Patrick P
Dauer-User
- 438
Hab ich geht nicht
Patrick P schrieb:Das glaub ich dir schon. Aber bei mir geht es nicht. Kann es am Kernel liegen?
Speedy 2 schrieb:Hey Leute .. wie lang hält bei euch der akku ? Ich hab das handy heut morgen angeschalten 100% und bis jetzt an grhabt und nix daran gemacht und jetzt sind es 72% ... wie ist es bei euch ? ... ist das normal ?
Sent from my GT-I9100 using Tapatalk
Speedy 2 schrieb:Ich hab die app jetzt geholt und geguckt und bei deep sleep steht 42% .... ist jetzt was kaputt ? :/
quick and dirty guide to have less battery drain:
- use 2G-only if you don't need 3G
- monitor programs which cause wake-lock. use betterbatterystats and either uninstall or tweak them
- do not use task killers. see the previous item and find the malicious programs instead of repeatedly killing them.
- do not activate google latitude on maps.
- if you don't need pushmail, uncheck gmail sync and use k-9 mail to pull mail, lets say, every 1 hour or so.
- go to settings / location and security. disable "use wireless networks" and "use gps satellites". enable them when you need them, other than that keep them disabled.
- disabling auto-brightness and using a low brightness level helps. do you know that you can adjust the brightness by swiping your finger across the notification bar? try it...
- using juicedefender may help, but it may also cause more drain. test it yourself.
- if you need more speed than 2.5G (i.e. edge) disable HSDPA (*#301279#, select 2 then select 1). you will have 3G instead of H(SDPA) and I think it is fast enough
- disable fast dormancy. dial *#9900# and disable.
- disable auto sign in for google talk (search for talk in appdrawer and use settings to disable automatic sign in)
- disable samsung update and don't use samsung gadgets if you are not in love with them. (this part may be taken care of the rom developers)
- try several radios. I recommend you to try KE7, KG2 and KH3 and choose the one which suits you best. KG2 seems to be the best for me. however, in terms of battery life, there is not much difference between those three.
- be aware that more you use your phone more the battery drainsdon't complain like "my battery drains quite fast but I did not use my phone. I only played angry birds for hours without making a single call" or don't expect to have a decent battery life if you use your phone as a computer or download torrents using your phone.![]()
Speedy 2 schrieb:Ohhjehh... also und wie find ich das jettt heraus welches widget das ist :/ ..
