[ROM][10APR][XXEMC2] ~ XperianZe 0.9.8.1 ~ [Xperia Z inspired][AROMA][JKay][Elegant6]
  • 317 Antworten
ok danke
Hey Jungs. habt ihr auch manchmal das Problem das Playstore sagt Zeitüberschreitung?
Zeitweise geht es,und dann wieder das?!Woran kann das liegen?
Nein, hab ich nicht, der Playstore funktioniert einwandfrei.
Lösch mal Daten und Cache der Playstore App.
Changelog:
v.0.9.6.2 (Complete ROM, 421 MB)
(No wipe needed if you're coming from 0.9.6.1 or 0.9.6, otherwise a Data/factory reset is needed!!)
- Updated Advanced Xperia Z launcher to version 2.0.5b by Ra3al
  • Fixed: Walkman (Music) widget not showing artist name
  • Fixed: Dark Digital Clock widget from ClockWidgets not showing date and alarm time
  • Fixed: The widget with all toggles from OnOfTools not always updating to the currently selected color filter
  • Added: Options to set vertical and horizontal margins for the desktop - in order to increase the empty space on the desktop; separate settings for Portrait and Landscape screen orientation
- Fixed widgets (music widgets shows the artist now and is resizable, Top contacts is working now)
- Zip-aligned all the widgets and the new calculator (forgot that in 0.9.6.1)
- New battery icon (replaced the Circle battery with the Blue Xperia Z icon mod by ksr007)
- Fixed the data arrows in the statusbar
- Added the Lite Camera-MOD HQR by AndroidGX (XXEMB5 version)
  • • Camera 'volume up' and 'down' buttons as shutter.
  • • "Low battery" warning and blocking removed.
  • • "Can't use flash on low battery" warning and blocking removed.
  • • HQ video recording:
  • - 1080p: Normal - 17MBit / Fine - 24MBit / Superfine - 30MBit.
  • - 720p: Normal - 9MBit / Fine - 13MBit / Superfine - 17MBit.
  • • HQ sound recording: (192 kbit/s instead of 128kbit/s).
- Changed the Setup wizard background image (the wizard which you get at first boot when you do a data/factory reset)
- White text in the statusbar (when you select ‘Theme clock’ & ‘Theme battery percentage’ in the JKay app. Was grey before)
- Removed SemcMetaDataCleanup.apk for good now (since some users are still getting the Music Download FC) (You will only lose the FaceBook 'Like' function in the Walkman app)
- Fixed Video Telephony (probably)
Download links:
421 MB (MD5: ee8776074b601faa96018b1872f350a4)
(check the MD5 of your download before flashing)
Data/Factory reset is NEEDED when you're coming from 0.9.5.2 or older (or from another rom)
not needed if you're coming from 0.9.6 or 0.9.6.1
v.0.9.6.2
Android File Host: DOWNLOAD
Mirror: v.0.9.6.2
Dev-Host: DOWNLOAD
:thumbsup:
wird gleich geladen :D
läuft sehr gut keine lags keine Performance probleme :)))
alles 1A
Gute Rom, läuft sehr geschmeidig. Keine FC!
GuMo zusammen,
bekomme seit dem Update die Meldung: "Der Vorgang android.process.acore wurde angehalten"
Woran kann das liegen??
MfG
Läuft einwandfrei, ich vermisse nur die sensme funktion. :mad: gibt es evtl. ne Möglichkeit es nachzuflashen.?
Guillmaster schrieb:
GuMo zusammen,
MfG
liegt meistens daran, wenn man keinen Data/Factory-Reset macht :)
Magic
Habe ich seit gestern Abend auch drauf.
Schaut wirklich alles fein aus.
magicdeep schrieb:
Magic
Na Toll ich Hohle Fritte.... stimmt ja hab ich voll Vergessen :mad2:
Danke dir für den Hinweis :thumbup:
Jetzt lüppt es wie am Schnürchen *g
Also ich kann den Lockscreen nicht ändern bzw. wenn ich ihn änder bleibt das Bild immer gleich..
Noch wer das Problem?
Habe es auch nicht geschafft.
Zum Glück gefällt mir das Lockscreen-Bild.
Kann man über Umwege bewerkstelligen :D in der apk das wallpaper austauschen oder ich meine auch irgendwo gelesen zu haben im Xperia Lockscreen Thread das man eine Verknüpfung erstellen kann.
Sent from my S3 powered by Rocky BALBOA
Gerade mal ausprobiert.
Funktioniert hier ohne Problem :confused:
Magic
läuft wunderbar, leider funzt aber mein CoPilot nicht mehr, hängt sich immer wieder auf, was soll ich da machen, bitte helft mir
Wie kann man beim sperrbildschirm den Hintergrund ändern? :confused:
