[ROM][4.1.1][MIUI V5] miuiandroid.com 3.11.29 Multi-Lang
  • 137 Antworten
klappt bei vodafone nicht. Text bleibt
Ok danke..lade später eine angepasste systemUi hoch für Carrier sollte dann gehen!
Bis ich mein S3 hab bräuchte ich Tester währe nett wenn einige von euch das machen würden....
Darum eine Frage:
Gehen die Smilies noch?
Wollt ihr andere Bootsnimationen?
Andere UI Sounds?
Wenn ja lade ich das später hoch!
Miui v5 3.6.7 ist seit 7.6. Online.
Chancelog :
[System]
Fix - Online time synchronisation causes the system to reboot
Fix - Failure in sleep mode causes phone to reboot
[Messaging]
Optimisation - Messages from last search results will no longer be recorded in Global Search
Optimisation - Viewing details of group sending message, clicking the drop-down menu of recipient list, and then clicking the screen can hide the drop-down list
Fix - In some cases, messages cannot be fully synchronised to phone
Fix - Exiting from the slide editing page back to message thread, MMS titles may disappear
Fix - In some cases, receiving MMS messages leads to Messaging app flash back error
Fix - In private messages, click on the search results allows creating New Message option
Delete - Removed two emoticons which cannot be displayed
[Camera]
Fix - In some cases, thumbnails cannot be displayed
[Music]
New - When using earphones with remote control, long press on the “Previous” and “Next” buttons allows to fast forward and rewind
Fix - After clicking “Shuffle All” in local music, it always starts playing from the first item in the list
Fix - Download icon status error on Playing page
Fix - In sequence playback mode, clicking “Previous” on the first song in the list does not work
[Themes]
New - Added support for batch update of local themes
New - Added support for opening MIUI Themes Store links via Theme app
New - New push mechanism (Themes pushed from the web site to...
Link :
miuiandroid.com/community/
MIUI ROM 3.6.14 ist online:
[Contacts]
Chancelog:
New - When searching for contacts with more than one number via T9 dialer, “Recent tag” will be shown for recently used numbers
New - When setting voicemail in the contact details, a confirmation dialog box will pop up
Optimization - After entering contact details from the search results page, clicking on back button will still go back to the search results page
Fix - Deleting a contact failed while editing it
Fix - When selecting "set ringtone" menu item in the contact details, wrong dialog box pops up
Fix - For contacts born early than the year of 1970, the birthday calendar cannot be displayed
Fix - The input box to "Add" or "Rename" group still appears when exiting and reopening contacts application
[Themes]
Fix - Deletion failure of theme package and details page status error
Fix - In some cases, paddling list page may cause flash back problems
Fix - Name display error of the theme you are using on MIX theme screen
Fix - Local and...
Link 1:
miuiandroid_m0_jb-3.6.14.zip
Link 2:
Goo.im Downloads - Downloading miuiandroid_m0_jb-3.6.14.zip
MIUI v5 Multi Lang 3.6.14:
Goo.im Downloads - Downloading miuiandroid_lang_m0-3.6.14.zip
Kann es auch bei Uploaded hochladen.
MIUI ROM 3.6.21 ist online:
[Phone]
Fix - Large square contact photo distortion in incoming call interface
[Themes]
Fix - In some cases, downloaded themes disappear or cannot be used
Fix - Downloading a large amount of themes from the web causes Themes app to FC
[Camera]
Optimisation - When clicking to focus or clicking the menu, QR code button will be hidden
Fix - After scanning QR code, press MI key can still take pictures
Fix - In the photo preview, press the menu button and then quickly slide right to enter camera preview page, white menu will appear at the bottom
Fix - While recording in simple mode, colour effects can still be selected
Fix - Thumbnails not displayed issue
[Music]
Optimisation - Improve efficiency while sliding the song list
Optimisation - While setting ringtone, if not supported format, pop up will display
Fix - For songs which do not support editing ID3, you can manually enter ID3 editing interface
[Browser]
New - Added function for smart loading of pictures
New - When opening browser, prompt whether to open the url from clipboard will pop up with prompt
Optimisation - Improved bookmark history interface
Optimisation - After app installation package download is complete, prompt whether to install or upgrade will pop up.
Fix - While opening browser through third-party apps, multi-window management mode of the browser cannot exit
[File Explorer]
New - Remote...
Link 1:
http://files.miuiandroid.com/3.6.21/miuiandroid_m0_jb-3.6.21.zip
Link 2:
Goo.im Downloads - Downloading miuiandroid_m0_jb-3.6.21.zip
MIUI v5 Multi Lang 3.6.21:
Goo.im Downloads - Downloading miuiandroid_lang_m0-3.6.21.zip
Leute, ich kann den N.E.A.K 3.1.2 Kernel empfehlen, bin bei 72% Akku und 22 h Laufzeit. Performance ist sehr gut. Real racing 3 mit Grafik mod läuft flüssig.
Update:
MIUI ROM 3.7.19 ist da. Erste seite infos.
MIUI v5 Multi Lang 3.7.26 online.
Falscher Thread, sorry. :(
MIUI ROM 3.8.2 ist das auf Wunsch kann ich Uploaded bereitstellen.
Ja bitte. Wäre sehr nett.
Der ursprüngliche Beitrag von 19:11 Uhr wurde um 20:57 Uhr ergänzt:
Download der Multi lang Datei funktioniert leider nicht.
Der ursprüngliche Beitrag von 20:57 Uhr wurde um 21:11 Uhr ergänzt:
Danke.Geht jetzt.:thumbsup:
Update 3.8.9 ist da, Sprache kann die alte 3.8.2 benutzt werden.
Jetzt auch mit Uploaded.
MIUI v5 Multi Lang 3.8.23 ist online.
MIUI v5 Multi Lang 3.8.29 ist online.
MIUI v5 Multi Lang 3.9.13 ist online.
MIUI v5 Multi Lang 3.9.27 ist online.
MiSeRy
Q
MiSeRy
Sakaschi
hellsgod
