Dr.Franz
Gesperrt
- 616
Wer ICS genießen will sollte sich das hier mal ansehen
Neue Version V3.3
• Changelog: version V3.3
• XWKL1 Base
• CSC XAKL1
• Kernel ☼Siyah 2.6.6☼
• Deodexed+Rooted+Zipaligned
• Fancy Rotation Animation
• ICS Transition animations
• JkayDeluxeSettings v13.4.1
• Market 3.4.4
• Phone Call recording
• New Call In and out Animation
• Call Full Screen
• Remover SMS in Call Log
• Mms.apk glass
• Mms.apk no MMS auto-conversion -200 contacts per SMS.
• Hacked Camera.APK for better audio quality
• Camera Hack take pictures by pressing VOL + / -
• User Agent Switch In Stock Browser
• Gtalk - without video call
• Add Sony Bravia Engine By ykk_five
• Add Google keypad ICS
• GPS fix for Asia
• Build.prop tweaks
• tweaks 3G
• SIP WiFi+3G
• EFS Auto Backup
• init.d Support
• Add language Vietnamese
• Themes Changer:
+ New DigitalClock widget Mod by My
+ New GoogleQuickSearchBox - by My
+ New themes ICS TwCalendarAppWidget, Clock , Calendar, Myfile, video player. Thanks to Vertumus
+ Changer smiley Icon of Contacts
+ Changer Text Color Theme Clock of Jkay Deluxe settings
+ New Icon Changer
+ MOd text Color Keypad
+ New BootAnimation
• Add app :
+ DarkyOTA (Install and uninstall system apps)
+ --VK--Home Launcher
+ Fancy widget Pro
+ Homesmack
+ Rootexplorer
• Jkay Features in v13.4.1 (bold is added since v13.3.9):
* Fixed 2 minor bugs (dimming changed to 5 and default brightness profile is again the Normal profile)
* Fixed 2 minor graphical bugs (Themed signal strength did not always go green at boot and when roaming)
* Split up the status bar option 'Theme icons' to 'Theme connection icons', 'Theme clock', 'Theme text' and 'Theme battery level'
* Added 'Add date to clock' toggle for always showing the date on the status bar.
* Moved Battery level text a few pixels to the left
* Confirmation toggle for Backup/Restore and Reset
* Added 2 more Brightness profiles (now 3 of the profiles require a custom kernel for the darkest setting, one is a special Test profile that can be used for testing if the kernel supports low brightness values)
Note: After Restoring Deluxe Settings in v13.4.1 please change your Brightness profile to the one you had in v13.3.9!!
Download Non Wipe vesion:
http://www.multiupload.com/9W40OAJVG9
Full wipe vesion
http://www.mediafire.com/?by622a6pstnh7so
List samsung app remove:
http://forum.xda-developers.com/showthread.php?t=1377069
Neue Version V3.3
• XWKL1 Base
• CSC XAKL1
• Market 3.4.4
• Call Full Screen
• Mms.apk glass
• GPS fix for Asia
• Build.prop tweaks
• tweaks 3G
• SIP WiFi+3G
• EFS Auto Backup
• init.d Support
• Themes Changer:
+ New Icon Changer
+ New BootAnimation
• Add app :
+ Fancy widget Pro
+ Homesmack
+ Rootexplorer
Full wipe vesion
