[Sammy-ROM][ICS] *10.05.12* [XWLP9] Thebyani Rom V4.2 (Vertumus Theme)
  • 9 Antworten
Gregor901
Gregor901
Enthusiast
2.024
Quelle:
xda-developers
Video For Thebyani V3.3 ICS:
Anmerkungen:
Lese FAQ
Wenn Probleme dann in die Recovery booten, "Fix Permissions" laufen lassen, neu starten. Sollten irgendwelche Apps nicht richtig laufen, dann in der Anwendungsverwaltung deren Cache löschen.
Almost everything is working great and fast.
Big thanks to Vertumus for giving me the permission to use his theme in Thebyani Rom
CHANGELOG:
V4.2: NON-Wipe Rom. Wiping data/factory is a must (New framework). -Based on XWLP9 -Siyah Kernel v3.2rc1 -Rom is very stable. -Better Performance -Better Battery life -New option in Settings for Kernel -Fixed Motion sensors in browser -Fixed Browser search issue -Vertumus sounds -50% Transparent Status Bar (thanks to el_liberator) -Updated APEX launcher to latest version -Removed AOSP MMS -Removed AOSP browser -Added Stock MMS app themed -Added Stock Browser themed -Added beats audio -Added full screen caller with record -BLN Support with 3 different mods -Blue themed Icon for MMS app -Thebyani Notification bar -Updated SuperSu to latest version -Remove AOSP Email and Exchanger -Added stock Email & Exchanger themed -Fixed Bluetooth issue. -Fixed Remote Control FC. -Fixed Auto Rotation issue. -Added init.d.support -Added .ad.blocking -Included clean kernel script (Built in) -Included BULP6 Modem -Flash on Lock Screen -Added 4 ways reboot -Rom's name on settings>about phone -Skip songs with volume keys -Removed "Swipe to unlock" text -Fixed home button lag -Added CWM app -This is what I remember. remember.
Installation:
1- Download den zip file (Thebyani_V*.*_ICS.zip).
2- Kopiere diesen Thebyani_V*.*_ICS.zip auf die sdcard.
3- Boote in den recovery modus
4- Wipe cache and Dalvik cache (Wipe von data/factory wird empfohlen, muss aber nicht sein.)
5- Installiere die zip von der sdcard. .
6- Danach reboot und alle Einstellungen vornehmen.
7- Wenn fertig, boote in die recovery.
8- Gehe zu Advanced > und wipe Battery stats.
9- Gehe zu fix permissions.
10- Reboot
11- Freuen
To set Nova launcher, remove the search bar on the original home screen
then, go to Nova setting > Desktop > click on Persistent Search Bar > choose (always)
To set Apex launcher, remove the search bar on the original home screen then, go to Apex setting > Homescreen settings > uncheck Hide Persistent Search Bar
Thebyani V4.1
Thebyani 15 toggles for V4.1
Wichtige Hinweise:
1- Some Customization:-
For:
- Torch from lockscreen
- 4-Way reboot mod
- Skip songs with volume keys
- Home button lag fix
- ICS lock on/off
- "Swipe to unlock" -text on/off
When you flash Thebyani rom a folder called Tweak is created on ur sdcard with the following files in it:
/sdcard/tweak/skip_song_on
/sdcard/tweak/home_button_fix_on
/sdcard/tweak/ICS_lock_on
/sdcard/tweak/lock_torch_on
/sdcard/tweak/unlock_text_off
So if u want to to change to stock lock screen then just go to folder /sdcard/tweak/ICS_lock_on and rename it to anything else. If u want to go back to ICS lock screen then just rename it back for it's original name.
Ex: I want the stock lock screen I change:
/sdcard/tweak/ICS_lock_on to ICS_lock_off
I want to get back to AOSP lock screen I change:
/sdcard/tweak/ICS_lock_off to ICS_lock_on
and the same for others.
2- For people facing Battery Drain:-
1- Go to the following folders and delete them:
- /sdcard/android/dcim/100andro
- /sdcard/lost.dir
- /sdcard/android/data/com.android.providers.media
- /sdcard/android/data/com.cooliris.media
- /sdcard/android/data/com.google.android.gallery3d
- /sdcard/androidthemes
- /sdcard/android/dcim/.thumbnails
2- After that, reboot into recovery, then go and wipe battery stats. Then, reboot and let the phone syncs then reboot again.
3- If u r using Siyah kernel (BE CAREFUL: this is only for Siyah), then install Extweaks app from market and do the following:
Go to MISC> RESET FUEL-GAUGE CHIP and press on RESET FUEL-GAUGE CHIP
After that give it will show u funny values give it few hours and it will be fine.
Downloads:
V4.2: Thebyani V4.2 ICS , Addons and 15 toggles for V4.2
Add-On:
Stock Email and Exchanger flashable zip Pls wipe cache and dalvik cache then flash the zip file after that go and clear data and cache on both Email and Exchanger apps
Thebyani's 15 toggles for V3.8 Mirror for my 15 toggles from ayk33 thanks to him
Google Calender Note: Using Google Calendar is responsible for delete a contact fc and Google+ app fc
Choose another Launcher
Dialer with record and no full screen
IF YOU LIKE MY WORK AND WANNA SEE ME SUPPORTING OTHER DEVICES, MAKING MORE ADVANCED STUFF. THEN, MAKE A DONATION VIA PAYPAL TO MY E-MAIL: ataz123@hotmail.com
Reaktionen: mecss und Markus Fenix
platzhalter
So, nachdem ich diese ROM hier eingestellt habe, habe ich sie mir jetzt mal draufgezogen. Einfaches Fazit: Läuft schnell und störungsfrei. Telefonie, Datenverkehr, Wlan, GPS usw. - alles o.k. und keinerlei Bugs feststellbar. Daten aus anderen ICS-ROMs problemlos importierbar.
Offenbar sehr solide gebaute Custom-Rom - wer was Zuverlässiges sucht, ist damit gut bedient.
Reaktionen: Dr.Franz und mecss
v3.9 ist raus... :D
-Based on XWLP7 deodexed by wanam and LP4 from Thebayni
-Added Beats Audio codec library
-Added Beats Audio Boot animation
-Added Custom start up sound (F1 racing car)
-Changed default wallpaper to Beats Audio
-Added Cron, init.d script and files from liberty rom (Siyah Compatible - change liberty.cfg in system/etc to make changes - zip align, fix -permissions, SD Boost.. and others in folder system/etc/init.d)
-Added Siyah kernel 3.1 rc2 (*note* rc3 is currently out)
-Changed LP7 csc to LP4 csc [LUX] (as I didn't like my phone starting up in Russian )
-AOSP lookscreen
-APEX launcher
-Fixed Home Button lag
-Added CWM app
Reaktionen: Gregor901
irgendwie hab ich probleme mit der V3.9, installieren klappt reibungslos.
Dann bootet mein phone bis zum dreieck und bootet erneut, bis zum CWM.
Wenn ich jetzt "reboot system now" mache passiert genau das gleiche wieder.
Denk mal es liegt am Siyah Kernel 3.1 rc2, muß man da noch was einstellen bevor er das rom bootet?
So, habe das eben mal probiert. Klappt aber alles. Allerdings habe ich 'n Fullwipe zuvor gemacht. Bin also nicht von einer anderen Thebyani-Version gekommen, sondern "leer". Das jedenfalls geht einwandfrei.
naja einen kompletten fullwipe hab ich natürlich nicht gemacht. Werde ich dann mal testen...
Neue Version 4.0 verfügbar, Opener + Threadtitel angepasst.
fettes dankeschön glg asus 002 :)
Chris1996
beicuxhaven
beicuxhaven
Chris1996
italy-playa
I
Chris1996
Chris1996
Chris1996
