[Sammy-ROM] *30.07.12* Salman-ROM v4 - S3 THEMED [dev.ment finished]
  • 39 Antworten
Chris1996
Chris1996
Stamm-User
141
hi leute leider beendet der Dev die Weiter entwicklung dieser Rom :(
Für alle die nicht flashsüchtig sind und mit einer echt sehr guten stablen und smoothen Rom zufrieden sind: Download Me Please v4.2
LG Chris
I LOVE YOU XDA, just to think i was a noob 3 months ago,
and now, i can flash cwm and any rom i want to, translate roms/apps,
MAKE ROMS, solve problems, and almost anything that i know about android
i have to thank XDA for makeing this wonderful fourm,
i could not just sit back, while i take from others, without giving anything
back, so this is me giving back, THIS IS SalmanRom
Changelog:
Salman v4
removed some apps
updated google play jelly bean (thanks to imbonez9)
new dialer, more like sgs3 lock screen with center date, time and whether sgs3 popp notifications (still needs work)
better sgs3 like notification area
added sgs3 music player (thanks to P_Toti)
new wallpaper selector new bootanimation added exchange.apk THEMED jobmanager.apk
fmradio.apk
phone.apk
secbrowser.apk
many others
MORE SCREENSHOTS
DOWNLOAD Salaman ROM v4
Für eine bessere s3 Optik könnt ihr die EXTRAS.zip downloaden
(do not flash the EXTRAS .ZIP, just unzip, you will find APK's etc.)
And for those who would like to have the samsung bloatware there is
a Flashable CWM package at the end of this post
DO NOT CHANGE KERNEL
Android 4.0.3
Build XWLPG
deodexed
bloarware removed
CF-ROOT KERNEL
fully rooted
Jkay framwork included (app not)
TouchwizUX-1.5.1-4x5
apex launcher THEMED
stock sounds
stock wallpaper
stock icons
stock widgets
Full RTL support (ARABIC)
Non stock Sgs3 boot animation
Stock Sgs3 shutdown animation (.qmg)
Music Player now transparent
Video player now transparent
Myfiles themed (blue)
contacts app themed (blue)
Memo app themed (blue)
browser themed (toolbar looks just like SGS3)
Added Samsung apps
Added Samsung IM
Added Clockpackage.apk ported from SGS3 rom
Added SGS3 battery percentage
Fixed android upgrading at every startup
camera sounds disabled
themed mms.apk/ it shows sgs3 icons when you send an attachment
No More FC
More stable
Faster
Better battery life
Faster GPRS/Gps/Wifi
AND MANY MORE OTHER THINGS
FILES IN EXTRAS .ZIP below
Extras .zip Package Includes
(warning do not flash in CWM, just extract and install from file manager)
-Android terminal emulator
-AppstoreVn (Black Market)
-ICS KEYBOARD APP (for arabic users)
-ARABIC FOR ICS KEYBOARD APP
-Battery Calibration App
-ChatOn APP
-Sgs2 bootscreen changer
-touch ripples live wallpaper
-SGS3 stock HD wallpapers (.jpg)
-BOOTLOGOS SGS3/SGS2/Samsung
^^^^DOWNLOAD^^^^
Bloatware Cwm Package includes
GameHub.apk
Kobo.apk
MusicHub.apk
PressReader.apk
ReadersHub.apk
SamsungApps.apk *
SamsungAppsUNA3.apk *
SamsungIM.apk *
Zinio.apk
*=included without flashing package
^^^^DOWNLOAD^^^^
How to INSTALL
1. put rom onto your MICRO SD CARD
2. boot into CWM
3. GOTO- backup and restore/backup/Go Back
4. GOTO- mounts and storage/format cache/format system/format data/Go Back
5. GOTO- install zip from sd card/ choose zip from sdcard
6. CHOOSE THE FILE "XWLPG.SalmanRom_v2"/ yes- Install XWLPG.SalmanRom_v2.zip
7. Go back to main menu and press reboot system now
****What to do with touch ripples Live wallpaper****
use the SGS3 stock HD wallpapers as the background of the
touch ripples live wallpaper (you can find in live wallpaper settings),
and since the lockscreen is transparent, its just like having the SGS3
Lockscreen, well it's my best try, just intill it leaks out =)
SalmanRom BLUE THEME (STATUS BAR/CURTIN)
THANKS TO Korumera FOR FILE HOSTINGhttp://s9.postimage.org/5ohiaeqgf/png.png
XDA-Thread
Hat die Rom schon jemand getestet?
Nein,noch nicht. werde mir aber die V3 flashen,die wohl in 2 Tagen veröffentlicht wird. Der Dev nimmt noch wünsche an,sofern realisierbar.
ich habe es gerade nach Anleitung geflasht. Erster Eindruck ist sehr gut. Leider hängt sich bei mir Touchwiz-start immer auf
Gruß Florian
Dpi geändert?
Nein.
Gruß Florian
Neu flashen ( mit full wipe ) schon versucht?
Sent from my GT-I9100 using Tapatalk 2
Mach ich jetzt mal.
Läuft es denn bei euch rund?
V3 online. einfach auf den v2 link klicken;)
dann wird gleich mal die v3 getestet ^^
Auch hier sehr schick was bisher noch nicht so richtig klappt ist der Sperrbildschirm sonst echt S3 nah :cool2:
ich schon wieder, habe immer noch das selbe Problem. Handy komplett platt gemacht. V3 geflasht. Sobald ich ein widget hinzufügen möchte stürzt mir touchwiz ab. Und dann immer wieder...
Gruß Florian
Bei mir läufts bislang einwandfrei. Zu den widgets: Hab gehört,dass Stock-Agenda und Kalender Widgets probleme machen.Angeblich für TW5 nicht angepasst.
Mir ist nur aufgefallen, das in Verbindung mit Jkay das letzte Toggle von 6 in der Quick Toggle Leiste nicht ganz dargestellt ist. HAb die Systemui aus dieser Rom https://www.android-hilfe.de/forum/...esign-by-nature-v3-1-1-final-jkay.249817.html extrahiert und per Rootexplorer implementiert. LÄUFT
Warum kommt keiner auf die Idee einfach mal in der Jkay app die Einstellungen zu resetten und woalaa alle toggles passen wieder.
wo ist denn der thread bei xda geblieben?
Edit:
Ist wieder da. XDA hatte Probleme
Keine Ahnung :thumbdown:
debaki
debaki
debaki
beicuxhaven
beicuxhaven
beicuxhaven
Lehrer
