[Sammy-ROM][GB] *16.02.12* Leo und Check's CheckROM RevoHD V6 | 2.3.6 XWLA4
  • 8.479 Antworten
@bandit:
build.prop aus CheckRom RevolutionHD V2.0.0
Code:
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=GINGERBREAD
ro.build.display.id=CheckROM Revolution v2.0.0
ro.build.version.incremental=XXKI4
ro.build.version.sdk=10
ro.build.version.codename=REL
ro.build.version.release=2.3.5
ro.build.date=Tue Sep 27 16:33:36 KST 2011
ro.build.date.utc=1317108816
ro.build.type=user
ro.build.user=se.infra
ro.build.host=SEP-62
ro.build.tags=release-keys
ro.product.model=GT-I9100
ro.product.brand=samsung
ro.product.name=GT-I9100
ro.product.device=GT-I9100
ro.product.board=GT-I9100
ro.product.cpu.abi=armeabi-v7a
# Samsung Specific Properties
ro.build.PDA=I9100XXKI4
ro.build.hidden_ver=I9100XXKI4
ro.build.changelist=611039
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=samsung
ro.product.locale.language=en
ro.product.locale.region=GB
ro.wifi.channels=
ro.board.platform=s5pc210
# ro.build.product is obsolete; use ro.product.device
ro.build.product=GT-I9100
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=GT-I9100-user 2.3.5 GINGERBREAD XXKI4 release-keys
ro.build.fingerprint=samsung/GT-I9100/GT-I9100:2.3.5/GINGERBREAD/XXKI4:user/release-keys
ro.tether.denied=false
ro.flash.resolution=1080
# end build properties
# system.prop for asop5000
rild.libpath=/system/lib/libsec-ril.so
rild.libargs=-d /dev/ttyS0
ro.sf.lcd_density=240
# Check's Boost
pm.sleep_mode=1
ro.ril.disable.power.collapse=0
persist.adb.notify=0
#Render UI with GPU
debug.sf.hw=1
#Increase overall touch responsiveness
debug.performance.tuning=1
video.accelerate.hw=1
# Improve overall media quality
ro.media.enc.jpeg.quality=100
ro.media.dec.jpeg.memcap=8000000
ro.media.enc.hprof.vid.bps=8000000
# Tweaks for battery saving
pm.sleep_mode=1
windowsmgr.max_events_per_sec=150
wifi.supplicant_scan_interval=180
#Decrease dialing out delay
ro.telephony.call_ring.delay=0
#Disable blackscreen issue after a call
ro.lge.proximity.delay=25
mot.proximity.delay=25
#Fix some application issues
ro.kernel.android.checkjni=0
# ADDITIONAL BY VINCENZO
keyguard.no_require_sim=true
#Flags
ro.config.hw_menu_unlockscreen=false
persist.sys.use_dithering=0
persist.sys.purgeable_assets=1
dalvik.vm.dexopt-flags=m=y
ro.mot.eri.losalert.delay=1000
# Samsung USB default mode
persist.service.usb.setting=0
dev.powersave_fps=0
# ADDITIONAL_BUILD_PROPERTIES
ro.url.legal=http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html
ro.url.legal.android_privacy=http://www.google.com/intl/%s/mobile/android/basic/privacy.html
ro.com.google.locationfeatures=1
ro.setupwizard.mode=OPTIONAL
ro.com.google.gmsversion=2.3_r7
media.stagefright.enable-player=false
media.stagefright.enable-meta=false
media.stagefright.enable-scan=false
media.stagefright.enable-http=true
media.stagefright.enable-rtsp=false
dev.sfbootcomplete=0
ro.com.google.clientidbase=android-samsung
ro.config.ringtone=S_Over_the_horizon.ogg
ro.config.notification_sound=01_Sherbet.ogg
ro.config.alarm_alert=Good_Morning.ogg
ro.config.media_sound=Media_preview_Touch_the_light.ogg
ro.opengles.version=131072
ro.secdevenc=true
ro.wtldatapassword=true
net.bt.name=Android
dalvik.vm.heapstartsize=10m
dalvik.vm.heapgrowthlimit=64m
dalvik.vm.heapsize=64m
dalvik.vm.stack-trace-file=/data/anr/traces.txt
net.tcp.buffersize.default=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.wifi=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.umts=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.gprs=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.edge=4096,87380,256960,4096,16384,256960
Moin, ich mal wieder :D
Ich hatte mir nun doch lieber erstmal die CM7 fürn Anfang geflasht, aufgrund der vielen Beiträge hier wo des Flashen net so will.
Aber so wirklich zufrieden, bin ich damit net...
Daher traue ich mich doch mal hier ran.
Wenn ich das richtig rausgelesen habe, ist ja viel wegen der CWM Version 5 nicht so gut gelaufen.
Bei CM7 bringt der Kernel die 4.0.1.5, kann ich es auch damit versuchen?
Sprich wenn ich dann die Wipes mache und anschließend die Checkrom flashe, bleibt der Kernel von CM7 doch erhalten?
Ich frage, da die Version 1.8 vom SiyahKernel nicht mehr im xda forum runterladen kann.
Wenn meine Theorie soweit stimmt, sollte ich doch so auch noch ein Thema über die Kitchen flashen können ohne Bootloop und dann erst den aktuellen SiyahKernel flashen?
idealforyou schrieb:
Auf Checkrom.com bin ich auch gekommen aber da kommt bei downloads:
CheckROM - Error
Deshalb suche ich einen Mirror Download. Der Verweis auf CheckRom bringt also rein gar nichts da dort kein Download des Roms möglich ist.
Hm naja hier geht es
DirectLink
Multiupload
the_w1 schrieb:
guten morgen,
ich hoffe dieser post wird nicht überlesen aber für eine antwort war es gestern zu spät.
das hc-k tool von hellcat ist primär dazu da dir den arsch zu retten :) sichert nämlich deine imei. Solltest du die zerballern ist schicht im schacht. backup und restore ;-)
Das kann man doch auch mit der Kitchen App erledigen, EFS Backup, also wofür dann eine Extra App?
Hallo leute,ich habe stock fw I9100XXKI3 und dann I9100XXKI4 (1 datei) installiert,als nächstes habe ich CF-Root-SGS2_XX_XEO_KI4-v4.4-CWM4 installiert und New_XXKI4_CheckROM_RevolutionHD_V2.0.0 auf interne sd kopiert.
Dann mit Volume Up + Power + Home ins Recovery gebootet...Wipe Data/factory reset ausgeführt...Wipe Cache ausgeführt...Wipe Dalvik-Cache ausgeführt...install zip, choose zip, die "rom".zip ausgewählt und ausgeführt...Reboot...aber handy boot-et nicht und dann habe ich noch einmal bei 2. angefangen...recovery startet aber funktioniert nicht
CWM-based Recovery v5.0.2.3
E:Can't mount /chace/recovery/command
E:Can't mount /chace/recovery/log
E:Can't open /chace/recovery/log
E:Can't mount /chace/recovery/last_log
E:Can't open /chace/recovery/last log
und wenn ich versuche wipe date/factory reset kommt
Wipping data...
Formatting /data...
E:format_volume: make:fxtf4fs failed on /dev/block/mmcblk0p10
Formatting /chace...
E:format_volume: make:fxtf4fs failed on /dev/block/mmcblk0p7
Formatting /se-ext
Formating /sdcard/.android_secure...
Error mounting /sdcard/.ANDROID_SECURE1
Skipping format...
Data wipe complete...
WAS habe ich falsch gemacht ??? BITTE !!
Also so wie ich das sehe liegt es auch hier an CWM5. Versuch folgendes:
1. Speedmodkernel flashen
2. Fullwipe
3. Checkrom 2.0 flashen
@Snarph
So auch bei dir.
Alles klar ich gehs mal an.
Der Speedmod verträgt sich ja nicht mit CM7, steht zumindest auf der Downloadseite, da ich CM7 ja danach aber nicht starte, sondern eh nen Fullwipe mache, ist das ja sicher egal?
2. Fullwipe
Und wie ??? Danke !!
- kernel per odin flashen ( siehe Anleitung im forum )
- Recovery modus ( wipe data/ factory reset,wipe cache )
- zip file auf die sd kopieren
- per recovery ( cwm 4.? ) installieren.
- warten und später freuen..
Reaktionen: Brico_GO
Du kommst ja aktuell ins CWM, aber dein Handy bootet nicht so wie ich das gelesen haben. Lade dir den Speedmod CWM Version runter. [KERNEL] SpeedMod SGS2 [K2-13 Update3 CWM4 CIFS ROOT] - xda-developers Boote ins CWM, flashe den Sppedmod über install zip. Boote erneut ins CWM. Anschließend wipe date factory reset, wipe cash, wipe dalvik cash. Anschließend flashe die Rom über install zip. Funktioniert das nicht, dann flashe über Odin eine dreiteilige Stock, damit es überhaupt erstmal wieder bootet, dann den Speedmod, dann Wipe, dann die Checkrom V2.
Danke jungs es funktioniert...und nun noch wegen DarkKnight Kernel...das mache ich einfach über CWM -> flash kernel (*.zip datei auswälen) oder ???
Jup.
Hab das mal in den Startpost eingefügt...
JA!...oder über Odin( ich flashe Kernels nur über Odin,nur so ne Angewohnheit)...
Vom Darknight gibts keine tar und ne zip würd ich jetzt nicht in Odin einbinden... ;)
Ich würde den ganzen Kernel nicht nehmen !!!:laugh:
Hamst0r schrieb:
Es kann doch nicht sein, dass es nicht anders funktioniert? Werd das morgen mal so ausprobieren wie dus sagst, aber wie soll man sowas denn in einem video erklären, versteht ja kein mensch^^
Es führen viele Wege nach checkROM. Es gibt wohl scheinbar nicht den Weg um auf 2.0 zu flashen.Das flashen ging bei mir von der 1.0 auf die 2.0 ohne probleme.Die meisten probleme entstehen meiner Meinung nach, durch die vielfältigen möglichkeiten der Software kombinationen die die Kitchen anbietet.Wo ich davon ausgehe das der großteil der CheckromRevo Nutzer niemals alles angebotene nutzen würden,wenn sie es zusammensuchen müßten,was durchaus einige vor enormen problemen bewahren würde.Da ja die meisten davon ausgehen das alles zusammen funktioniert ,weil es in der Kitchen ist und das scheint wohl offensichtlich nicht der Fall zu sein.Anders sind die auftretenden Probleme nicht zu erklären da Samsung bestimmt nicht unterschiedliche Galaxy S2 ausliefert auch wenn zum teil manche Bauteile von unterschiedlichen Herstellern kommen,die aber irgend einen Standart erfüllen müßen.
Sent from my GT-I9100 using Tapatalk
Warum der rennt bei mir ohne Probleme
Eigentlich hat alles super geklappt nur die normale Statusbar geht ohne den Haken show quickbutton text nicht das geht nur mit der deluxe bar
Hallo , ich habe die neue Revolution 2.0 , und den Empfang von Telefon ist schlecht geworden, habe ich die Modem xxkg6installiert,Kernel ist der siyah-v2.1-darkknight aber ist nicht besser.. meine telefon provider ist vodafon , bitte was kann ich noch versuchen??
->TopAZ<-
->TopAZ<-
beicuxhaven
beicuxhaven
beicuxhaven
beicuxhaven
  • Angepinnt
  • beicuxhaven
27 28 29
chris1995
