ehrles
Ikone
- 1.888
Nein, gemeint ist der Standard-Kernel der temasek Rom. Also Rom+Gapps flashen und los geht's .
ehrles schrieb:Xxdlh1
ehrles schrieb:Erstmal für Ulm , ich nutze die XXDLH1 in der Region Trier Rlp.
Some users with official builds also facing similar wifi issues.
Atm there isn't any solution I'm afraid.
I am one of many that is not affected by the wifi issue. If there is a solution I'll let u guys know. In the mean time use older builds first or try siyah kernel.
amo66 schrieb:
