gewürzwiesel;4224157 schrieb:Danke für den Hinweis und Threadtitel aktualisiert
temasek's UNOFFICIAL BUILD - V72
BUILDING IN-PROGRESS
Android 4.1.2
V71 2 x cherry=picks of smdk4412 kernel commits merged
Lots of translations merged
Some new commits merged (not in my pickings) which are nice - Read by your own
No new cherry-picks
Will be back to upload - Going for a coffee & some cigarettes
Quote:
GENTLE REMINDER
If you chooses to use my unofficial build here, pls DO NOT post your issues and/or request support from the official cm10 thread. My builds contains yet-to-approved commits and MAY affect codeworkx's debugging process. Pls understand and I hope to get your support on this.
cm-10-20121010-UNOFFICIAL-i9300-V72.zip
MD5SUM: TBA
CHANGELOG
MERGED COMMITS UP TO
Change I9739f9ae: core/Makefile: avoid exceeding MAX_ARG_STRLEN
http://review.cyanogenmod.com/#q,sta...:jellybean,n,z
CHERRY-PICKS
# [General]
# Change I2cfce9d9: LatinIME: Add Bulgarian predictive dictionary
# [CM KERNEL]
# MERGED - Change I0dd5114a: bcmdhd: Reenable IPv6, disable multicast in suspend
# MERGED - Change I7cf296f8: wakelock: use single threaded workqueueus
# [Framework]
# Change Ia5319634: Allow brightness decrease when filtering is disabled
# MERGED - Change I1bf9fbd8: Services: Fix for dock audio routing
# Change Ibf2587da: Allow airplane and silent power toggle (2/2)
# Change I4a4ec23c: frameworks/base: Implementation of AtCmdFwdService
# MERGED - Change I43edf58b: * Only do a cancel discovery if the device is discovering. * explicitly close input and outputstream. This could prevent objects from being cleaned up before the next connect attempt.
# MERGED - Change Ib1ab82ba: Add simple caching to XML compilation
# Change I8716a260: camera: add define for ISO settings
# Change Ib37d1be2: Framework: Option to not lock automatically when a call ends (1/2)
# Change Ia06708f4: SystemUI: Clock - right/center/off (Part 1 of 2)
# Change I67277749: Allow the statusbar to show both network technology and signal strength text
# Change I23a508fa: Navigation Bar: Ability to enable on every device 1/2
# [Settings]
# Change I8d23ee78: Allow airplane and silent power toggle (1/2)
# MERGED - Change Ifbc5d738: NotificationLightSettings: Use config.xml provided default LED colors and on/off times.
# Change I47611b41: Settings : Clock - right/center/off (Part 2 of 2)
# Change Id6628200: Allow the statusbar to show both network technology and signal strength text
# Change I5716f8c4: Navigation Bar: Ability to enable on every device 2/2
# [Apps]
# MERGED - Change I4ec79d12: Allow full themeing of mms via theme chooser
# Change Id143325b: Zero Shutter Lag Mode on Front Camera
# Change Ic0894bc5: PhoneApp: Option to not lock automatically when a call ends (2/2)
# [EXTERNAL SOURCES]
# realtime change size of OnScreenButtons (frameworks) by Francesco Foresta
# - https://github.com/Quarx2k/android_f...61259acfc132b2
# realtime change size of OnScreenButtons (settings) by Francesco Foresta
# - https://github.com/Quarx2k/android_p...5cc76c288e316d
DOWNLOAD SITES:
http://temasek.hopto.org
http://d-h.st/users/temasek
http://www.mediafire.com/temasek
MagicSven schrieb:Hallo Leute,
hab jetzt über eine Stunde damit verbracht mir den Thread hier durchzulesen aber teilweise blick ich noch nicht ganz durch.
Ich hab gestern ein S3 bekommen und wollte das jetzt erstmal neu aufsetzen.
Hab mir dann CM10 v70 installiert aber das WLan ging nicht mehr.
Wenn ich jetzt heute Abend die CM10 V72 inkl. Siyah 1.6.7 installier müsste es gehen?
Hab mittlerweile wieder das "alte" Android IceCreamSandwich installiert und musste natürlich alle Apps wieder installieren und einrichten...
Kann mir einer vielleicht kurz beschreiben wie ich das Gerät komplett und sauber platt machen kann und in welcher Reihenfolge ich was installieren muss??
Gerootet ist es momentan und ein Backup wurde mit diesem nanoidbackup? erstellt. Also Lautstärke hoch, Home, Powerbutton.
Wäre echt super wenn mir einer kurz erklärt was ich in welcher Reihenfolge machen muss.
Vielen Dank
PS: super Forum hier und tolle - vor allem aktuelle - Beiträge !!!
tomml schrieb:Die ideale Reihenfolge wäre... Full Wipe -> ROM flashen -> Kernel flashen -> Reboot
Looks like Samsung finnally listened to the developers of CUSTOM roms for Android devices.
Samsung is going to discuss the issues around the missing source files for the EXYNOS processor.
Samsung started to use their own processor since the Galaxy S. Because the Exynoss processor is quit special to Samsung. Samsung decided to leak not that much about their own EXYNOS processor.
Since Samsung sold many Android devices, developers making CUSTOM roms for Android start to blame Samsung about the missing source files from the EXYNOS processor.
Specially the makers of CyanogenMOD aren’t happy with Samsung at the moment.
One of the biggest developers for CyanogenMOD (codeworkx) started to switch over to Sony.
Lets hope for the Android CUSTOM rom community that Samsung will post the whole source information.
We of SamMobile think samsung will do good to release these documents, because the Samsung community is the biggest of all android phones. And it is good to have a great community behind your products.
Let’s hope this time Samsung will actually release them, or they will loose a whole bunch of credabilty and users!!
