[ROM][4.1.1][MIUI V5] miuiandroid.com 3.11.29 Multi-Lang
  • 137 Antworten
gordon-1979
gordon-1979
Stamm-User
119
miuiandroid.com stellt vor
MIUI v5
MIUI v5 Multi Lang 3.11.29
MIUI ROM 3.11.29 Changelog
[Phone]
Fix – When user was answering call, the status of the upper Status bar was irregular (11-26)
[Locks screen, Status bar and Notifications]
Optimization – The push icon displays pushed apps’ icons (11-27)
[Home screen]
Optimization – Improved Gaussian blur effect for 1080p devices (11-27)
[Browser]
Optimization – When a page is added to the Useful tab, the corresponding shortcut square’s background is the same color as the page’s (11-27)
[Music]
Optimization – MiSound prompt added (11-25)
Fix – Sometimes playing default video would cause FC (11-25)
[Downloads]
Fix – Sometimes changing the system language would cause app to FC (11-25)
[Gallery]
New – Cloud images can be played as slide show (11-22)
New – User can share cloud images using third-party apps (11-22)
Optimization – Faster loading time for start page and local images page (11-22)
Optimization – Screen saver settings moved to system settings (11-25)
Fix – When Gallery was open, the bar along the bottom of the screen would flicker (11-22)
Fix – Sometimes an error would cause cloud images to increase to over 1000 (11-22)
Fix – When user closed cloud album, cloud album images would still be displayed as screen saver (11-25)
Fix – The on the local storage page, the phone’s internal storage and external SD card were being displayed with the same name (11-25)
[Themes]
Fix – Themes with incompatible components cannot be applied (11-28)
[Video]
Optimization – Improved display for details page when viewing with lager system font sizes (11-26)
Optimization – When DLNA devices are found, they are displayed in the same directory (11-27)
Fix – Sometimes, when coming from the player interface, the details page would FC (11-26)
Fix – When system was set to English, some menu titles were still displayed in Chinese (11-26)
Fix – When user tapped search button, two loading animations would appear (11-26)
Fix – Sometimes app would FC in list view (11-26)
[Weather]
New – Weather data for cities out side of China added (EN locale only for now) (11-26)
New – Inclement weather warning feature (11-26)
New – Trends data now includes weather data from the previous day (11-26)
Optimization – Improved weather animation for clouds at night (11-26)
Optimization – User can swipe between pages (11-26)
Fix – Some themes couldn’t get weather data (11-26)
[Security Centre] (Mi2 & Mi2A only)
Optimization – Increased efficiency for virus scans using cloud definitions (11-28)
Fix – After virus scan, app names and icons weren’t displaying properly in virus detail list (11-28)
Fix – When system language was set to English, part of the Power settings interface was still in Chinese (11-28)
Fix – When cleaning up trash, checking for large install packages would cause FC (11-28)
Fix – Sometimes in Permissions, when user was looking at logs, app would FC (11-28)
Fix – Sometimes during “Clean up” process app would FC (11-28)
Fix – Sometimes the number of items cleaned up would display “-1″ (11-28)
Fix – Sometimes changing configurations in Power settings would also enable vibrate (11-28)
Fix – When using a custom power configuration, notification sound on touch feature didn’t work (11-28)
Fix – Sometimes in the auto-clean configuration for cache, the “Never” setting didn’t work (11-28)
Fix – Sometimes power configuration would continuously change back and forth between Sleep and Default (11-28)
[Data usage] (Oppo Find 5)
Fix – Icons weren’t displaying properly (11-28)
Installation:
Download ROM:
files.miuiandroid.com - Downloading miuiandroid_m0-3.11.29.zip
Download Google Apps:
MIUI
Alles auf die SD-Karte Kopieren
Tasten Power+Lauter+Home Gleichzeitig Drücken um in den CWM Recovery zu gelangen
Dann Wippe data/Factory Reset
Und Wippe Cache und Wippe dalvik cache durchführen
Jetzt Flash Rom
Reboot und gleich wieder ins CWM Menü Booten
Zuletzt Flash gapps 4.1.2
Reboot
3-5min warten Fertig
Folgende Kernels habe ich schon getestet:
Siyah 1.9.1 (Fehler Frei)
Neak 3.1.2 (Fehler Frei)
boeffla 2.11 (Fehler Frei)
Übernehmen keine Haftung für mögliche Schäden an eurem Gerät!
Ihr seid daher für euer Handeln selbst verantwortlich!!!
Reaktionen: Bukongahelas, stephan1977, mareis1973 und eine weitere Person
Downloads & Instruktionen
Inhaltsverzeichnis
  • Downloads: Rom & Mods
  • Instruktionen
  • Changelog
Stock Changelog
Downloads
Original Port: miuiandroid.com
Rom
Weekly
Engl.
3.5.24
SGS3 - i9300m0JB
Link
Link
Xiaomi
d10359f18e233d25ad77f14aba3b18a5
Multi
MIUI v5 Multi Lang 3.5.24
SGS3 - i9300m0
http://tinyw.in/wnYm
351967d9e8d0a7dd81696316e0bf84d9
Languages included:
Not updated to v5, so only v4 translation (may occur FCs, not translated words, etc.)
and we are looking for translators:
New v5 translation for:
Will be included:
Mods
GApps
Jellybean 4.1.x : Goo.im Downloads - Downloading gapps-jb-20121011-signed.zip
Control Panel Suite
Instruktionen
Installation:
  • Xiaomi:
  • We release FULL Multilang ROM for Xiaomi devices so you don't need flash our English release at first.
  • Install via Updater app
  • Other Devices:
  • Download and flash our current English Only ROM + Gapps
  • then flash the chosen language pack on top of it. (DO NOT WIPE)
Von einer Samsung Stock- Costom kommend
  • Kopiere MIUI auf deine Interne SD Karte
  • Gehe in den CWM Mod und mache einen Fullwipe data/system
  • Flashe MIUI - Reboot
Fertig
Von einer AOSP (CM9) Rom kommend
  • In diesem Fall erst mal eine Stock Samsung Rom per Odin Neu Flashen
  • Einen für AOSP Roms geeigneten Kernel flashen
(findest Du in der Datenbank Stockrom- Custom Kernel)
  • Keinen Reboot machen - Batterie Raus & wieder Rein machen
  • Dann wie ersteres vorgehen
  • und dann so verfahren ersteres aufgeführt
Platzhalter
Platzhalter
Doofe Frage:
Wo ist der Unterschied zu dem MIUI Germany Releases?!
Einfach nur das Multi-Sprachpack?
Oder irgendwelche Mods? :confused: :smile:
Kannst davon ausgehen, das Sie sich minimal Unterscheiden!
Mod Cange Log ist nicht aufgeführt.
MIUI Multi-Lang ROM 2.7.27 Online - Downloadlink in Post 2
Viel Spaß beim Flashen!
Habe es heute mal geflashed da MIUI Germany mal wieder ewig braucht das dass neue Update rauskommt.
Das
miuiandroid.com ROM läuft an sich echt gut. Problem: Die Deutsche Übersetzung ist mieserabel :flapper:
Darum warte ich dann doch noch etwas. Morgen sollte MG es ja wohl auch mal hinbekommen. :smile:
Off Topic An
In Bezug auf Kritik zum MIUI Germany Release.
Bitte beachten, das alles Ehrenamtlich gemacht und Kostenlos zur Verfügung gestellt wird.
Wir haben in erster Linie zu danken!
Off Topic Aus
Multi LP Version auch Online, siehe Eingangspost!
Weekly 2.8.10 [EN] Online - Steht in Post 1 zum Download bereit!
Weekly 2.8.10 Multi Online - Siehe Post 2!
Weekly Multi-Language Rom 2.08.17 Online - Siehe Post 2!
Da kein ICS Nexus Upates von den China Devs zu erwarten ist wird von Andy Thomson der ICS Port eingestellt!
Mit dem JB Port geht es weiter, es entsteht ein neuer Beitrag bei MIUI England.
Statement Andy Thomson
Originaltext: Then wait no longer.. I've started a new post for the Jelly Bean ROM..
I will no longer be updating this ICS ROM as there is now no ICS base for me to work from, plus I don't have the time to maintain two threads.
Just to be clear the New JellyBean ROM is completely naked!! There are no bells and whistles..No Control Panel no extended power menu no nothing! Apart form lovely JellyBean goodness.. If the enhancements I've mentioned are important to you then I suggest you stay on ICS a while longer. I will be adding all the features back but it's going to take time..
Thanks for all the support with this ROM. See you over at the new thread I hope..
Andy Andy Thomson, 18 minutes ago
#4108
Reaktionen: Simuur95
#4108
Upps, ist Mir jetzt aufgefallen, das Betrifft ja das SGS I und nicht unser SGS III
Der Downloadlink ist ja schon aktualisiert. Gelle!
Sorry für die Falsche Post, eventuell ersehne Ich Mir zu Viel das MIUI Jelly Bean schnell auch für Uns kommt. Lange wird es sicher nicht dauern.
Weekly Rom 2.08.24 Online - Siehe Post 2!
Multi Version - Weekly Rom 2.08.24 Online - Siehe Post 2!
Englisch Weekly 2.8.31 Online - Siehe Post 2!
Weekly 2.8.31 Multi Online - Siehe Post 2!
