WanamLite ICS XWLP8 V11.1 Android 4.0.3 Battery friendly Blue ICS & Stock Themed
  • 49 Antworten
hab bei whatsapp keine vibration mehr nur ton, ist das bei euch auch so?
vibration ist aufjedenfall an !
also, habs gerade getestet, vibration geht nur wenn sie auch in den systemeinstellungen angeschaltet ist.....
WanamLite ICS XWLP4 V10.6 Android 4.0.3 Stable Blue ICS & Stock Themed
  • Based on my deodexed XWLP4 (Blue ICS & Stock Themed)
  • Cf-root LPS kernel
  • CRT TV animation & SIP (you can disable it by disabling windows animation or change animation scale)
  • 15 Toggle buttons (fixed scrolling speed + fixed wrapped text)
  • Removed Samsung apps (available as separate patch)
  • Removed TW launcher (Needs maybe more bloatware dependencies, flash my sammy apps package if you need it)
  • Apex or Nova launchers
  • Fixed Camera lag on first launch
  • AOSP keyboard (updated Android 4.0.4)
  • Removed Google Plus (Available on the Market)
  • Youtube with HD over Wifi & 3G
  • Unlimitted SMS recipient & Enabled Automatic encoding on messages
  • Camera without sound
  • Phone with Call Recording & No Incremental ringtone
  • Noise suppression enabled
  • No SMS on Call logs
  • Tweaked kernel
  • Tweaked internet speed
  • Battery life improved
  • ICS Lockscreen
  • Numeric battery
  • Fixed Sdcard issue (Thanks to Chainfire)
  • Fixed USB Storage mode (flash this patch if you want MTP)
  • Stock Clock (themed icon)
  • Stock Calendar (themed icon)
  • Hacked Email & Exchange (Updated from Android 4.04)
  • Disabled Scrolling cache
  • Disabled Home button Lag
  • Enabled Logger
  • I/O scheduler set to Default
  • Lower System & apps compression
  • Updated Google apps
  • Speed slightly boosted
  • Possible fix for Market auto install apps (i can’t test it).
  • Waste characterization enabled (For Rom cookers: PLEASE credit or let me know if you use any file of my rom, otherwise you will be reported)
How to install :
  • Copy my rom to internal sdcard
  • BACKUP BACKUP BACKUP
  • If you came from a Gingerbread or AOSP Rom or if you use Stock Email, you MUST WIPE your data
  • Flash my rom from Recovery
  • Reboot & enjoy, let the phone to boot up, at least 5 minutes to let media scanner finish.
Download link : You can Update from V10.4 or V10.5 without Wipe, A WIPE IS RECOMMENDED IF YOU COME FROM OTHER ROM.
V10.7 ist online. :)
wie immer gibt es keinen changelog,da das der erste build auf der basis einer neuen stock fw is ;) was ich persönlich schade finde. was aber trauriger ist,ist die tatsache,dass der te den thread nicht aktuell hält :(
kann sich bitte ein mod darum kümmern :)?alternativ würde ich das übernehmen,wenn ich einen neuen thread dafür aufmachen darf ;)
link zur v10.7:
http://wanamlite.com/2012/04/10/wan...4-0-3-stable-blue-ics-stock-themed/#more-1316
Thread-Titel aktualisiert... ;)
@trayzor,
du kannst gern Kjetal, den TE, darauf ansprechen, ob du es übernehmen kannst, falls er es abgeben möchte...
hmm,der ist doch selbst aktiv hier,mal sehen,ob es reicht,wenn ich ihm ne pn nächstes mal schreibe ;)
Hab ne frage liebe community.
Ich bin mir langsam nicht mehr sicher ob es an einen App liegt aber ich habe einen Kack Problem mit allen Roms außer stock LPQ. Ich kann nach bestimmten Zeit (ca. 10 std.) kein WLAN / WiFi Direkt mehr einschalten. Der "schalter" bleibt hängen und kann nicht mehr betätigt werden. Es wird auch kein WLAN eingeschaltet. Wenn ich dann das Display ausschalte hängt sich mein SGS2 einfach auf. Nach neu starten ist alles gut. Und paar Stunden später wieder das gleiche.
Ich flashe jedesmal mit Full Wipe.
Da ich zur zeit WanamLite habe frage ich erstmal hier.
Der steht auf dem Markt und verkauft Eier. Und der ist nicht nur für einen Thread verantwortlich sondern hat hier noch mehr zu tun, es wäre ja auch kein problem mich über ein Update zu Informieren und um eine Thread änderung zu bitten ?
@misui99 : den bug gibts/gabs wirklich in vielen roms. kann dir nur als alternative das go switch widget empfehlen. da kannste dann paar mal wild auf den wlan-schalter drücken und danach funzt es auf jeden fall. ich hab derzeit keine probleme mit dem toggle ;)
@kjetal : wenns nur um die letzte änderung ginge,könnte ich deine aufregung verstehen. aber dem ist nicht so.. ;) keep cool, as said, next time schick ich ne pn raus ;)
v10.8
http://wanamlite.com/2012/04/13/wan...droid-4-0-3-stable-blue-ics-themed/#more-1352
Change Log:
  • Based on my deodexed XWLP7 (Blue ICS)
  • LP6 Modem
  • LP7 Cf-root kernel
  • Fixed SMS logs on Call
  • 5 lidroid Toggles per page
  • Few UI improvements
  • Disabled BLN (if you need it flash Siyah or other kernel supporting it)
  • Unhidden Gallery3D
  • Hacked Stock Email App (It will wipe your email data)
  • Added Full Arabic support (تعريب قوائم)
  • Other things i don’t remember now
übrigens,so nebenbei : der siyah-kernel hat heute auch noch n nice update gekriegt @misui99. zitat:
  • updated the build script a little to fix the module loading issues (which is, by the way, the main root of wifi toggling issues)
have a try :)!
http://www.gokhanmoral.com/gm/2012/04/13/siyahkernel-v3-1rc2/
Servus,
ich habe die 10.7 installiert, kann ich die 10.8 ohne wipe installieren? Einfach gezippte rom auf sd karte kopieren und dann "Flash zip from SD-Card" auswählen?
Danke im Voraus
jap du kannst es direkt drüberflashen ;)
Changes Log (10.8.1):
  • Back to Stable updates of Nova & Apex launchers
  • Added Hacked AOSP Email (Stock one doesn’t work for some users, maybe because of “No SMS o Call logs” mod)
  • Fixed MMS for Arabic users
WICHTIG! das update ist keine vollständige rom! ihr MÜSST also zuerst die 10.8 installieren. danach das update drüber bügeln ;)
http://goo.gl/vDLMI
Reaktionen: Horst2k
Trayzor wird den Thread von mir übernehmen , alles weitere nachher.
Habe mir gestern die 10.8 und 10.8.1 installiert. Kann es sein, dass diese inzwischen von wanam zurückgezogen wurden? Die Version 10.8 und 10.8.1 ist nicht mehr auf seiner Webseite. Aktuellste Rom ist laut Webseite 10.7!
Version 10.8(.1) wurde entfernt wegen zu vieler Bugs.
Aktuell ist seit heute 10.9.
Funktioniert tadellos bei mir.
also wie kjetal sagte,werde ich den thread übernehmen (neu strukturieren und so), bis dahin poste ich hier einfach weiter.
die 10.8er ist in der tat verschwunden. für leute, die die arabische unterstützung nicht brauchen, wird ein upgrade auf 10.9 empfohlen.
http://wanamlite.com/2012/04/15/wan...droid-4-0-3-stable-blue-ics-themed/#more-1381
Changes Log (10.7 -> 10.9):
  • Blue ICS Themed only (Sorry stock theme users, i will provide it from next FW)
  • Stable Apex launcher (Removed Nova,you can get it from Market)
  • SMS/MMS with sent time on logs
  • Fixed “No SMS on Call logs”
  • LP6 Modem
  • Google Music (Compatible with ICS Lockscreen)
  • AOSP Calculator & LiveWallpapers
  • Updated Google Apps (Gmail, Maps, Street)
  • Updated stock Google Play Store (I don’t recommend to use the modded one for restricted country, Market Enabler works great in my country)
  • Battery life slightly improved
  • Fixed a minor “Bluetooth” lowcase on the Dialer
  • No Full Arabic support (Only Arabic built-in support read/write)
THIS BUILD IS STABLE AND HIGHLY RECOMMENDED FOR V10.8.x users who don’t need Arabic support.
http://goo.gl/u4Bth
konkret hat sich zu 10.8. also folgendes geändert:
oder anders ausgedrückt : abgesehen von der basis ist jede menge dazu gekommen:cool2:
WanamLite ICS XWLP8 V11 Android 4.0.3 Stable Blue ICS & Stock Themed
http://wanamlite.com/forum/index.php?topic=7.msg7
Da wanam sich nun extra ein Forum eingerichtet hat, werde ich in Zukunft darauf verzichten, direkt auf die Downloads zu verlinken und stattdessen immer auf das Forum verweisen :)!
Changes Log :
  • Base on XWLP8 (OPSLP4 CSC)
  • LPS Modem
  • Blue ICS & Stock Themed
  • Stock Music Player (Google one available on the Market)
  • Added TwLauncher
  • Stock LiveWallpapers
  • Added Social Hubs
  • Other things i don't remember
verstehe den trend irgendwie nicht..mischmasch aus aosp und stock :( naja die hubs werden mal direkt gefreezet.
