Masta_Gee81
Enthusiast
- 5.419
[ROM] SenseStyle [2.3.7][Htc Sensation Theme][Beautiful][DOWNLOAD]
Quelle : [ROM] SenseStyle [2.3.7][Htc Sensation Theme][Beautiful][DOWNLOAD] - xda-developers
[ROM][2.3.7] SenseStyle [Htc Sensation Theme][Beautiful][13/11/2011]
- Based on Android 2.3.7 (official Cyanogen Source)
- Modem XXKI4
- Kernel Wolverine
- CSC Multi
- Deodexed
- Zipaligned
- Root
- Sip & Voip 3G/Wifi
- Launcher StyleSense (Free and Customizable)
- Theme Style Htc Sense (ported all png from Htc Sensation)
- StatusBar Style Htc Sense
- Icon Style Htc Sense
- Htc Sense Wallpaper
- Htc Sensation Sounds (ringhtone, notifications, allarms)
- Sense Analog Clock
- Sense Analog Small Clock
- Market 3.3.11 (ported from ICS)
- Ad-Hoc Support
- HTC Ime Keyboard (open files -> ADDON_SenseStyle -> Install Clicker_hi.apk and IME_Keyboard.apk )
- New BootAnimation
- Extended power menu
- Non incrase ringhtone
- Battery % 1,2,3...,100
- and many other that don't remember.
- In Settings > CyanogenMod Settings:
**Applications:
*Install location.
** Dispaly:
*Automatic backlight
*Screen ON/OFF Animation
*Accelerometer rotation
**Input:
*Long-press home settings
*Long-press menu settings
*Search key behavior
*Haptic feedback tweaks
*Volume rocker wake
*Volume button music control
**Interface:
*Power prompt
*Notifications power widget
*Status bar tweaks
*LED notifications
*Render effect
*Reflow after pinch in
*Share screenshots
*Overscroll effect
*Overscroll weight
**Lockscreen:
*Style options
*Widget options
*Unlock options
*Lockscreen gestures
*Delay and timeout
**Performance:
*CPU settings
*Use JIT
*Enable surface dithering
*Use 16bit transperancy
*Allow purging of assets
*Lock home in memory
*Lock messaging app in mem.
*VM heap size
**Sound:
*Notification focus
*Silent state
*Vibrate during calls
*Quiet hours
*Mute camera shutter
*Always play on speaker
*Attenuation of set volume
*Volume if music is playing
**Tablet tweaks:
*Bottom status bar
*Disable lockscreen
Example:
- For the 5 lockscreen -> (Settings >CyanogenMod settings >Lockscreen >Style options >Lockscreen style ... You can set also features etc..)
- For the Overclock -> (Settings >CyanogenMod settings >Performance >CPU Settings ... You can set min and max cpu freq. , governors and other)
- For the BLN -> (Settings >CyanogenMod >Interface >LED Notifications >Click on Unconfigured and Set Messaging and Missed Call);
Deleted some apk in system/app ... resulting a very light rom that provides better performance (+ Free Ram) and a longer battery life.
YOU MUST FOLLOW THIS GUIDE:
Download: Odin v1.85 , Recovery 4.0.1.5 , SenseStyle ROM;
-Put you device in download mode ( vol down + home + power )
-Click PDA and select GT-I9100_ClockworkMod-Recovery_4.0.1.4.tar
-Click Start ( the process during 5-6 seconds )
-Download the rom and put it in the SD.
-Go to recovery (vol up + home + power)
-Do all wipe
-Flash zip from SDcard
-Chose zip from Sdcard
-Select the ROM
-After first boot, the phone rimaning on the first screen, don't worry, remove the battery, put the battery, go to recovery and reflash the rom!! happen only in the first flash...
-This is the only procedure to flash correctly CyanogenMod and rom based on CyanogenMod
DOWNLOAD
Full Pack -CWM Recovery-(Live Wallpaper, VoiceToGo(with rootexplorer,go to system/app click on VoiceToGo and install it), Gtalk Audio/Video, Voice Search, Youtube, Gmail, Adobe Flash Player, Es Monitor, Google Maps, Street for Maps, Google traductor) DOWNLAOD
Fix:
- Phone with call recorder ---> Download
- Modem XXKI4
- Kernel Wolverine
- CSC Multi
- Deodexed
- Zipaligned
- Root
- Ad-Hoc Support
- New BootAnimation
**Applications:
*Install location.
** Dispaly:
**Input:
*Volume rocker wake
**Interface:
*Power prompt
*Status bar tweaks
*LED notifications
*Render effect
*Share screenshots
*Overscroll effect
*Overscroll weight
**Lockscreen:
*Style options
*Widget options
*Unlock options
*Delay and timeout
**Performance:
*CPU settings
*Use JIT
*VM heap size
**Sound:
*Notification focus
*Silent state
*Quiet hours
**Tablet tweaks:
*Bottom status bar
*Disable lockscreen
Example:
-Do all wipe
-Select the ROM
DOWNLOAD
Fix:
P.S. Danke drücken kostet nix
