blackscript
Achtung wichtiger Hinweis
Android-Hilfe.de, XDA und der Urheber der Rom übernehmen keine Haftung für mögliche Schäden an eurem Gerät!
Dies gilt auch für Garantieansprüche gegenüber dem Hersteller eures Gerätes.
IHR SELBST seid daher für euer Handeln verantwortlich!!!
Der Rest wurde/wird aus dem >>>Original Post<<< bei XDA übernommen.
Dank an ksr007, dass wir die ROM hier vorstellen dürfen!
Super Fast-Smooth-Clean-Battery FriendlyHello everyone ! this is the second rom cook that I did.You can find my first rom for the Galaxy S2, called the "Purelook S3".
And now a new rom for galaxy S3 called the " Purelook HD", with the main inspiration is from Xperia Z.
findet ihr >>>HIER<<<
Aktuellster Changelog
v8.0 XXEMF1 (JB 4.1.2)
- Base XXEMF1
- Modem XXEMF1
- Kernel Stock repacked XXEMF1
- Update Boeffla kernel to v2.12 stable
- Update Googy max kernel to v1.5.4
- Added Camera from S4 GoogeEdition
- Xperia Z Ultra defaul wallpaper and lockscreen wallpaper in Xperia & translucent theme .
- Galaxy MEGA defaul wallpaper in Samsung TW theme .
- CODEX HD v3.1 (thanks to @codexc) :
- New Xperia z Keyboard from new base 4.2.2
- New Xperia z apps Movie/Album new base 4.2.2
- Bravia engineer 3
- Added in AROMA for chooser :
- Sound when booting phone up
- Bootanimation : Samsung or Xperia Z
- System Sound : S4 or Xperia Z
- New dock themed (Z ultra) for Xperia launcher v2.05b
- Rewrote some tweaks and scripts .
- Added Office Suit Full from Galaxy S4
- New Battery icon
READ BEFORE CHOSE IN AROMA :
XPERIA THEME : Chose Xperia v9.6 theme ( or Translucent theme)> chose Xperia icon pack !
If you want Xperia launcher with enables showing unread counts for SMS, calls, Gmail and K-9 mail - That is awesome launcher of ra3bal and buy it by the following link.
Unread counts:
Xperia Unread provides unread counts for SMS, Calls, Gmail and K-9 Mail for the Xperia Launcher.
It supports all SMS and Phone apps.
Screenshot!
Galaxy S4 theme + feature : Chose S4 apps in Addon app > chose Stock TW Galaxy S4 theme > chose Galaxy S4 icon pack .
Got FCs with Xperia keyboard ( download and flash new version from here) XDA Forum Link
V7.2 beta3 XXEME2 (JB 4.2.2)
V7.2 beta2 XXEME2 (JB 4.2.2)
V7.2 beta XXEME2 (JB 4.2.2)
v7.1 FINAL XXEME2 (JB 4.1.2))
v7.0 XXEME2 (JB 4.1.2)
v0.1.2 XXUFME3 [4.2.2-leak]
v0.1.1 [4.2.2-leak]
v6.1 FIX online
v5.2a Final
V5.2 Online
V5.1
V5.0a XXEMC3 for testing only
+Added Shark kernel v15.1 in AROMA
+New Accuweather Widget S4 (latest version of Dr3oma)
+Added option in AROMA to enable Home&lock button in status bar (customized in Jkay deluxe setting, Jkay setting > set notification option)
+Transparent status bar without lost ripple effect and new font for date&month (Circle lockscreen, you need Jkay deluxe setting and customized in lockscreen options)
+Edit and add some new tweaks for build.prop and etc/init.d (UV kernel by 91sysctr tweak in init.d)
+S4 themed for Seclauncher2.apk (TW launcher Samsung)
+update GG playstore to latest ver 4.0.26
+Back to original gmail.apk (white theme)
And others thing i do not remember, will add soon.
Pleas feedback to me . thanks you !
V5
Base Firmware: I9300XXEMC3 (4.1.2)
Region: Europe
Country: Nordic Countries
Carrier: Unbranded
Build Date: 27 March 2013
CSC: NEEEMC1
Change List: 1071725
- All features from v4.0c
+ Fixed and update Xperia keyboard to v4
+ Update S4 keyboard to v2
+ Changed and added some tweaks in init.d and build.prop (3g + network + system + performance)
- Update to latest Jkay framework 14.93.3 for XXEMC3
- Update Framework for transparent theme to 14.93.3
- Add modem XXEMB6 in AROMA
- Removed 3 kernel in AROMA : Adam, perseus , boeffla
- New UI when stating AROMA installer
- Removed Option for Lock&Home button on status bar in AROMA
- Update Galaxy S4 theme to v5
- Add ink effect for circle lockscreen (go to setting > lockscreen > lockscreen options > Ink effect)
- Update Multi window control to XXEMC3
- New defaul battery icon for Xperia theme + S4 theme
V4.0c for testing
Changelog v4.0
- Added [MOD][SCRIPT] Project Extreme
- builp.prop and init.d
- Juwe ram script
- cross breeder 6.20.13
- Update Googy Max to v1.0.5a
- New v6 script and Cross breeder 6.20.13
- Added v6 super changer script and seeder ( higher performance, speed, reduce lag...)
- Update Shark kernel to v18.3
- Added modem XXUpdate Googy kernel to v2.0
- Added Headphone.apk ( you can add any app in there when headphone is plugin)
- Edit some build.prop and init.d for performance and smooth)
- New defaul wallpaper for XperiaZ lockscreen
- Camera stock Modded
- EMB6
- Fixed Ink effect
- Update Googy max kernel to v1.4.9
- Update Boeffla to 2.12 beta 8
- Rebuild some tweak in build.prop and init.d
- Enable more Languages for Chooser
- No mms in call log
- Base XXEME2 - JB 4.1.2
- Modem : CEELL1
- Update all app system to XXEME2
- Jkay framework 14.95
- Update SuperSU v1.32
- Update latest Gmail.apk
- New Multi window theme for Translucent and S4 themes
- Rewrote somes build.prop and init.d
- Update kernels in AROMA :
- + Shark v18.2
- +Boeffla 2.12 beta6
- +Googy Max v1.4.7
- + Googy kernel V1.5.8
- + Kernel stock XXEME2
- New PureXAudio Remixed version 1.0
- New defaul wallpaper.
- Edited some tweaks & script for build.prop and init.d
- Added " V6 super changer Script" ( better ram and system, but do not use it if you want multitasking)
- Remove white theme & green themes transparent
- Added Stock theme S4
- Updated for Blue theme transparent
- Changed wanam stock kernel > Omega stock kernel ( thanks to OMEGA team)
- Update Galaxy S4 launcher and Accu weather to Latest MDL S4 firmware . ( thanks to Arsaw)
- Added Touchwiz UX 2013 themed for both themes in my rom (thanks to Kik0o)
- Camera mod HQR XXUFME3
- Added " hold menu to kill app"
- Added " Ink effect" ( only use with Ripple effect)
- somethings i forgot, i add it later
v0.1.1 [4.2.2-leak]
- Rewrote AROMA installer
- Only stock kernel repacked
- Remove bloatware apps
- 3 theme to choice : White , green , blue
- Deodexed & Rooted & Zipaligned & Busybox
- SMS recipient list & disabled conversion sms to mms
- Hacked Stock Email App
- Latest SuperSu update (V1.30) (Pleas go to SuperSU app and update Su-
- Enabled all supported languages
- Multi CSC (+145)
- No SMS on Call logs
- Enabled Exit button to browser
- Enabled Call button on Contacts and Logs (optional)
- unlimited Contacts joining
- Enabled Shutter sound menu on Camera
- Disabled Shutter sound on Apps
- Enabled Camera during Call
- Enabled Call recording
- 4 way reboot (Reboot, Hotboot, Recovery, Download)
- Accu weather galaxy S4
- Touchwiz Launcher3 Galaxy S4
- Latest Samsung Apps
- Flash player supported
- And other things i don't remember
v6.1 FIX online
- Fixed for Ink effect
- Fixed SecwallpaperChoser.apk
- Update base XXEMD2
- Kernel stock XXEMD2
- Update Jkay framework to latest 14.95
- Added options to chooser theme for status bar (motomoto, Xperia,Blue angel)
- Side to Side animation TW
- New battery icon for both themes
- More Tweaks for build.prop (3g & streaming, touch boots, audio quality...etc)
- Update "SecwallpaperChoser.apk" to latest version from Galaxy S4
- Update for Xperia toogles status bar (2g,BT tethering, wifi tethering)
- Update some icons for Xperia Z style icon theme
- Replaced Camera mod by stock camera of XXEMD2
- New defaul Wallpaper in rom
v5.2a Final
- Fixed for Crash UI
- Stock animation (if you want animation in v5.2 - DOWNLOAD HERE)
- Update Shark kernel to v16
V5.2 Online
- New themes for status bar (If you don't like, pleas check in Addon page in OP for stock theme of status bar)
- Rebuild some tweaks in init.d and build.prop (More smooth & fast, hope also on battery life)
- New TW animation (SIDE TO SIDE animation)
- Replaced XXEMB6 modem by XXEMC2 (requested by Spevil07, some troubles with MB6)
- Added some addons in Addon page ! pleas check .
V5.1
- Update Jkay framework to latest 14.94
- Update transparent theme (some apps and transparent in call going) (Credit to @nguyenxuanhoa for his awesome works)
- Update GG playstore to latest 4.0.27
- Update Shark kernel v15.3
- Added Perseus kernel v36.3 in AROMA
- All features from v5.0a (Read Here)
- Added X4 video player from Xperia Z
- Removed AC!D audio v7 in AROMA
- Added PureXAudio (Enable by defaul and you will not see it in rom because it's system file) (Credit to ZeroInfinity)
V5
Region: Europe
Carrier: Unbranded
CSC: NEEEMC1
V4.0c for testing
Changelog v4.0aNote : this is not official update, only for testing !
v4.0c only a small update patch .(49,2mb), first install v4.0a then go to CWM and flash v4.0c !
- Fix and update Xperia keyboard to latest version 4
- Fix and update S4 keyboard to Version 2
- Alot of tweaks and script for build.prop and init.d
+ 3g, network, internet speed tweak
+ Battery life tweak
+ kernel and system tweaks
- Speedmod k2-12 (kernel source update 10) included in v4.0c because i like this kernel (you can change whatever kernel you like)
- Added Xperia bootanimation + media (ringtone+Ui sound+ alarm) [If you want Samsung bootanimation, flash Disable_custom bootanimtion from HERE]
- added apk file for code test *#197328640#
- Replaced AC!D v5 by AC!D v7.0 (if you use AC!D v7 it will cause FCs for choser soundeffects in setting/sound)
- Xperia launcher advance v2.05b cameback as defaul in Rom
- New theme for Seccalendar.apk (more easy to read and write)
Changelog v4.0
¤Base Firmware: I9300XXEMC2 (4.1.2)
-Region: Europe
-Country: United Kingdom
-Carrier: Unbranded
-Build Date: 11 March 2013
-CSC: OXAEMC2
-Change List: 1042335
¤ Update Jkay framework 14.93.1 XXEMC2
¤ Replace XXELLA modem by latest XXEMC2 modem .
¤ Remove Lonas kernel in AROMA (3 versions)
¤ Add syiah 1.9.1 - Perseus v35 - Speedmod K2-12 (kernel source update9)
¤ Replace AC!D v7.0 by AC!D v5.0. (V5.0 Compatible better)
¤ Translucent theme updated to latest framework 14.93.1( special thanks to Nguyenxuanhoa, my friend-my master)
¤ Fixed mod Lock&home buttons on statusbar
¤ Remove Chrome.apk (you need download from CH play to get its working)
¤ Replace Google playstore inverted blue by original playstore from GG (phonesky.apk) - hope it will help faster download from GG play.
¤ Original Youtube.apk comeback - Fix for errors login your account.
¤ Add Secnotemyfile.apk with white themes (Galaxy S4 theme)
¤ Remove Xperia advance launcher v2.05b to option in AROMA
¤ Change bootanimation from Xperia Z to Samsung (flash this if you want back to Xperia Z bootanimation)
¤ Boot sound Galaxy s4 option in AROMA
¤ New toggle from Elegant v6.0
¤ New theme for Walkman music (See here for what's new) ]thanks to ThilliaC
Flash Anleitung
-Natürlich ist ROOT vorraussetzung
-Downloaden und auf die interne SD Karte kopieren
-Das S3 im Recovery Modus starten
-Im Menü install Zip from SDcard auswählen
-dann choose zip from sdcard wählen
-auswahl nach belieben im Aroma treffen und flashen
-Ende der installation abwarten und Neu starten
-Sollten FC´s oder sonstige Probleme auftreten, einen Full Wipe durchführen und ggf. erneut flashen
- Viel Spaß mit der Rom !!! -
DOWNLOAD CENTER
Purelook HD v8.0 XXEMF1 -JB 4.1.2 (02/07/13)
DOWNLOAD
Purelook HD v7.1 FINAL XXEME2 -JB 4.1.2 (17/06/13)
DOWNLOAD
Purelook HD V7.2 beta 3 XXEME2 | FOR TESTING ONLY! (20/06/2013)
DOWNLOAD
Purelook HD V7.2 beta 2 XXEME2 | FOR TESTING ONLY! (20/06/2013)
DOWNLOAD
Purelook HD V7.2 beta XXEME2 | FOR TESTING ONLY! (20/06/2013)
DOWNLOAD
Purelook HD v7.0 XXEME2 -JB 4.1.2 (13/06/13)
DOWNLOAD
Purelook HD v0.1.2 XXUFME3 -JB 4.2.2 (02/06/13) - LEAK
DOWNLOAD
Purelook HD v0.1.1 XXUFME3 -JB 4.2.2 - LEAK
DOWNLOAD
Purelook HD v6[19.Mai]
DOWNLOAD
Purelook HD v6.1 FIX
DOWNLOAD
den 6.1 fix über die v6 flashen
Purelook HD v5.2a[10.Mai]
DOWNLOAD
Purelook HD v5.2[7.Mai]
DOWNLOAD
Purelook HD v5.1[1.Mai]
DOWNLOAD
Purelook HD V5.0a XXEMC3 for testing only[Apr 22]
DOWNLOAD
Purelook HD v5.0 IGalaxy SIV meet XperiaZ I[Apr 13]
DOWNLOAD
Purelook HD v4.0a XXEMC2 (08/04/13)
DOWNLOAD
DOWNLOAD
DOWNLOAD
DOWNLOAD
DOWNLOAD
DOWNLOAD
DOWNLOAD
Pleas note :
One bug in transparent theme when you playing video app defaul.
-How to fix :*
Play your video and touch to icon "zoom in &zoom out" on play screen. When it's change to scale screen, you will able to see video
DOWNLOAD
DOWNLOAD
DOWNLOAD
DOWNLOAD
DOWNLOAD
DOWNLOAD
DOWNLOAD
DOWNLOAD
DOWNLOAD
MODS
