Scoty
Ikone
- 1.852
Eben erschienen bei XDA.
Features:
Das Rom wird per Odin geflasht.
Download
Features:
Code:
1, Rooted. Integrated the latest su, superuser and re explorer.
2, Customizable 15 toggle buttons of status bar, setup with LidroidParts. please ref the thread: http://forum.xda-developers.com/show....php?t=1289896
3, Disable launching S-Voice by double-click Home-key so that Hone-key can reponse faster. You can enable it by check 'Launch S Voice' in S-Voice settings.
4, Provider two keyguards samsung-keyguard and android-keyguard. You can switch them by a widget named LockSwitcher, you can find it in "Apps"->"WIDGETS" maybe at the last one or two pages.
5, Remove sms and mms records from call records.
6, Support call recording.
7, Support phone NO. location(only for China).
8, Auto update phone NO. location database.
9, Support auto ip dial.(only for China).
10, Untethered camera, you can take a phone even when low battery life or calling.
11, Integrated LidroidToolbox which include batch install/uninstall/forbid/backup/restore packages, flip mute, auto start management, auto airplane mode switcher, screen shoot and barcode scanner.
12, Integrated One-key-lock. Lock the screen by a single tape.
13, Integrated Market from lidroid.com find more game.
Download
