TurkbeyRom V37 SE No Wipe JkayMod(13.6.4)-2.3.6 XWLA4 NEAK KERNEL 1.3.3X ONLNE
  • 1.678 Antworten
FireS24208
FireS24208
Stamm-User
361
TurkbeyRom V37 SE No Wipe JkayMod(13.6.4)-2.3.6 XWLA4 NEAK KERNEL 1.3.3X ONLİNE
V37 SE
Pda : I9100XWLA4
Phone : I9100 -XXKP8
Csc : I9100F0PKI1
Added new framework
notification bar clock and date blue ( Jkay Theme Options )
Added Sony Bravia Engine Mod ( New Gallery.Apk )
Lockscreen notifications such as missed calls and messages screen changed
Changed some system icons
New SystemUi.Apk
Update go lancher 2.80 final build 94
Added Swype to remove notification
http://www.youtube.com/watch?feature...&v=7BB5p-xYMdM
Extra New SystemUi jkay İcon Mod Thanks Chatrat
mDNIe Tune Screen Mode
Program to edit something which dynamic profile settings
I offer you some information for consideration. I decided to dig a little bit so I \ to play with the settings of the image display of our apparatus. As it turned out, everything is relatively easy to work with us and, as we know, through technology mDNIe (mobile Digital Natural Image engine), Samsung-developed th for its LCD TV and LED TV products.
Attention! Settings are created for the profile of "dynamic" are applied to the UI and work as usual. In "Camera", "Gallery", "Movie Player", "Visibility in the street" configuration data are not applicable, they require editing of other files.
After installing the rom, set Settings-Display-Dynamic-Screen.
INSTALLATION
Wipe data and factory reset
Wipe the cache
zip install from sdcard
turkbeyromv36se.zip install
Achtung: Da System-Dateien verändert wurden, wird ein Fullwipe empfohlen.
Download von der Rom und Pulldown StatusBar sowie auch der Standart Dialer
Wuala.com
Hier ist noch ein Link für ein Video zu der Rom
TurkbeyRom JkayMod N º V37 SE (13.6.4) -2.3.6 Núcleo 1.3.3X Neak XWLA4 - YouTube
This is my web site
SGS 2 Rom Geli
Link XDA:TurkbeyRom V37 SE No Wipe JkayMod(13.6.4)-2.3.6 XWLA4 NEAK KERNEL 1.3.3X ONL0NE - xda-developers
Master Gee81 hat ein paar Dialer Themes bereit gestellt
[THEME] Universal BlackColors by Eladios Updated v4 fully supports the new Jkay 13.2
Ics themed dialer for turkbey rom!
Danke dafür gehen an Master Gee81
Hier sind noch mehr Themes von Usern von XDA
Dialer themes for this rom ( Thanks grgsiocle )
http://forum.xda-developers.com/show....php?t=1382057 ( Thanks Siberian Tiger )
THE SPACE ALIEN ULTIMATE COLLECTION
( Thanks SPACE ALIEN )
Thanks dan96815
(Extra)
LG
Reaktionen: faker, anime, pjponal und 27 andere
Werde ich mal testen.
Vergleich zur chekrom wäre interessant.
Sent from my GT-I9100 using Tapatalk
Ich denke nicht das die MOds das zulassen ?!
Mal sehen ...
Gruss M@sta
Denke mal schon da er sie ja überarbeitet hat!!!
Reaktionen: muro58
Es geht ja um diese 2 Sachen : New Applanet , Blackmartalpa ,
und die stehen immernoch oben mit drin ... schau mal .
Sonst ist nichts gegen die Rom zu sagen ...
in dem zip sind die files nicht mehr drin
Ahh Ok ... wusst ich nicht ,,. weil es immernoch oben mit drin steht ...
Dann ist ja gut :cool2:
Bei Downloads hat er geschrieben das er die Apps Removed (entfernd) hat!!
Und er hat sich bei den Dev´s von XDA entschuldigt
Hm...finde ich ja net so toll, dass der dev solche apps in der rom hatte, wenn diese anscheinend nicht legal sind(kenne die apps net) aber dennoch sehen die Screenshots echt hammer aus...denke testen werde ich dennoch mal.
Sent from my GT-I9100 using OmegaRom v5.0
Dann nimm doch bitte auch den Screenshot raus, wo die Markets zu sehen sind.
Ist ja schön und gut dieser Thread aber muss man wirklich jedes Bild vom XDA Thread übernehmen ?
Erstmal lange runter scrollen damit man überhaupt sieht was da drin ist. 2 kleine Bilder hätten auch gereicht....
Reaktionen: Drielander
Habe es noch mal bearbeitet ist es jetzt besser oder soll ich noch mehr weg nehmen.
Kann bestätigen, dass Applanet und Blackmarket nicht mehr in der Zip drin sind...ansonsten geiles Rom...
Wo ist der Unterschied zur Criskelo Rom? Außer dem Warez?
Von meiner seite aus spricht nichts dagegen den Thread nun zu lassen wenn die Apps entfernt wurden.
Reaktionen: mred33
1.Beitrag schon gelesen, und dir die Bilder angeschaut???
Sind keine Warez inkludiert.
Ich hoffe das hier in Zukunft etwas mehr zur Rom gepostet wird.
Die Rom beinhaltet keine ilegalen apps mehr!!!!
Reaktionen: mecss
Ja, ich hab den Beitrag gelesen, ja, ich hab die Bilder gesehen, deswegen frage ich nach dem Unterschied. Wenn da keiner ist, bleib ich bei Criskelo.
Und ein Dev, der Warez unterstützt und in seine Rom einbaut ist ein schlechter.
Aber egal....
smooth 123
jackbauer2411
MadMurdoc
MadMurdoc
