[ROM][4.2.2][XXUFME7][Sotmax JB Ultimate Stock v25 HD] *stable as rock*
  • 319 Antworten
wayne850
wayne850
Der Entwickler, android-hilfe.de und der Urheber dieser Anleitung übernehmen keine Haftung für mögliche Schäden an eurem Gerät!
Dies gilt auch für Garantieansprücher gegenüber dem Hersteller eures Gerätes.
Ihr seid daher für euer Handeln selbst verantwortlich!!!
Orginal post von Sotmax bei xda
Originaltext Entwickler:
This is ONLY for the GT-i9300 international version.Do not flash it to any other Device
This rom is for anyone who wants to keep the stock look and have a device as it looked the first time you powered it on.
Pre-rooted, deodexed & zipaligned and with some serious add-ons that i think in my opinion will be needed and only that.
I did not disable any function or removed any bloatware(sometimes a few things only) or any other stuff, as i didn't want to make someone to have to search for them if he/she needs them.
Also this is my personal build and just want to share it here.
It is for everyday use, with out a single fc and is absolutely BUG FREE.​
sotmax Ultimate stock V24 XXUFME7 (4.2.2)
Changelog:
Sotmax Ultimate Stock V24
Add ink effect and aosp lockscreen thanks to arsaw
Add New 4.2.2 camera and gallery to aroma installer
All heating issues seems to be gone
Stabilized virtual memory with some scripts
Some minor fixes to updater script
Updated aroma installer and binary to latest version
Add pop up browser
Stabilized system a little bit more
Speed it up a little (trying to find the Golden Mean)
some bug fixes here and there
some boost scripts
Download
V24 download link:
Android Filehost
(md5:
17f4e075ae6b0fc43f491c7b81b0035d)
Screenshots
sotmax Ultimate stock V19 XXEMC3
(letzte 4.1.2 Version)
Changelog:
Based on latest Fw XXEMC3
Fixed Scloud option not installed in some cases
Add latest jkay framework and lite app
Add more options in Aroma
Add Siyah Kernel as an option in Aroma
Add ability to avoid kernel installation
Add some modems to choose (10 total) and the ability to avoid modem installation
Add New original Playstore 4.0.25 in white and blacked theme
Add all available multiwindow colour with the ability to choose both 320 and 240 dpi
Add call recording options both 320 and 240 dpi
Replace S-Note app with the version 10
Add again the ability to choose between original and note 2 keyboard with and without auto correct
Some more performance tweaks
Some more i cant remember
Download:
Android Filehost
Mega
RomHut
Installationsvoraussetzung:
Dies ist eine "non-wipe" ROM.
Das bedeutet, dass es nicht zwingend erforderlich ist einen wipe durchzuführen.
Es ist aber ratsam einen wipe durchzuführen, speziell wenn man nicht von einer Jelly Bean ROM kommt.
Voraussetzung für die Installation sind Rootrechte.
Falls das Gerät noch nicht gerootet ist, kann man dies z.B. CF-Auto-Root nachholen.
!!! Akku muss ausreichendgeladen sein, am besten voll !!!
Installation:
  • heruntergeladene ROM im .zip Format auf der internen oder externen SD-Karte des S3 speichern.
  • S3 ausschalten
  • Das S3 mit den Tasten Lautstärke +, Homebutton und Powerbutton in den recoverymodus versetzen.
  • Sicherheitshalber ein Nandroid-Backup erstellen.
  • Wipe dalvik & cache durchführen
  • Wipe data factory reset (Kann übersprungen werden, kann dann aber auch wie oben beschrieben zu Problemen führen)
  • .zip von int. oder ext. SD Karte installieren
  • Optionen im Aroma Installer auswählen, bei Zweifeln einfach die vorgegebenen Optionen wählen.
  • Nach Abschluss der Installation rebooten
  • Freuen und geniessen
Sotmax Roms App bei Google play
Reaktionen: wieselfried, DarkSonic, brommau und 4 andere
Läuft einwandfrei.
Thx
Probiere auch mal.
V8 ist die aktuelle Version.
Features & Change Log
sotmax Ultimate stock V14 XXELLA
Features:
-Based on latest official firmware 4.1.2 XXELLA (UK)
-CSC i9300XAELLA
-Baseband i9300XXELLA
-Stock look-theme free for avoid slowing down device and keep stock look.
-Stock bootanimation & bootsound
-Multilanguage
-Kies Supported
-Pre-rooted deodexed and zipaligned (superSU)
-Aroma installer implement with Yank555.lu latest kernel thanks to Yank555 who makes also the installer
-Permanent fix for phone and contacts opening lag(NOTICE:If you flash other kernel than included make sure that can handle init.d. Also if you flash latest Yank kerenl pick the option to let kernel handle init.d. The phone app and contact app will not close while they stay inside job manager and even if they close they have the highest priority to pen much more faster than stock or previous versions)
-Permanent fix for TW launcher redraw
-Dialer fix for 240dpi mod
-Add per dpi app and mod for 240dpi mod
-Implement HD voice on many Networks a mod by tarzan11 so all credits to tarzan11
-Very specific ram and speed tweaks for optimal performance
-Native script to ensure more ram without killing apps(while restarting they drain battery)
-Add option to make statusbar fully black via aroma installer
-Add Nexus 4 Clock via aroma installer
-Add Xperia Z launcher ported fully by ThillinaC
-Add Xperia Keyboard port by gregbradley
-Add Playstation app fully wiorking if your region allow it
-Unbranded
-UI sounds changed (not bloop bloop in menus & some others)
-Stock power off animation
-Data app functionality to let user remove apps that dont like and keep system clean
-Full weather in lockscreen via Aroma installer
-4.2 apps from nexus 4 via Aroma installer
-New transparent weather widget with correct values
-Option to choose dpi via installer (thanks to bala_gamer)
-Full caller picture via Aroma installer
-4.2 sounds from nexus 4
-4.2 lockscreen option
-Green eye smart stay icon via Aroma installer
-Gmail updated to 4.2 official
-Resizable popup browser(thanks to freddy1991)
-Sms recipients increased to 200
-No mms conversion
-Phone & contacts app lagfix ( while you keep them in job manager but notice that if system need memory will close everything in its way)
-Multiwindow with all available apps added via multiwindow control app
-Transparent multiwindow mod (thanks to whiskeybro)
-Native Call Recording Repacked specific to that version (thanks to wanam Guide)
-Non increasing ring (thanks to wanam Guide)
-Modded NFC app to keep it running even at lockscreen (thanks to AndiP)
-init.d support
-Extended power menu ( thanks to AndiP )
-Galaxy note 2 gallery fully working from official firmware
-Paper artist incuded from official firmaware
-Torch light widget from N7000 (assistive light is ungly but still present for anyone want it)
-SNote App from Note 2 (thanks to Arsaw)
-More fonts
- some Live Wallpapers(including earth live wallpapers from sony xperia)
-flash Player
- Google Ears ( with transparent widget )
-Add music hub
-add video hub
-Optional apps via aroma installer
[FONT=&quot]Changelog:[/FONT]
Changelog:
Sotmax Ultimate Stock V14
New kernel by Yank555 V3.1b with many more options
Add Xperia keyboard port by gregbradley
Add Playstation app fully working if your region allow it
Remove ink effect as it caused problems to some users
Some more hidden
Sotmax Ultimate Stock V13
-New Samsung updated version XXELLA UK
-Multi CSC set to EUR
-Add New Kernel from Yank 3.0a with Soft-patch MoviNAND VTU00M (16GB) eMMC failure
-Add the ability to choose between 320 and 240 dpi in device system thanks to bala gamer.Is in experimenta phase but working well.
I will work further on this
-Add option to choose lockscreen from Nexus 4>
-Add option to choose Nexus 4 sounds
-Add Google Play Music via Aroma installer
-Add Google Wallet via Aroma installer
-Add New Accuweather Widget thanks to KIMBASINGER
-Fixed Google bookmarks bug
-Fixed Exit button in stock browser
-Some other small fixes
-Some more tweaks
-Some more changes inside
Reaktionen: Kumo
Archiv
[FONT=&quot]v12 download links[/FONT]
[FONT=&quot]
[/FONT][FONT=&quot]devhost mirror from yank [/FONT]
[FONT=&quot]
[/FONT][FONT=&quot]google drive [/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]for uk owners that want hd voice enabled flash this version from tarzan11[/FONT]
[FONT=&quot]Quote:[/FONT]​
[FONT=&quot]For anyone dont want to miss g icons in contacts grab specific file from attachment and flash it via recovery[/FONT]
V11 Download Links
Android FileHost
MD5::::::697FE748F12A0AD14C22B497F8F7F362​
[FONT=&quot]
V10 Download Links
[FONT=&quot]
[/FONT]
[FONT=&quot]Dev-Host Mirror from Yank555 [/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]RomHut Mirror [/FONT]
[FONT=&quot]
[/FONT][FONT=&quot] Android filehost [/FONT]
[FONT=&quot]Mediafire Mirror From Stanly08[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]MD5[/FONT][FONT=&quot]::::: f39eb8bf368a91ff783ad9aae55ec488[/FONT]
[/FONT]
V9 Download links
NOTICE: If you stuck at the end of the aroma installer dont panic.Hold power for some seconds to force reboot and that wil lead you into recovery again.Then just press reboot system now.
This happens to some cases only and we are working on that to solve it.
Once solve this i will just replace the file
[FONT=&quot]Google Drive [/FONT]
[FONT=&quot]Torrent download [/FONT]
[FONT=&quot]Also you can find it in attachment [/FONT]
[FONT=&quot]Download from Android file host[/FONT]
[FONT=&quot] One more mirror thanks to kepz[/FONT]
[FONT=&quot]::::::MD5:E45AA9051772489B77D57A68E129BE9C[/FONT]
V8
MD5: CA214B45935EE99805E2D206C66396EE​
V6
Download Here
MD5:::::::::::::::
9E3CC2384BA161B1B8B9BEBEA2D5C5B2
Reaktionen: Kumo
Hall Zusammen,
habe Post 1 etwas Aufgeräumt & Übersichtlicher gestaltet
Unter Downloads jetzt mehr Mods gelistet - stammen alle vom Original Port
Features & Change Log findet Ihr jetzt in Post 4
& Archiv in Post 5
Seer gute arbeit Läuft einwandfrei stabil mit eine fantastise battery.
Ich habe mit Yank kernel und ist super.
Kann ich nur bestätigen.
Habe aber noch den Stock kernel.
Damit ich einen Vergleich habe, wenn ich den Kernel wechsle.
Hallo Zusammen, wer hat Lust ein How to Video von dem Rom zu machen?
Einfach in den Beitrag posten, Ich pinne es dann mit Urheber Verweis in Post 1! ;)
sotmax Ultimate stock V9 XXELKC​
Online!
- Download Siehe Post 1 & Features & Change Log Post 4
Viel Spaß beim flashen!
Danke! V8 läuft super....:thumbsup:
Kann ich V9 da einfach drüber flashen oder muß ich nen full wipe machen?
Full Wipe ist natürlich die die sichere Sache. Aber Cache und Dakvik sollte reichen. Es sei denn es treten FC's auf, dann ist nen Full Wipe von Nöten.
Also habe die Rom jetzt auch getestet, da sie auf XDA einen kleinen hype ausgelöst hat. Läuft sehr flüssig und ist dazu akkuschonend :) gefällt mir:thumbup:
V10 ist online :)
Post 1 Aktualisiert!
Das ist ein sehr schönes rom. Mir fällt nur eines auf (hatte ich aber mit dem Omega Rom auch schon): die "Seitenlasche" mit dem apps verschwindet regelmäßig und ich muss dann in Einstellungen unter dem Punkt Anzeigen jedes mal erst den entsprechenden Hacken entfernen und dann wieder setzen
um meine Leiste zu bekommen.
Hat das noch jemand bzw. besser noch Ideen, wie ich das in Griff bekomme?
Stefan
Du meinst die Multiview App Leiste?
Die kannst Du mit langem Druck auf die Zurücktaste (de)aktivieren.
Bzw. holst du sie mit einem langem Druck auf die Zurück-Taste auf den Bildschirm.
[Mobil gesendet][GT-I9300] Sotmax V8
V11 ist online:
Code:
[B][U][SIZE=3][CENTER]Ultimate Stock V11[/CENTER]
[/SIZE][/U][/B]
[B][CENTER][SIZE=3]-New kernel from Yank555 compiled with old ramdisk and secure from latest root exploit on exynos found by alephzain
-Based on latest Uk Firmware XXELL4
-Add option to choose non transparent weather widget
-Add TW landscape rotation option
-Add multiwindow control tweak thanks to LegendK95@xda
-Add option to choose non transparent sidebar
-Add option to choose keyboard from Note 2(not having 3rd page so no smilley code)
-Enable true no converting to mms after 4 sms
-Add Snote App as an option in Aroma to handle more system space if someone dont need it
-Add some more features in system
-Add some fonts
-Add some tweaks to make system snappier[/SIZE][/CENTER]
[/B]
Download:
sotmax_Ultimate_stock_V11_XXELL4_Aroma.zip | by sotmax for Galaxy S 3
Reaktionen: MULO, Tavros und Satarius
Danke für Eurere Tipps mit dem Multiwindow. War genau das, was ich gesucht habe (und geht auch wie von Euch beschrieben).
Würde auch den "Danke Knopf" drücken, wenn ich ihn nur finden würde.
borussemd
Caho
Android_Noob.
Tavros
LouCipher
LouCipher
