with CAF values
# Change I2cfce9d9: LatinIME: Add Bulgarian predictive dictionary
# [Framework]
# NEW - Change I3dfe0b4e: Add CmCircleBattery to StatusBar options (1/2)
# REVERTED - Change Ia5319634: Allow brightness decrease when filtering is disabled
# Change Ibf2587da: Allow airplane and silent power toggle (2/2)
# Change I4a4ec23c: frameworks/base: Implementation of AtCmdFwdService
# Change I8716a260: camera: add define for ISO settings
# UPDATED - Change Ib37d1be2: Framework: Option to not lock automatically when a call ends (1/2)
# Change Ia06708f4: SystemUI: Clock - right/center/off (Part 1 of 2)
# Change I67277749: Allow the statusbar to show both network technology and signal strength text
# Change I23a508fa: Navigation Bar: Ability to enable on every device 1/2
# [Settings]
# NEW - Change Iaaaffeb3: Add CmCircleBattery to StatusBar options (2/2)
# NEW - Change If44de6dd: Wi-Fi: Region Code: Added Brazil (code BR: 25)
# Change I8d23ee78: Allow airplane and silent power toggle (1/2)
# Change I47611b41: Settings : Clock - right/center/off (Part 2 of 2)
# Change Id6628200: Allow the statusbar to show both network technology and signal strength text
# Change I5716f8c4: Navigation Bar: Ability to enable on every device 2/2
# [Apps]
# Change Id143325b: Zero Shutter Lag Mode on Front Camera
# UPDATED - Change Ic0894bc5: PhoneApp: Option to not lock automatically when a call ends (2/2)
# [EXTERNAL SOURCES]
# realtime change size of OnScreenButtons (frameworks) by Francesco Foresta
# - https://github.com/Quarx2k/android_f...61259acfc132b2
# realtime change size of OnScreenButtons (settings) by Francesco Foresta
# - https://github.com/Quarx2k/android_p...5cc76c288e316d
DOWNLOAD SITES:
http://temasek.hopto.org
http://d-h.st/users/temasek
http://www.mediafire.com/temasek
