[Sammy-ROM][ICS] *01.06.12* CriskeloServanTeam v11.1 - 4.0.3 (LPW)
  • 89 Antworten
wie kriegt man dieses akkuweather.com widget im apex oder nova launcher zum laufen?
Kommt immer die Meldung auf Startbildschirm kein Platz vorhanden. Da muss man doch was einstellen aber was war das nochmal
ROM ◥███◣ CriskeloServanTeam V11◥███◣-ICS 4.0.3 15 Toggles full working (Oficial LPW)
CriskeloServanTEAM ICS V11
LINK
CriskeloServanTEAM_-V11-LPW-MD5-9653A8B278BA69438475112EB9F3DF20.zip
Changelog:
• Base Rom XWLPW
• CF-Root-SGS2_XX_OXA_LPW-v5.5-CWM5
• ADD Modem LPW
• Deodex
• ADD Superuser apk
• ADD Galaxy S3 Launcher ICS Mod ToucWizUX-1.3-5x5
• Add BrowserPlus ICS stock Browser
• AOSP keyboard ICS
• Samsung keyboard ICS
• AppWidgetPicker (Widgets groups, the same APP)
• ADD Roletube App YouTube that allows the download of Videos (SDCARD/Download)
• Host updated to avoid publicity
• Everything you need to run VPN (not tested) Thanks to ookba
ADD LockScreen Original ICS and Samsung (in SD-CARD/ CRISKELO-SERVAN-ADDONS Update LockScreen Samsung/ICS)
• ADD StatusBar 15 toggles Theme STOCK/CRISKELO (en SD-CARD/ CRISKELO-SERVAN-ADDONS Update status bar 15 toggles stock theme/criskelo theme)
• ADD Version of Rom Agregado in About phone (Settings.apk)
• Mod SMS are not logged in Call Log
• ADD CRT TV off effect
• Native CallRec
• Various improvements in Framework-res.apk
• ADD 15 Toggles LibDroid (working perfectly)
• Fixes Status Bar (GPS icon, Direct access to settings, new icons, Data enlarged erase button (now a cross), Operator at the bottom, and some other tinkering)
• Battery% on / off from settings / display
• Icons en statusbar color ICS
• ADD Wallpapers in gallery Criskelo
• ADD more Wallpapers in TW Wallpapers
• ADD Gallery ICS Google
• DialPad style ICS
• Improvements in performance, ported from Galaxy S3
• Many details, to improve the overall stability of the ROM
Thread-Bot mecss hat den Titel aktualisiert... :D
Ich war mal so frei und habe den Thread-Titel aktualisiert... ;)
V12 online. Wenn ich richtig vermute sogar mit Jkay Unterstützung
Gibt es ne möglichkeit nur die icon in der Statusbar zu bekommen?sehen schön aus will aber auf stock bleiben da mein s2 stabil läuft nach 0.3 endlich!hab mich jetzt tot gesucht nach theme@s überall ohne erfolg:(:mad:mit rom usw bin ich noch unerfahren wie das geht und was danach passiert?
gesendet mit tapatalk ,s2 ics 4.0.4 siyah......
schön das hier mal einer hilfe gibt....:(
tapa,s2 xwlpw stock 4.0.4 ics ,pille theme ,blue icon mod-4.1.5 siyah
Was erwartest du an Hilfe einer ROM, die nicht mehr weiter entwickelt wird und veraltet ist, zumal die meisten User schon längst auf andere ROMs umgestiegen sind.
Des Weiteren wird jemand antworten, wenn er etwas dazu sagen kann...
kann mir einer dem Download des ersten center clock geben???ist tot!?
Thoddü
Thoddü
Deadboy
Jamen
debaki
debaki
debaki
