Kaffee4Eck
- Themenstarter
- #201
V10 ist wieder online. Wegen den Alben bei der Musik App adde ich einen Fix. Hab den String in der apk vergessen. Aber naja wenn man gute 22 Stunden wach ist. ^^
mecss schrieb:Ich war mal so frei und habe den Thread-Titel aktualisiert...![]()
[System]
[Phone]
- Added virtual screen button support for Galaxy Nexus
- Add Motorola RAZR models support
- Optimisation of paste into text editing operations
- Add support for file manager to read external storage card (memory)
- Fix volume key wake up screen may cause media volume to be accidentally changed
[Contacts]
- Add I9100 Call recording support
- Added support to allow some numbers to not automatically add IP prefix (See Phone Settings for more info)
- Optimisation of Emergency dialer interface, add preset commonly used emergency numbers
- Optimisation of layout and text descriptions
- Fix (CDMA) operator support, shows a more accurate talk time
- Fix in some cases caller name will disappear
- Optimise interface to support 720P resolution
[Messaging]
- Fix in some cases selecting a contact from a group does not load the contact details
- Add new contact shortcuts
- Optimise vCard file under certain circumstances returns and error importing the contact which leads to other problems
- Fix strange numbers added to existing contacts and still return after editing the details
[Gallery]
- Optimisation when clicking on contact card to make calls or send SMS / MMS messages
- Fix text message search in some cases leads to FC error
[Lock screen, status bar, notification bar]
- Fix desktop Photo gallery restart photos problem
- Fix using the panoramic camera shooting mode, thumbnails have green in them
- Fix the large picture view, when long pressing operation (edit) button, fix narrowing of icon
- Fix darkened view on Video screen, pressing menu button issues
- Fix FC in view image details for the Motorola Blade device
- Fix desktop photo frame widget when image is deleted from device, the Widget will FC
- Fix duplicate albums on Nexus S and Galaxy Nexus
[Themes]
- Add Variety lock screen support for multi-language (through XML customisation)
- Fix Variety lock screen picture mask, the use of absolute coordinates and calculation error in rotation
- Fix changing theme, modify the style of the notification bar switch leads to a memory leak issue
- Add Variety lock screen support for text control multiple lines of text
[Music]
- Add new wallpaper browsing experience
- Optimise web version of wallpaper browsing experience
- Fix in some devices, the theme resources for 'system' cannot be applied so theme does not take effect
- Fix network connection or network instability problems when theme FC
[Settings]
- Optimisation of music control buttons in the status bar
- Fix in some cases confusing playlist sorting problems
- Fix in some cases, only music automatically stops without reason
- Fix single player, when notification is received the player will not resume playback
- Prompt title error of long press on system play list
[Monitor]
- Optimisation to split the volume controls to be more refined (adjust per use); e.g. Tones, Alarms, Calls, Media, System, Bluetooth etc
[Guard Mode (DND)]
- Added support for the status bar displays the current network traffic output e.g. 0.3K/s
[Notes]
- Optimise the interface layout, support setting different settings per rule
- Optimisation of 12-hour use - segment time format
hallo, ich habe auch mit full wipe installiert, und habe ich auch probleme mit superuser..NiXiN schrieb:Ich habe es gestern nach einem Fullwipe installiert.
Es läuft alles soweit ganz gut. Die Superuser-App macht Probleme, indem sie abstürzt wenn ich nicht im Vorfeld, der jeweiligen App die SU-Rechte benötigt, die Rechte einräume.
Ein großer Minuspunkt für mich ist das nicht funktionierende MTP.
Eigentlich war ich das besch...... Scrollverhalten von CM9/AOKP ROMs satt, aber die nicht vorhandene Sortierfähigkeit des MIUI-Launchers (irgendwie geht mit meinem gekauften Apex das MIUI-Feeling flöten) und kein MTP sind schon NO-GO Anwärter.
Gruß, NiXiN
