[Sammy-ROM] *28.04.12* [XWLP9] CodecROM™ 5.7 by DSA [AOSP Apps | Theme]
  • 1 Antworten
Chris1996
Chris1996
Stamm-User
141
CodecROM™ 5.7
XWLP9 5.7 Changelog
ROM DEVELOPMENT ON HOLD - PHONE HAS BEEN STOLEN, WAITING ON INSURANCE
• Base Firmware: I9100XWLP9 (4.0.3)
• Region Netherlands
• Carrier: KPN
• Build Date: 11th April 2012
• Modem: XXLPS
• CSC: OXALPS (CPW, DBT, ITV, KOR, XEF, XEO, XEU)
• Change List: 378442
• CF-Root LP8 Kernel (Doesn’t seem to cause SOD issue)
No wipe
• Deodexed
• Zipaligned
• Rooted
• BusyBox
• ClockworkMod Recovery 5
• Unlimited contacts on messages
• No SMS to MMS converting
• Contacts issue fixed
• Some system tweaks from 4.04
• Updated Hosts file
• Fixed Sdcard issue
• Performance tweaks
• Battery tweaks
• Memory Tweak
• Kernel tweaks
• Faster GPS fix
• Removed bootup sound
• SIP (VOIP)
• 15 toggles (Lidroid Mod)
• Fixed text in statusbar
• Lockscreen flashlight (press and hold Menu button)
• Black youtube with hd over wifi & 3g
• Modded Phone.apk:
- Call recording
• Modded contacts.apk:
- No log removed
- Set the Default Call logs type to “View All Call logs” (no SMS)
- Let you view/edit all other logs types
- Doesn’t conflict if you switch to stock email app
• Hacked Email.apk:
- Removed keyguard and other security policy restrictions
• Hacked Camera.apk:
- Silent
- volume buttons capture picture
• Modded Google Play Store:
- Unlimited access to apps
- Removed countries restriction
- Fixed the issue – ‘your device is not compatible with this item’
• 4 way reboot power menu:
- Reboot
- HotBoot
- Recovery
- Download
• Themed stock keyboard
• Added AOSP Keyboard
• Updated AOSP apps
• Added DSP Manager
• Home button lag fix
• Volume keys skip music track when phone is locked
• ICS 4.2 Theme by Vertumus
• 4 Way Lockscreen rotation by default
• 4 way screen rotation (achieved with Apex Launcher screen orientation set to auto rotate)
• Removed usb connection tone
• Removed low battery notification tone
• Removed charging notification tone
• Removed video recording tones (camera/video is completely silent now)
• Removed the annoying camera click when rebooting
• Slightly smoother scrolling
• Live wallpaper .apks are back
• Weather on lockscreen now works (you need to switch back to stock lockscreen)
• Multi CSC
• Thanks to kahvitahra, you now have these mods that can be switched on and off:
ICS lockscreen (On by default)
Home Button Lag Fix (On by default)
Volume Keys Skip Track (On by default)
Swipe To Unlock Text (Removed by default)
• When you flash the ROM, a ‘tweak’ folder is created on your SD Card with the following folders inside:
/sdcard/tweak/skip_song_on
/sdcard/tweak/home_button_fix_on
/sdcard/tweak/ICS_lock_on
/sdcard/tweak/lock_torch_on
/sdcard/tweak/unlock_text_off
• If you don’t want to use one of these tweaks or you want to use stock lockscreen, then just rename that folder to (e.g) “skip_song_off” or delete folder. When you want to get tweak back then create that folder again.
shakeyabooti GNex icons
• ICS/AOSP Themed
• New bootanimation
• New shutdown animation
• New tones
• ICS Themed MyFiles
• ICS Themed FM Radio
• ICS Themed Keyboard
• CRT Off Effect
• Gingerbread emoticons
• Apex Launcher
• Modded Play Store
• Google Books
• Rom Toolbox
• Modded Youtube
• DSP Manager
• Samsung Keyboard
EMAIL
• GMAIL
• BROWSER
• CALENDAR
• CALCULATER
• CLOCK
• GALLERY
• VIDEO EDITOR
• KEYBOARD
• TALK
All bloatware
• Samsung Keyboard
• TW Launcher and most TW related stuff
Chainfire
Sboulema
Vertumus
kahvitahra
rustamabd
Lidroid
codeworkx
LegendK95
karl999999
raffaele88
bezke
Adesirello
Dully79
CriskeloSERVANTEAM
nguyenxuanhoa
esk02k
Intratech
SiberianTiger
shakeyabooti
El_liberator
theos0o
Deeco7
Special Thanks:
Wanam for time/patience and answering my stupid questions, for sharing mods/guides on xda (and permission for things)
This is a CWM flashable ROM, not to be used through Odin
•Download BUT DON’T EXTRACT my ROM
•Backup apps etc via Titanium Backup
•Move my .zip file to your SD Card (Internal Storage)
•Reboot into CWM
•Perform ‘wipe Data/Factory Reset’
•Choose ‘Install .zip from SD Card / Choose .zip from SD Card / XWLP9 CodecROM 5.7 by DSA.zip
•Select yes from the options
•Wait until install finishes and reboot
Minor Thing to note:
Browser is AOSP, so where it should show ‘Search’ in options, it shows ‘%1$s is now running’ – This is just a graphical thing
DOWNLOAD LINK
Extra Packages:
• Beats audio CWM Zip
• Additional Apps CWM ZIP – Includes:
- Plus One
- Street
- Maps
-XDA App
All Have GNex Icons
Battery Saving Tips
Disable auto sync for accounts
Disable GPS (and wifi gps)
Disable auto backup of Gmail account
Set wifi sleep policy to “when plugged in”
Disable motion
Check your apps settings and disable useless background sync
Orginal ->XDA-Thread<-
Da man nicht die Möglichkeit hat für den Dev ( Darkside Agent ) zu spenden wäre es jeddoch toll wenn ihr auf den XDA-Thread geht und wenigstens auf Danke klickt ;)
Platzhalter 1
Gregor901
asus002
Chris1996
italy-playa
I
beicuxhaven
  • Angepinnt
  • beicuxhaven
27 28 29
chris1995
