Datenbank - Diskussionsplattform MIUI V5 [JB] Rom übergreifend
  • 165 Antworten
Ein aktueller SAMMY/MIUI Port von muchopoli83 / xda
Alter Bekannter aus meiner Aktiven Zeit mit dem Samsung Galaxy S
[ROM][MIUIv5][3.5.3][I9300][JB 4.1.1][NOTE2 EDITION][MW, Camera & Keyboard note2....]
Liest sich Interessant:
Changelog MIUI ROM 3.5.3 NOTE 2 EDITION by muchopoli83
I having enjoyed three days of holidays, so, the list of updates this week is pretty simple. I hope you understand. Thank you!
- Translated into the language of Cervantes. (also English and Chinese)
- Multiwindow.
- Kernel Googy 1.5.2.
- Modem+Ril EMC2.
- Center clock mods without carrier (in YAOS Updater).
- Framework Animations (YAOS).
- CRT-OFF (YAOS).
- Black Google 4.2 keyboard.
- Note 2 keyboard (Black and Black-Cyan, also in YAOS).
- Note 2 Camera.
- Lite version.
- Toggle2g.apk
- Fixed installation failure from kernel with CWM6.
- Removed chinese supermarket and other unnecessary applications.
- Added Gapps. Gmail, Google Talk and Play Store.
- Translated clock 2x4.
- Translated pngs in different applications.
- Zipalign.
-Added Yaos Updater to update OTA and download modems, kernels, mods. Thanks to @Dexafree and @Arasthel.
- Organized all icons and all gapps together in one folder.
- Bootanimation thanks to @Klaus99.
- EXTRAS tab in settings, added the following applications:
* YAOS Updater (hidden from desktop).
* Font Installer. Translate to spanish (hidden from desktop).
* Toggle 2g plugin (it can not hide from desktop).
* Recovery Executer: (hidden from desktop) Magnificent and useful application of our fellow @Fraggel, which among other features, installs automatically zips, with or without wipes, selecting them from the SD, makes and restores nandroids backups......
Two options to OTA recognizes files and if there is any update.
1 - Touch button to update (down left).
2 - Touch settings button (down right). Select "check for updates". Thus, every time you open the application, it will automatically update.
Wollte diese Rom von muchopoli83 mal testen. Beim runterladen habe ich da Probleme. Ist das richtig,dass man sie da bei 4shared anmelden muss?
Zekene schrieb:
Wird es eig. Bald mal MIUI mit Android 4.2.x geben? Bald kommt schon Android 4.3 oder 5.0
Hallo noch mal Zekene,
werde Dir Hier mal deine Frage beantworten, da diese ja keine Custom Rom (z.B. xiMIX Mod) bezogene ist.
Offiziell testet man gerade für das Galaxy Nexus an einem 4.2.2 Release.
Welchen Stand es für alle anderen Geräte hat, kannst Du nachfolgend verfolgen.
https://www.android-hilfe.de/forum/...anclubs-xiaomi-phone.333497.html#post-4522517
Solange es keine offiziellen Sammy Stockroms 4.2.2 für die Samsung Geräte gibt, wird es auch keine darauf basierendes MIUI geben.
Die MIUI Devs sind nicht bekannt dafür, selbst am Android Base zu arbeit, sondern nutzen jeweilige Geräte- oder CM Stock Roms zum kompilieren.
Was sich Inoffiziell tuhen wird wird sich zeigen, miui.polimorph_® ist an seinen Testversuchen mit CM 10.1 4.2.2 (derzeit auf CM 4.1.2) zu kompilieren bisher gescheitert. Er ist seit geraumer Zeit (Häusle Bauer, keine Zeit) inaktiv, von daher von dieser Seite erst mal nichts zu erwarten.
Wer derzeit nicht auf 4.2.2 verzichten will, muss auf aktuelle AOSP-, CM 10.1-, AOKP-, etc; Roms zugreifen und kann den
MiHome Launcher 2.4.0 dazu nutzen um auf diesem Weg einen Hauch MIUI Feeling zu bekommen.
Diese Kombi nutze Ich mit dem SGS und bin mit der Performance reicht zufrieden!
Weiteres Mod gesichtet:[MOD][Samsung Galaxy S3 - i9300] Center Clock, CRT-OFF and MORE....
Diskussion in 'MIUI Mods' started by jimbo77, Yesterday at 4:22 PM.
Hey Guys!
I created a simple MOD for the Galaxy S3 i9300 running on MIUI 3.5.17. The MOD includes:
  • Removed IME Switcher prompt from Notifications, whenever you are typing the system will no longer prompt that annoying switcher.
  • CRT-OFF
  • All Rotations Allowed (90°, 180°, 270°).
  • Centered Clock when in Desktop.
  • Long Press to skip songs with any active Music Player.
Known issues:
  • When I implemented the long press to skip songs somehow it disabled the "Long Press Home Button" to bring the recent open apps, I´m trying to fix it right now, meanwhile if you want to use this mod you can use the custom actions under
    • Settings>Buttons and Keys>Long Press Screen Keys.
      • I selected Menu long press to kill active app and Back Long press to open the recent apps panel.
If you find any additional issue please let me know.
Regards,
Jimbo77​
