[ROM][Aroma-Kitchen][XXDLJ1][20-10-12]---Dragon's Jelly Bean Rom V4.0---(Online!!)
  • 1.191 Antworten
Masta_Gee81
Masta_Gee81
Enthusiast
5.405
Based on XXDLJ1
Samsung stock Jelly Bean rom modded for the best Stability and Speed..
Deodexed
Zipaligned
Ext4 Tweaks (Aroma)
SQLlite 3 Teaks (Aroma)
Battery Tweaks
AOSP Jelly Bean keyboard
Swype
AC!D Audio Technology (Dr.Dre, Beats Audio, Sony Walkman and more..)
Disabled scrolling cache
Hacked Stock Email App
Removed bloatware Apps (Can be Installed With Aroma)
Busybox
RAM Optimizations
GPU Acceleration
Zipaligns Apk's At Boot
Cell Standby Fix (Build-in)
Wifi Fixed (Thanks to gh.rohit)
1% Batt Mod
10 Steps Auto Brightness Mod
Fixed Browser
Fixed Email
Custom Boot Animation Supported
Updated Host List
Extended Power Menu
Call Rec Enabled (Thanks To Wanam)
Hide Sms From Call Log (Thanks To Wanam)
OOM Priority Supercharger ( Thanks To Zeppelinrox )
Init.d Tweaks
Build.prop Tweaks
OTA Updater
Enable/Disable Fast Dormancy (thanks to gokhan)
CpuSpy
FontInstaller
SuperSu 0.96
Touch Recovery 6.0.1.2 (Aroma)
PlayStore 3.8.17
CenterClock Mod (Aroma)(Thanks to raubkatze for the guide how to)
DragonJB Theme (Aroma)
Battery Mods (Aroma)
Signal Mods (Aroma)
Galaxy Sim Unlock
And More.....
Dragons Jelly Bean V3.0
Changelog:
Based on XXDLIH
Modem XXDLID
121 CSC Country Codes (Thanks to Wanam)
Removed AC!D Sound Technology 2.0 (New version soon!!)
Siyah 1.7 RC1
Updated Google Drive
Updated Twitter
Updated Google Plus
Removed Snote
Some little fixes
New Transition animations Thanks to ThepSynTyst (Check HERE for samples)
And more​
Dragons Jelly Bean V2.4
Changelog:
Siyah 1.7b6
Perseus 24.2
Franco R19
Lightmanager 3.0
Playstore 3.9.16
Dropbox 2.2
Flipboard
Aroma 2.56
Gmail 4.2 (Pinch to zoom)
Updated CSC Country Codes (Now 120) Thnx to Wanam
Updated DragonsJB Green Theme
TPRW Recovery 2.3.0.0
CRT-OFF Effect
Smart Rotation
New Tweaks For Better Performance
Transitions Effects (DragonsJB, ICS, JellyBean)
Added AllShareControl App To Bloatware Allshare Option
Google Now & Voice Search Fixed
AC!D Audio Technology Fixed Now DSP Manager Works Properly
And More....
DSPManager Fix : Download
Dragons Jelly Bean V2.3 (XXDLIB)
Changelog:
Updated Siyah Kernel 1.6.8
Added Perseus 23.4
Added Franco R18
Added Phenomenal 4.0 Normal-Medium-Extreme
New Framework-res with modifications for more stability
New SecSettings with modifications for more stability (hope the settings fc's issue some users encounter is solved)
Fixed and changed some in the Aroma script
Added Lockscreen Big Weather Mod (Thanks to Turkbey)
Updated anps-config list
Updated Light manager 2.6
Updated Streetview
New rom is totaly clean of performance scripts and mods, you can now choose to install and find out which one works best for you.
All Previous mods
And more...
Installation Instructions:
Recommended Full Wipe!!!
1. When installing rom first choose install System
2. After installation system reboot phone, let phone boot and then set google account.
3. when done setting google account leave phone alone for 15mins and let the media scanner do its job!
4. Now you can reboot to recovery and start installing mods and so on in the Dragon Jelly Bean Kitchen
Hello Guys there will be some delay in the releases for now due my sgs3 is broken.. hope to buy new sgs3 soon so everything goes back to normal Please consider a donation so the faster i can buy a new sgs3
Thanks to you all for the patience and support..
Dragon
Don't forget after flashing rom and first boot, to update the root binaries in SuperSU
Vorschau Bilder von Bats Signal Wifi etc.
Themes
attachment.php
Batteries
Signal
XDA THREAD
Wenn euch die Rom gefällt dann Bewertet diese bzw den Thread doch bitte mit 5*****
So hat man ein gutes und erfreutes Gefühl beim Flashen;) Danke.....
ICs Versionen sind hier :
XDA THREAD
JELLY MIX THEMES BY M@STA_GEE81&DR.NO
Reaktionen: störte, niko2006, macduck und 16 andere
na endlich das warten hat ein ende, war auf mein S2 das beste Rom.
Lief stabil und schnell
Reaktionen: qwasd
Auf das Rom bin ich auch schon gespannt. Mal sehen ob es meinen Favoriten XliteRom_V7.0 ablösen kann.
DragonICS Rebith V1.0
Release Date
29-06-2012
Reaktionen: Kumo
Originally Posted by Dragon7780
uploading now!!!
Hab ich schon gelesen ... bin mal gespannt ob es heute nacht noch was wird :confused:
Ich hoffe es dauert nich mehr sooooo lange...werd es dann auch gleich mal testen :drool::drool::drool:
Yes...sie is online!
Boa 730Mb !!!! Das is schon nen Brocken ;)
Aber Testen tue ich diese Trotzdem ...
hat die Rom schon jemand drauf und kann mal sagen wie sie läuft
Geilo endlich joa ist echt nen brocken, mal sehen waset drauf hat.
Zum Glück kann man volles röööääärrr saugen, 6 MB's :)
Der ursprüngliche Beitrag von 08:29 Uhr wurde um 09:02 Uhr ergänzt:
So Leute grad am drauf bügeln, melde mich dann in ner halben Stunde nach einigen kürzeren Tests:)
Der ursprüngliche Beitrag von 09:02 Uhr wurde um 09:16 Uhr ergänzt:
Ok Leute meine ersten eindrücke sind echt überragend, es läuft bis jetzt alles extrem flüssig, und bis jetzt funktioniert auch alles. Wenns so weiter geht wird es meinen Favoriten ablösen(Xlite V7)
Also mir sagt es nicht zu. Su geht nicht und auch sonst macht es keinen guten eindruck. Bin wieder zurück zu meiner Favorit Rom.
Jap musste ich auch leider feststellen, und nachdem ich grad alle Apps drauf gehauen habe geht hier grad ne halbe Standbild Party ab. Naja vielleicht gibt es nach ein paar Updates noch ne neue Chance.
Back to Xlite V7.0
bei mir läuft die rom einwandfrei
Dachte ich auch erst, nachdem ich aber alle Aps (400 knapp) lief garnix mehr gut:)
mit titanium wa ;-)? Hauptsache keine Daten wieder hergestellt!?!?
(wtf!? wofür brauch man 400apps!? bevor du die Hälfte aufgerufen hast ist doch der Akku leer ;-) :-D)
...mit Tapatalk vom S3 @xltiterom v7 ^_^
Das sind docjlh nicht viele Apps, ich kenn genug Leute die deutlich mehr haben.
.. wieso will der Updater gleich eine neue Romversion herunterladen? :ohmy:
... und weg damit! test mal das XLiteRom V7
auch hier sind die widgets abgeschnitten.. z.b das orginal widget vom mp3 player- ich kann die grösse nur nach oben und unten ändern und immer bleibt ein halber satzt am ende stehen..sieht scheisse aus. wenn einer weiss wie man das ändern kann..
Ich hab das Problem , bei allen Roms , das ich nach Titanium herstellung den Wasser Lockscreen nicht mehr habe ?!?!?
Da kommt dann immer der Kreis mit den Pfeilen ?!
Hab auch alle Einstellungen nachgeschaut ... und unter Sicherheit , weitere Einstellungen für Bildschirm Sperre kann ich den Wassereffekt nicht auswählen !?!?
Weiss einer mehr ?!?!
P.S Wallpaper hab ich auch geändert , aber immernoch das gleiche :(
Kani_23
Spot.Zwei
Spot.Zwei
araic
araic
Droid228
Droid228
