Datenbank - Diskussionsplattform MIUI V5 [JB] Rom übergreifend
  • 165 Antworten
MIUI ROM 2.7.20 Preview Changelog
This weeks recommended updates:
  • New (MIONE Plus) voice-activated shutter options, supports taking pictures using your voice command
  • Added bulk delete contacts for Contacts app
  • New online cloud storage for Gallery Albums (see lower section of Gallery UI for more info)
Full changelog will be posted on Friday morning as usual.
Thanks,
Mark & Team
MarkHUK, Yesterday at 7:02 PM
MIUI ROM 2.7.20 Changelog
[Phone]
Optimise calls modify the contact record speed
Optimisation of restore of call records from the backup and recovery
Fix using the original corrugated lock screen, call background deformation
Fix in some cases to delete call records, results in sync problems
[Contacts]
Fix in some cases cannot synchronise address book
[Messaging]
Fix SMS messages unable to send in some circumstances
Fix animated GIF in the drawing page will not play animated GIF
Fix list page, rotate the screen to exit the edit mode / search mode
Fix some PNG images cannot be sent as an attachment
Fix the attachment bar height shows incorrectly
[Lock screen, status bar and notifications]
New improved status bar and notification bar shortcut switch icons (toggles menu, notification bar and list etc)
[Desktop]
Fix on recent tasks to remove a single application, causes an FC error
[Camera] (MIONE Plus Only)
New AF (Auto focus) switch
Added two new real-time filters: Classic and LOMO
New voice-activated shutter, support for taking pictures using voice
Opening zero-delay shutter, fix in some cases leads to FC error
[Themes]
Fix problems with previewing themes not loading correctly
[Gallery]
New cloud albums storage support
Fix received GIF images view via gallery problems
[Notes]
Optimize the search interface, search results, real-time display
Optimise drag notes fluency
Optimise new notes, or move the notes to the notes folder, the notes will be created as a Sticky
Fix the New Memo button on the horizontal screen will appear stretched
Fix in some cases, dragging of notes leads to FC error problems
Fix drag and delete notes pop up input method issues
[Other]
Fix open and close sync switch, did not trigger the synchronisation
Fix synchronisation instructions, In some instances there will be a null returned
Fix to closing the sync switch, changing whilst using Wi-Fi, will cause sync problems
[Alarm Clock]
MI-ONE Plus support for alarms when phone is in shutdown state​
MarkHUK, 47 minutes ago
Reaktionen: Galaxy_S2
Diesen Freitag kommt das 100 erste MIUI Rom,
wenn das mal keinen Grund ist zu feiern!
MIUI ROM 2.7.27 Preview change log
1. Support added for Gallery, File Manager, Sound Recorder, notes and the status bar 720P devices.
2. Added support for 720P devices to use not 720P theme resources.
3. Optimise text selection operations when selecting web content from browser.
Friday marks the 100th week of MIUI ROM
MarkHUK, Yesterday at 9:24 PM
MIUI ROM 2.7.27 Changelog
[System]
  • Added settings for magnifying glass text selection (See Settings > Full Settings > Input settings)
  • Added support for text editor, long press text to display magnifying glass
  • Fix some radio signal issues
  • Added support for 5 new ICS based devices; HTC Incredible S, HTC Desire S, HTC Evo 3D, Meizu MX and Samsung Galaxy Note
[Phone]
  • Optimisation for long-press call records, select the menu for edit before call will automatically pop up the T9 panel
  • Fix the input field at the top of the dialer interface, selecting numbers would open input method keyboard
  • Fix the T9 search in some cases will lead to FC error
  • Fix setting without IP dialing numbers, the bottom of the "add numbers" section will be repeated
[Contacts]
  • Optimise contacts interface horizontal screen issues
  • Optimisation of the group list picture loading speed
  • Fix adding 'New contact' when name is too long causes a memory overflow problem
  • Fix when synchronising Xiaomi account, decoding of some Wi-Fi services leads to FC error
[Messaging]
  • Optimisation of network SMS availability, retransmission failure messages will be prompted when you can re-send message(s)
  • Fix problem in some cases where text messages are not displayed in the SMS sessions list
  • Fix new message, enter recipients, if more than the same number added (with and without prefix) will only show with prefix number
  • Fix system to clear SMS mute tone
  • New (high resolution devices) support for 720P resolution with status bar
  • Fix 720P devices unlock button dropped down too far
[Themes]
  • Optimisation to support 720P device interoperability with non-720P themes
  • Optimisation of listings loading speeds in some cases
  • Fix mix and match wallpaper option displays the wrong information
  • Fix in some cases returning from theme details page to list page results in FC error
  • Fix search results page cannot use the back key to return
[Camera] [MIONE ONLY]
  • New real-time video filters; Classic and Lomo
  • New panoramic photo's now able to save location details
  • Fix pressing shutter, if the phone jitters make cause issues with photos
  • Fix camera store animation ghosting problems
  • Fix in some cases starting more than one camera interface
[Gallery]
  • Added "Show on map" function to image details pages
  • Optimise the image details interface page
  • For optimal viewing of pictures, added quick switch to next picture / photo
  • Fix browsing cloud album(s) in some cases leads to FC error
[Settings]
  • New (high-resolution devices) support for 720P resolution
[File Explorer]
[Browser]
  • Optimisation when selecting web content text
[Sound Recorder]
[Notes]
  • Fix setting note reminders leads to FC error
[Alarm Clock]
  • Fix shutdown alarm clock, default ringtones issue
MarkHUK, Today at 7:29 AM
New MIUI V4 Feature : Huge Font Size
Hi MIUI Fans,
Another amazing feature coming this week is the ability adjust the font size to a HUGE SIZE to increase readability and usability. A very friendly and welcoming feature.
Thanks​
Pele, Today at 11:09 AM
MIUI 2.8.3 Recommended updates (Preview changelog)
Recommended updates:
  1. New, Support to globally effect font-size, see (Settings > Full Settings > Display Settings > Font size) for info
  2. Online version of MIUI Weather (We will check if this includes international support from Xiaomi!)
  3. Notes app now supports inserting contacts and pictures
  4. New system updater reporting to give feedback on MIUI ROM
Further improvements will be made to the Xiaomi Cloud services as well to improve performance and stability.
Full change log will be posted on Friday as usual.
Thanks,
Mark​
MarkHUK, Yesterday at 8:52 PM
MIUI ROM 2.8.3 Changelog
System]
  • Add OTA update feedback options to give details of how you feel about the latest update of MIUI ROM
  • Optimisation of large font mode, Large mode font will arrange icons in a 3x3 grid arrangement
  • Fix Xiaomi Services Framework when network becomes unstable may lead to FC error
[Phone]
  • Fix when system time is adjusted then call cannot make use of the auxiliary menu
[Contacts]
  • Optimisation of MiCloud contacts sync
  • Optimise the contacts batch delete interface
  • Fix SIM card contacts problems displaying new contacts
[Backup]
  • New, added support to encrypt local backups
[Camera]
  • Fix touch to focus, the camera focus may jump to the middle of the screen regardless of where the screen was touched
[Messaging]
  • New, if network SMS activation fails, show display message
  • Optimisation of network SMS activation text descriptions
  • Fix problem when going repeatedly in and out of the same message dialogue, the resulting message list cannot be read
  • Fix status of the horizontal screen, when exiting editing mode the message list page display is not shown in its normal state
  • Fix common SMS sending failure, retry attempt when network is available will still fail to send SMS
[Desktop]
  • Optimise font size support for Huge, Large, Normal, Small text when using 3x3 icon grid arrangement
[Lock screen, status bar, notifications]
  • Add default lock screen music player interface support to adjust volume
  • New variety lock screen 3D support to utilise the Z-axis height parameters
  • Add variety lock screen support for touch / start time variables
  • Add variety lock screen support to access application icons
  • Fix in some cases the clock does not update in a timely manner when device state becomes unlocked
  • Fix in some cases, the "Sync" shortcut switch leads to some problems
[Themes]
  • Optimisation of High-resolution (720P) devices theme support
  • Fix ringtones list page play preview button is not present in some cases
  • Fix in some cases, High-resolution (720P) wallpapers will not load
[Gallery]
  • Optimise the gallery library startup speed
  • Optimisation of Cloud album failed to load retry mechanism
  • Fix long-press gallery editing mode vibration inconsistencies
  • Fix 720P devices, clicking on the picture when displayed shows a fuzzy blue box
  • Fix 720P devices, browse SD card editing mode batch selected text size
  • Fix some frequent FC errors
  • Fix cloud album repeatedly downloaded problem
  • Fix first time loading the gallery application, photographs will show 0 results
  • Fix photo details page, the bottom action bar does not disappear correctly
[Weather]
  • Optimise the new version of the weather application
[System Updater]
  • Added survey poll feedback option to report on ROM stability when updating (Only really useful for Chinese users at the moment)
[Browser]
  • Optimise bookmarks manager, adjustment of bookmark position was not working
[Notes]
  • Add notes support to insert pictures and contact details
  • New editing notes support for text completion using the sliding marker
  • Add increased size for the picture frame
  • Fix in some cases, notes shortcuts errors
  • Fix sliding notes, the interface state is incorrect
  • Fix in some cases, the notes will appear at the bottom of the black lines
  • Fix in some cases, creating new notes folder is unsuccessful
  • Fix removal of telephone notes folder leads to FC error
  • Fix Add reminder failure and also delete operation
  • Fix in some cases, the call notes folder last modified time shows wrong details
[Other]
  • Fix in some cases, due to network instability, may lead to synchronisation FC errors to occur
  • Optimisation of SMS activation, if synchronisation fails, display message
MarkHUK, Today at 7:58 AM
Deutsche Übersetzung folgt sicher Zeitnah / Miui Switzerland » Miui Rom
MIUI ROM 2.8.10 Preview Change log
Xiaomi account contacts synchronisation services at i.xiaomi.com can now make use of advanced features such as Address book recovery function. You can shoose to restore your contacts for up to 60 days in any selected period you choose for the backup. If you mistakenly delete contacts this feature will allow you to easily recover them.
Online MiCloud Albums synchronisation, the release is still undergoing testing and should be optimised in time for Fridays release.
Recommended ROM updates for this Friday:
1. Desktop widgets, improved support for dynamic effects (Such as desktop clock dynamic effects, more about this on Friday)
2. Enhanced MiDrive functions, select from other applications to send files directly to your MiDrive. For example, send songs and pictures to MiDrive, this will also include Contact avatar upload support as well.
3. Improvement to MiCloud Picture sync settings
Solve power consumption issues with constant sync, now has option to only sync when charging, more about this on Friday)
Finally, next Thursday 16th August will mark the 2nd birthday for MIUI, witness a major announcement from Xiaomi. More news to follow!​
MarkHUK, 9 minutes ago
Jetzt auch gelistet: Erstes MIUI Rom auf AOSP Basis
[MIUI][AOSP]CK-MIUI 1.0.1[Only 166mb][cam fixed]
by chiragkrishna / xda & Hier Vorgestellt: [KLICK]
MIUI ROM 2.8.10 Changelog
[System]
  • New Variety framework to control and refresh content or crawl data
  • Add Variety framework supports other applications
  • New virus-scanning function
  • Add a password protection for system
  • Fix setting the ringtone when set to "no" leads to errors
  • Fix sound played only once issues
  • Repair the the Huaping problem
  • Delete confirmation prompt for the data network, convert from Wi-Fi
[Phone]
  • Optimise call recording button will not be clickable (because some devices do not support call recording)
  • Optimise update of attribution number of libraries
  • Optimal adjustment of the proximity sensor when hanging up, also avoid accidental dialing problems when phone is in your pocket
  • Fix Custom attribution information is deleted from call list. Attribution information is not updated (08-07)
  • Fix proximity sensor on some devices when in call leads to FC errors
  • Included in the fix number "," cannot normally match the contact name
[Contacts]
  • Optimise the contact list page account screen
  • Fix bulk deletion, you cannot remove SIM card contacts
[Messaging]
  • Optimise MMS synchronisation, when MMS has been deleted its items will not continue to sync
[Lock screen, status bar, notification bar]
  • New synchronisation status bar displays icons
  • Fix lock screen does not display the lock screen wallpaper when applied
  • Fix status bar is always displayed, showing checking SD card problem
[Desktop]
  • Add dynamic wallpaper support
  • Optimize 720P devices desktop layout
  • Fix problem when name is too long, causes text over lap of adjacent icons
  • Fix RAM cleanup key button text problems
  • Fix in some cases large font used in some applications
[Themes]
  • Add Desktop widget support for richer dynamic effects (eg, screen can have a special animation effects)
  • New clock desktop widget dynamic screen effects
  • Optimise boot animation, so that it can adapt to the screen size
  • Optimise the theme home page layout
  • Optimised time taken to apply wallpaper in themes
  • Fix in some cases, wallpapers may fail to load
  • Fix theme application, memory leak may lead to FC errors
[Camera]
  • Fix screen freezing issue in Camera UI
[Gallery]
  • Add Gallery to support large font mode
  • New cloud image copies only historical photographs simultaneously when charging (if set in settings)
  • Optimise load speed when first opening application
  • Optimisation to improve cloud picture albums when the screen turns off synchronisation speed will be reduced
  • Repair insert / delete / update the database leads to occasional FC error
  • Fix SD card error leads to the Gallery FC errors
  • Fix repeated download of the cloud picture albums
Settings
  • Fix synchronisation button toggle switch problems
  • Remove the font size in the secondary setting switch
[File Explorer]
  • Add support for other applications to select a file and sent directly to MiDrive
  • Optimise MiDrive usage via the file explorer to select the files from third-party programs
  • Optimisation to increase reading progress prompt when loading folders
  • Fix image thumbnails in some cases show the normal size instead of thumbnail
  • Fix renaming of file, you cannot copy / paste / or set as wallpaper
  • Fix cross-draw the screen in editing mode, editing mode will not quit
[Calendar]
  • Fix issues when system language is set to Arabic, leads to FC error
[Notes]
  • Added support for notes to click on links to visit web sites or call phone numbers
  • Optimise the reminder dialog startup speed
  • Optimisation to reduce the update image scaling strategy, if the picture is too large it will be reduced to a screen display size
  • Fix modifying the system language leads to FC
  • Fix adding multiple contacts will lead to problems
  • Repair notes in contacts issues
  • Fix in some cases, adding a contact will result in the pictures displaying garbled (if added to note)
[Other]
  • New addition of the original Internet transfer functions
[Alarm clock]
  • Optimize the alarm to sound, the screen does not automatically unlock when alarm is on
MarkHUK, 56 minutes ago
1. Support for new MIUI Desktop launcher themes
This weeks update will add support for desktop launcher theme support, see video here:
MIUI Free Launcher MIUI
The new system will require theme developers to revise the new format and it will bring more room for some amazing theme options.
2. New version of MIUI video player
New and redesigned MIUI video player, Redesigned every detail of the player interface to bring a better user experience.
3. File Explorer support to Compress / Decompress zip files directly from the application
Further enhanced the File Explorer to allow unzip and zip of files, no other File Manager app available does this currently.
Happy 2nd Birthday to MIUI. Full changelog will be published tomorrow as normal.
MarkHUK, Today at 7:01 PM
Bin gespannt wann das erste Jelly Bean Rom für das SGS III kommt!
MIUI ROM 2.8.17 Changelog and JellyBean!
Hi everyone,
Today is another landmark day, the Google Nexus S and Galaxy Nexus are being upgraded to Android 4.1.1 today!
NO ETA for other devices, we are waiting for Qualcomm in regard to the Xiaomi MI-ONE Plus.
Full changelog follows:
[System]
  • Upgrade Google Nexus S and Galaxy Nexus to Android 4.1.1 JellyBean
[Phone]
  • Optimise the telephone recording interface prompt position adjustment (720P devices)
  • Fix deleted contacts, T9 search can still find contact entries when searching
  • Repair of CDMA mobile phones direct dial the extension number, the call page number highlighted the wrong info
  • Fix a few special circumstances leading to FC errors
  • Fix in some cases, T9 search finds less than actual total contacts
  • Fix some of SIM cards only display the name of one listed contacts
  • Fix contact cannot be deleted when the name contains "," via call log
[Contacts]
  • "Rebuild T9 search index" feature added in the new code to resolve some cases when contacts still cannot be searched
  • New first boot function, first time loading does not display by default SIM card contacts
  • Added on first load of application contacts, you can direct the use of Xiaomi account contacts
  • Optimise large font mode, the phone records will show the effect
  • Optimisation of large font mode, contact details page "Name" and "work info" display
  • Optimisation, no longer display the menu of options for "Group" and "Favorites" page or "bulk delete"
[Messaging]
  • Fixed unusually rare issue, SMS sync results in the amount of traffic used
  • Fix using without SIM card, SMS synchronisation, the system does not automatically go into standby
[Themes]
  • Browsing wallpaper, does not load preview, temporarily displays thumbnail before displaying
  • Optimise the mix and match page layout design
  • Optimise theme details page full-screen preview animations
  • Optimise layout of the icons and fonts in the mix and match interface
  • Fix online resource details page, click continue to the next theme will not get more resources
  • Fix in some cases, online wallpaper application results in failure issues
  • Fix in some cases, application does not work after boot of music application
  • Fix process of the preview loading prompt
  • Fix returning from details page, you cannot fall-back to the correct list of resource items
  • Fix in some cases, the theme details page number indicator will disappear
  • Fix in some cases, the theme details page clicking on the page does not load causing FC error
[Gallery]
  • New video player UI
  • Optimisation on the phone icon and display
  • Optimise slide left to view picture, jumping interface problems
  • Fix problem being unable to play video files from Album folders
  • Fix some of the app cannot use the library to open picture attachments
  • Fix phone part of the OOM error
  • Fix browse pictures page, decoding failure when the picture has been rotated / edited
[Music]
  • New music lyric function, Baidu lyrics support added
[Backup]
  • Added support to turn off backup encryption (see Backup Settings)
[File Manager]
  • New file compression and decompression functions (zip format only for now)
  • Fix selecting to send files to the MiDrive from other apps leads to FC errors
[Browser]
  • Added support for read mode to support bookmark management
[Notes]
  • Optimise support backing up notes including pictures
  • Fix when in edit mode, multi-marquee position displays an error
[Alarm clock]
  • Fix large font mode interface display problems
MarkHUK, 17 minutes ago
MIUI ROM 2.8.24 Preview changelog
This weeks update will focus on detailed enhancements of the ROMS exsisting features
1. New notes layout grid options, List view and Grid views, original list view or new side-by-side grid view of your notes
2. New Free Desktop Launcher Support folder
After last weeks trial run, now supporting folder support for apps
3. Desktop optimisation and tuning, opening from lockscreen etc.
Full updates published on Friday as usual.​
MarkHUK
MIUIAndroid Site Owner & Server Admin
Translator of MIUI ROM into English since September 2010 & various other mods / hacks
Donate if you want to: http://bit.ly/9hWYa6
MarkHUK, Today at 12:02 AM
MIUI ROM 2.8.24 Changelog [ICS & JB]
[System]
  • ZTE U970 (GrandX)
  • New support for Shutdown alarm clock
  • New LT18i base upgrade to 4.1.B.0.587
  • Fix incorrect name for network and some other network problems
  • Optimisation of the application installation interface
  • Optimisation of the desktop permanent memory, to avoid Desktop automatically exiting memory
[Phone]
  • Fix setting call forwarding, press the Backspace key will repeat the last settings
  • Fix call recording issues
  • Fix telephone number is too long will cause FC error
  • Fix some device hardware lib issues
  • Fix large font mode, vertical zoned answer are does not display correctly
  • Remove a CDMA phone setting for fixed dialing
[Contacts]
  • Optimise large-font mode, contacts, call history display
  • Optimise large font mode, add a desktop shortcut for a contact
  • Fix problem unable to delete USIM card contacts
  • Optimise favorite contacts ordering by alphabetical a-z or z-a functionality
  • Fix airplane mode, you cannot add new SIM card contacts
  • Fix when deleting account, the account list page wil now refresh
  • Fix problem when you cannot import contacts vcard (HTC Sensation)
  • Fix "Show SIM contacts" switch is turned on, but on boot is not displayed in SIM card contacts
  • Fix SIM card account under displaying new contacts on the SIM card, contact list does not update
[Messaging]
  • Fix QQ contacts, when deleted from SMS session, will still displayed in the system SMS
[Desktop]
  • New MiHome Free (Launcher)
  • Support for folder multiple selection (select the application folder that is generated can batch edit to increase or decrease the application folder)
  • New MiHome Free menu items, including desktop default layout restore and exit free desktop mode
[Themes]
  • Support added for quick preview of theme wallpaper, press preview to see a quick view of how it will look on your desktop
  • New distance sensor to prevent misuse (eg, mobile phone in your pocket making accidental calls)
  • Fix Variety lock screen time components use different widths, components will show incomplete or not centered
[Gallery]
  • Added support to set picture as the desktop and/or lock screen wallpaper
  • Optimisation to enhance the gallery switching between Home / Album list page / picture list page loading speed
  • Optimisation to improve in some cases picture decoding success rate
  • Fix phone 480 * 800 resolution, online MiCloud album folders show half the image
  • Fix browsing pictures, when sliding between left to right created a jitter effect
[Desktop]
  • The desktop widget, fix in some cases, the animation shows only half
[Music]
  • Layout optimisation and adjustment for folder and album pages
  • Page layout optimisation for 720P devices
  • "Play up" optimise adjustment algorithm
  • Fix in some cases, local songs being played are always displayed in buffering... state
[File Manager]
  • Fix problems opening file manager leads immediately to exit and other FC errors
  • Fix when SD card is inserted, the Browse page will be updated
  • Fix cannot move or copy files between internal / external SD card or MiDrive
  • Fix browsing folders when attempting to use ZIP compression
  • Repair return to list jitter problems
  • Fix when opening the next level directory, the list is does not refresh causing some problems
  • Fix refresh of page, the list jumps to the top
[Browser]
  • Added support for reading list folder to delete bookmarks
[Notes]
  • Images in third party applications will now provide option to send image to notes application
  • New grid view, view in traditional list of side-by-side (Grid view), changeable via Settings menu option
[Video]
  • New video vertical screen playback mode
  • Optimise display effect when dragging the progress bar in the video player
  • Optimised video playback when screen brightness setting is adjusted, playback will automatically restore the system brightness settings
  • Fix in 800 * 480 and 960 * 540 resolutions, video playback progress bar UI display dislocation problems
MarkHUK
MarkHUK, Today at 6:52 AM
[ROM] [Sammy] NEW-xiMix-Miui_V4_[ICS] 2.8.24_SGS3_Deutsch-Englisch
von ximi_zH , Heute, 02:55 PM bei MIUI.CH veröffentlicht
Downloadlink: http://dl.dropbox.co...miui_2.8.24.zip
Näherses zu dem Mod bei NEW-xiMix-Miui
Wer Lust hat dieses Rom vorzustellen, kann dies gerne tun!
[ROM]*2.8.24*HYBRID_TMT_MIUI_1.0 AROMA INTERNATIONAL Codename "RAYGLOBE" 08/24/12
Thread By: acer73 / xda
Download Rom: Multilanguage pack
https://www.yousendit.com/download/T...Tk1nYU4zZU1UQw
Ver. 1.0
- Added all Samsung app + Touchwiz
- Added all sounds from Samsung
- Awesome Aroma installer with app, kernel, modem, option
- Added Beats audio support
- Kies support
- add Multi Csc
- Added 720p stock icons
- Tweaks for render UI with GPU
- Many tweaks for better battery life
- Zipalign apps at boot
- Added 3-way reboot
- MIUI Launcher redraw is minimized
- Increased touchscreen sensitivity
- Tweaks for smoother scrolling and minimized duration of black screen before call screen appears
- Fixed standby battery drain
- Supercharged support
- Jelly bean wallpapers
- More to come...what you want ...?
[ROM]*2.8.24*HYBRID_TMT_MIUI_1.1 AROMA INTERNATIONAL Codename "RAYGLOBE" 08/24/12
Download Rom:
Ver. 1.1 - Upload
Ver. 1
Multilanguage pack
Ver. 1.1
- New base (only original miuiandroid.com files)
- Removed seclauncher2 from galnet instead installed this http://forum.xda-developers.com/show....php?t=1691957 (all credit Toss3)
- Removed some Galnet Jar
- New build.prop
(credit to gh.rohit for some lines)
- New script in init.d (
no bolt_siyah or voltctrl)
- Update Supersu
- New hosts file for remove ads
- Removed CSC (android.phone.error in v.1.0)
- Bravia engine and Beats Audio
- Experia Album
- One file multilanguage
Ver. 1.0
- Kies support
- add Multi Csc
================================================== ========[/QUOTE]
MIUI ROM 2.8.30 Changelog
1. File Explorer support to decompress RAR files
2. Optimisation of contact chooser (picker)
Send SMS messages to a contact, you can now directly select thw most recent contacts, groups or favorites.
3. Recent task list support to enter application process details
You can now long press the clean up memory key to directly open the list of running tasks, this is to meet the needs of some ROM users who have asked about this functionality.
Significant updates to improve the Xiaomi MI-ONE Plus camera quality, noise reduction and image sensor optimisations
Finally this week, i.xiaomi.com will also have many improvements including functionality to delete photos from albums on the MiCloud storage system. Other functions and optimisations have also been made to make the user experience significantly more enjoyable.
Full changelog will be posted on Friday as normal.​
MarkHUK
MarkHUK, 13 minutes ago
Ich, Android-Hilfe.de oder die Entwickler/Publisher der ROM oder Mods,
übernehmen keine Haftung für mögliche Schäden an eurem Gerät!
Ihr seid daher für euer Handeln selbst verantwortlich!!!
Merkmale: dieses MIUI Mod basiert auf China Stockrom​
Version: 2.10.12
MD5: b358b640d69902eb18de8bea07f727e7
Version: 2.9.28
MD5: 1d372b168ba9bda92db2943e9873d3d5
Version: 2.9.21
MD5: a63be67e275d5dd6abdc2f7cd6069817
Version: 2.8.31
MD5: e81e208f606ee4bba3196802404dad76
Version: 2.8.24
MD5: 89dd96cdc9401a2a36d96b53f312706b
MIUI ROM 2.8.31 Changelog
[System]
  • Optimise LT26i to new base ROM version 6.1.A.1.58
[Phone]
  • Added support for local IP Calling
  • New, customise the reminder times for missed calls, 1, 2, 3, 5 or 10 times
  • Fix during call, moving phone away from ear, the screen does not light up
[Contacts]
  • Optimise contact selection for sending SMS, you can now directly select the most recent contacts, groups or favorites.
  • Contact selection interface will no longer appear to optimise export of contacts to SIM card contacts
[Messaging]
  • Optimise MMS maximum picture size support to 1920x1920
  • Optimisation for MMS failure to send message, can now manually re-send
  • Optimisation when switching to Xiaomi account, will be prompted about sync of SMS items found in other accounts
  • Fix in some cases the SMS popup prompt does not correctly display contact information
  • Fix problem of none-mute state, the caller cannot be heard
  • Fix call interface, the screen does not respond problem
  • Fix in some cases, lock screen lights / animations become stuck
[Desktop]
  • New "Recommended" folder icon with theme changes
  • New MiHome Free desktop user prompts to use the functions
  • Add shortcut to load running tasks by long-pressing on on clean-up key in Task management
  • Optimise the desktop icon shadow and font size
  • Optimisation of third-party default icon for some applications
  • Optimise response time when icons are dragged to the edge (new screen) on desktop
  • Optimise folder animation and position
  • Optimisation of folder renaming operation
  • Optimisation, un named folders will be shown as 'untitled folder' if no name is provided for the folder
  • Fix in some cases, MiHome Free desktop loading is unsuccessful
  • Fix when adding a desktop widget, insufficient memory may lead to desktop FC errors
  • Fix problems in MiHome Free desktop editing mode, menu items are unavailable
[Themes]
  • New, Local ringtone support to sort by time added
  • Optimised wallpaper crop functions
  • Fix reloading page issues after applying new theme
  • Fix in some cases, replacement fonts does not prompt to restart the phone leading to garbled interface font issues
  • Fix HTC Desire S, changing part of theme module resulted in problems
  • Fix in some cases, Wallpaper details page from background task to foreground leads to FC error
  • Fix in some cases, online wallpaper details page thumbnail does not display correctly
  • Fix in some cases the theme details page leads to some FC errors
  • Optimise drop-down list styles in recommended theme page
  • Fix image preview problems
[Camera]
  • Optimisation to significantly improve the image quality on the Xiaomi MI-ONE / S+. Contrast and noise issues
[Gallery]
  • Optimise MiCloud albums, only sync when charging, switched setting to Xiaomi account page
  • Fix lock screen wallpaper deformation issues
  • Fix use of front camera will automatically flip to rear camera issue
  • Fix download list occasionally shows as half-grey
[Music]
  • Optimisation to improve the album cover artwork and lyrics quality (in cooperation with Baidu music)
  • Optimisation when music is playing, when a call is received music playback will be automatically paused
  • Fix being unable to bulk download online music
  • Fix in some cases pressing the return key after entering online music may cause FC errors
[File Explorer]
  • Added support to extract .RAR format files
  • Optimisation of decompression of archive when extracted will create a new folder of the same name as the archive
  • Fix downloading pictures from MiDrive may cause some display problems
  • Fix FC error concerning opening SD card in File Explorer (Manager)
[Browser]
  • Optimisation of the tab management interface
[Sound Recorder]
  • Optimise audio file support and background playback
[Notes]
  • Optimisation of grid pattern and quick dragging of notes fluency
  • Optimise when adding notes to create a folder, it is not required to input the folder name for the note(s)
  • Optimisation, add prompts on how to use new Notes features (first time use)
  • Optimise notes with pictures, now show picture preview in grid view mode
  • Fix the grid view stick notes folder, first notes are update with content changes
[Other]
  • New variety lock screen frame support mechanism to support intercept touch events
  • Fix variety lock screen framework in some cases conditional parameter command does not work
  • Fix URL correction for i.xiaomi.com
  • Fix Xiaomi account page does not update when theme is changed
MarkHUK
MarkHUK, Today at 6:55 AM
Q
MiSeRy
MiSeRy
Android_Noob.
