WanamLite ICS XWLP8 V11.1 Android 4.0.3 Battery friendly Blue ICS & Stock Themed
  • 49 Antworten
Kjetal
Kjetal
Mitglied
10.214
http://wanamlite.com/forum/index.php?topic=9.0
Changes Log :
  • Removed SocialHub (available on Samsung Apps patch V2)
  • LP6 Modem (reported as battery friendly by many users)
  • TwLauncher INCLUDED
  • Improved Battery life
  • Disabled software auto update
  • Removed "NO SMS an Call logs", this feature is Built in now
  • Stock LP8 Email App (this will wipe your email app data)
Video of V9.3 (Thanks to
clicheboy) :
Features :
Based on latest leaked ICS.
Deodexed & Rooted & Zipaligned.
Updated Google Apps & Facelock
Blue ICS themed (Themed apps & Numeric battery).
No SMS on call logs.
Unlimited SMS recipient list.
No SMS to MMS convert.
15 Status bar toggles.
Tweaked Speed & Battery life.
Disabled scrolling cache.
Removed all bloatware.
Large APN list.
Rapid GPS lock.
Enabled CRT TV & Built In SIP.
Enabled Hardware acceleration.
Added Trebuchet & Apex & Nova launcher.
Numeric battery.
Aosp Email/Exchange/Clock.
No incremental ringtone.
Disabled Noise suppression.
ICS Lockscreen.
Download & Changes log:
If you use a stock Exchange account, you must wipe your email & exchange data.
If you have any Market issue :
  • Open the stock browser, and go to Android market web site it will ask you to use Market app, select it and go ahead (Thanks to Ayman).
  • If the above solution doesn't work, remove your Gmail account, reboot and add it again.
DO NOT CHECK "Force GPU rendering" on Developer options as it may causes some issue (Lock wallpaper...)
If you get any Gmail issue, clear app data.
You can update your launchers here : Trebuchet & Nova & Apex
Samsung apps available here.
Installation (Must have CWM kernel like Cf-root) :
Copy my Rom to internal sdcard
Backup, backup, backup
If you came from a Gingerbread or AOSP Rom, you MUST WIPE your data
Flash my Rom from recovery
Reboot & enjoy (
and let the phone to boot up, at least 5 minutes required for media scanner to finish)
Some simple tips to get the best of your battery life :
Call *#9900# and disable Fast dormacy
Disable auto sync for accounts
Disable GPS (and wifi gps)
Disable auto backup of Gmail account
Set wifi sleep policy to "when pluged in"
Set brightness level to automatic
Disable motion
Check your apps settings and disable useless background sync
Disable transition animations
Thanks to :
@chainfire, @CM team, @Sammobile, @JesusFreke, @Brut.all, @LegendK95, @Vertumus, @Ficeto, @Lidroid
Screenshots :
Reaktionen: trayzor, kiriakos1963, Simuur95 und eine weitere Person
v9.5 ist on.
chika schrieb:
9.5 Basiert auf LP7, wenn ich jetzt nicht alles durcheinander bringe war das doch die Beta vor der LPQ oder?
Warum diesen Schritt zurück?
Lg SouLLesS
Die DXLP7 scheint wohl eine Offizielle für Indonesien zu sein.Allerdings Ist da wohl,außer Englisch,keine europäische Sprache drin.
Lässt sich Deutsch irgendwie nachinstallieren?
Ansonsten dann doch PureICS...
Lg SouLLesS
9.8 ist online. Vielleicht kann ein Mod das mal ändern. Danke.
Jetzt auch in Deutsch.
Titel geändert und Link hinzugefügt... ;)
Reaktionen: Duffman
Ich habe die ROM (v9.8) seit gestern drauf. Läuft sehr gut und flüssig.
Wenn ich jetzt noch meinen tierischen Akkuverbrauch in den Griff kriegen könnte, wäre ich vollends zufrieden.
Momentan ist ja schon die 9.9 draußen, aber es kränkelt unter dem selben Bug wie fast alle aktuellen Custom Roms auf Basis von LP7 oder LP2, nämlich das Flackern der CRT OFF Animation. Merkt das keiner der Modder?
Ich habe inzwischen ebenfalls auf v9.9 upgedatet. Der Bug ist nocht da, stört mich aber nicht weiter, solange der Rest flüssig läuft - das tut er mit der ROM.
Die 9.9 lief auch bei mir sehr gut!
Mit der neuen V10 tritt jedoch der "2 SMS" Bug nicht mehr auf ;) da ich mysms nutze hab ich noch keine Update wie die Go SMS nutzer ;)
Hab einfach drüber Installiert und danach den Cache geleert.
muss auch sagen das die 10 einfach tutti läuft, hab se seit gestern drauf und hatte noch nicht einen bug entdeckt und das beste ist, seid 12 stunden etwa 25% stromverbrauch bei relativ intensiver nutzung also absolut empfehlenswert......:rolleyes:
V10 läuft bei mir auch im Grunde perfekt. Alle Gedanken an CheckRom v6 sind verflogen.:smile:
Beim entfernen der 'Bloatware' war Wanam wohl etwas zu gründlich. Wenn man in der Gallerie bei einem Bild auf Edit klickt, gibts einen FC, weil er das Fotobearbeitungsprogramm entfernt hat.
Lässt sich aber leicht beheben in dem man die PhotoRetouch.apk nachinstalliert.
Könnt ihr Kontakte löschen oder bekommt ihr einen FC? Habe momentan die Stock odex von wanam installiert, aber mir geht der Samsung Lockscreen auf den keks....
Ja, ich hab auch nen FC wenn ich einen Kontakt lösche. Mich stört das aber nicht weiter, da ich alle Kontakte immer online bei Google bearbeite. Ist aber bis jetzt der einzige mir aufgefallene Bug.
@ Kjetal hier die neue thread überschrift :
[ROM][27Mar][Android 4.0.3]WanamLite V10 XWLP3 Clean & Stable Blue ICS & Stock Themed
Greetz M@sta ;)
@Kjetal,
ich war mal so frei... ;)
Und das nächste Update:
[ROM][29Mar][Android 4.0.3]WanamLite V10.2 Final LP3 Clean & Stable Blue ICS Themed - xda-developers
  • It’s a FINAL update Based on my deodexed XWLP3 (Blue ICS & Stock Themed)
  • Fixed 15 toggles buttons TEXT (Thanks to Препод for his idea)
  • Decrease Home button lag on ICS lockscreen
  • Fixed BLN support for 3rd part Apps
  • Updated Google apps
  • Added AOSP Google Gallery & Calculator
  • Extweaks compatible (Siyah kernel V3.0 beta 7)
  • Added stock Calendar (remove aosp one, it causes FC)
  • Contact edit/delete fixed
  • Fixed Google plus “android acore FC” (Thanks to chemija)
  • Tweaked internet speed
  • Waste characterization enabled (For Rom cookers: PLEASE credit or let me know if you use any file of my rom, otherwise you will be reported)
Die Version 10.2 läuft wohl bei vielen nicht so rund. Auch mein Kalender wollte nicht mehr Synchronisieren!
Dank Nandroid bin ich wieder auf 10.0. Ist die beste ROM die mein S2 je gesehn hat!
