[Sammy-ROM] *25.04.12* [LP9] Dynamic v1.4 [ICS][Slim][Performance & Battery life]
  • 61 Antworten
Masta_Gee81
Masta_Gee81
Enthusiast
5.405
[ROM][XWLP9]★ Dynamic v1.4 ★[ICS][Slim][Performance & Battery life][25April]
- Full Wipe
- Based on the lastest official XWLP9 4.0.3
- Kernel N.E.A.K 2.0.3x
- Modem XXLPS
- Deodexed & Zipaligned
- Root & Busibox
- SuperSu & CWM
-ClockWorkMod Recovery Full TouchScreen
- Trebuchet Launcher
- Status bar 15 toggle
- Battery 1%
- Google Play Fixed
- Automatic EFS Backup
- Fixed Home button lag
-BLN (active it with BLN control app)
- MultiLanguage
- Reduction of noise during calls
- 4 Way Reboot
- No SMS into call logs
- Gallery 3D optimized
- Fix USB storage mode
- Best Video quality 1080p
- Best Audio Suound (Beats audio lib)
- Youtube with feature to see video in HD (720p)
- Browser optimized
- No advertising without the need for external programs
- Istant GPS
- Deleted shutdown video (As in CyanogenMod 9)
- Any features of ICS 4.0.4
- Beats Audio lib (best audio sound)
- Phone with Call Recorder
- Google Music
- Quick panel
- Google Gallery
- Vertumus 4.2 Theme. (Full ICS Graphics)
Themed ICS:
- Lockscreen
- BootAnimation (without sound)
- Keyboard
- Camera
- Calculator
- File
- Wallpaper & ICS LiveWallpaper
- SMS
- Clock
- Settings
- Browser
- Radio
- Phone
- Contacts
- Video
- Music
This ROM is very slimmed
Removed all unnecessary apps in system/app (also 101 apk) that doesn't affect the correct operation of the device...
I make this rom for BEST PERFORMANCE and BEST BATTERY LIFE
*For a clean installation and no problem
- Download the ROM and put it on your S2.
- Go to Recovery
- Wipe data factory reset, wipe cache.
- In Advance: wipe dalvik cache and wipe battery stats.
- In mount and storage - format data , system and cache
- Install the zip file and you will get the CWM install completed message.
- Select Reboot Now and let the phone boot up to an Android setup screen.
- If there are Update, download it, put it on the phone, go to recovery and install it. Don't do wipes.
IF you have Gingerbread ROM...
- Flash first stock ICS Firmware, after flash CF-Root kernel for root and recovery.
- You can follow the guide above cited
Dynamic XWLP9 v1.4 | 25April | Download
For Best battery life:
1) Open NSTools app
2) On |CPU| Set "Min CPU freq" to 100MHz
3) On |Volt| Set this voltage:
100MHz --- 850mV
200MHz --- 875mV
500MHz --- 925mV
800MHz --- 100mV
1000MHz --- 1125mV
1200MHz --- 1200mV
v1.4
- Now Based on XWLP9
- Added NStools (follow my guide for best bettery life)
- Updated Trebuchet launcher
- Fixed SMS colour app
- All news of other relase
- Updated YouTube
v1.3
- Now Based on XWLP8
- Updated kernel to Abyss 2.2 Stable Edition
- Updated Theme to Vertumus 4.2
- 4 Way Reboot
- No sms into call logs
- Added Memo.apk
- Best battery life
v1.2
** For Flash the Update, you must have Dynamic XWLP7 v1.0 **
- Update kernel: AbyssICS v2.1 Stable Edition
- Best Performance and Battery life
v1.0
-Initial relase based on XWLP7
Quelle: [ROM][05Apr][LP4] Dynamic |ICS|Slim|Performance & Battery life|Download Link Added| - xda-developers
Reaktionen: Me-Virus, S04, Termaal und 4 andere
#Reserviert 1
Wow sieht sehr nice aus! Ich liebe einfach dieses Cyan Blau :love: Werd ich gleich mal Testen!
25 MHz? Kann mal jemand testen ob er dann überhaupt noch aufwacht?
Das musst du im Kernel Bereich mal fragen ... die können dir da weiterhelfen ...
Ich lass immer alles Org. so hab ich keine Probleme ... :D
P.S. Update Kernel Dl Link im ersten Post hinzugefügt ...
Reaktionen: belphegore
Ja wacht auf und läuft richtig schnell :)
Reaktionen: kirkhamster und belphegore
Ich werd's auch mal testen. Allerdings frage ich mich, ob es außer schwarz, blau (in 3-Schattierungen) und ggf. a bisserl grün keine anderen Farben gibt. Jeder schwimmt auf der "BlackBlue"-Welle.
Nunja - Geschmacksfrage halt. Aber so "massenhaft" ?? Oder gibt es nach Volkswagen und Volksmatratze nun auch Volksfarben ?
Gregor, ich hab keinen Plan :D Google hat halt mit dieser Farbe bzw dem Stil von ics einfach einen neuen Maßstab gesetzt, es sieht einfach übelst stylisch aus und die Leute fahren einfach drauf ab :) aber ist halt Geschmackssache! Mir gefällt es total!
Hab die Rom drauf, gefällt mir bisher wirklich sehr gut. Was mir nicht so gefällt ist die schwarze Schrift auf grauem hintergrund, ist leider nicht so gut lesbar! Hab die dpi auf 210 runtergesetzt und jetzt ist der dialer irgendwie verschoben! Weiß jemand Rat wie ich das wieder zurechtrücken kann ohne jetzt die dpi wieder auf 240 zu setzen?!
Edit: Mir kommt es so vor, als wäre das Scrollverhalten ein wenig träge..
sent from my Hyperdroid machine.. bäm!! bä!! bäm!!
So habe sie nun auch drauf.
Ist meine erste ICS - Rom und ich muss sagen, wow.
Sieht nicht nur super aus sondern läuft auch super.
Okay mein Vorredner hat schon recht, ein wenig träge ist es in selteneren Fällen aber damit kann ich leben ;)
EDIT: Das liegt aber daran, dass man meistens zu geringe Mhz zahlen bei SetCPU angegeben hat ^^
Was mir auffällt ist, dass das Display viel tollere Farben hinbekommt.
Bin von Checkrom V6 auf diese gewechselt
Ich hab nix an den mhz eingestellt, alles so gelassen wie es war! Schick ist die Rom, ohne frage, aber ich denke ich bleibe bei RomMIX, falls mir was von dieser Rom mehr gefallen sollte wie in der RomMIX, die png's sind ja schnell getauscht :D
Was sich inzwischen alles slim schimpft ist ne echte Schande!
>100mb ist NICHT slim!
Find ich schon ... es gibt Ics Roms mit über 450mb vollgepackt mit Schrott!!!
Da ist diese hier mehr als slim in meinen Augen :D
aber zum glück gibt es ja apps wie Root Explorer und man kann das runterschmeissen was man will :thumbup:
Edit : Seite 1 Aktuell .... Neues Update 1.1 ....
Kann ich die 1.1 ohne Data Wipe drüber bügeln ?
EDIT: Hat sich erledigt ! :)
Für mich ist die frage nicht geklärt :p kann ich die 1.1 draufmachen wenn ich die 1.0 hab ohne full wipe ? :)
Nein, ist full wipe ;) Hab ich im xda dev. gelesen.
So nach 2 Tagen ein kleines Feedback .
Optik ist toll ! Leider ist die Rom an sich ein wenig hakelig. Es hängt alles schon noch ein bisschen auch wenn man die MHz zahl erhöht. Ich habe allerdings noch nicht die 1.1 getestet
Ich überlege mir auch schon die ganze Zeit, ob ich mir diese Rom flashen soll.
Aber vorab habe ich da eine Frage: Findet man die externe SD im Pfad
/sdcard/external_sdcard ... (wie bei Samsung)
oder unter
/emmc/ ... (wie bei CyanogenMod 9) ???
Letzteres wäre für mich ein Grund diese Rom nicht zu flashen. :(
Sowohl die 1.0 als auch die 1.1 waren bei mir unter der sdcard.
Reaktionen: Termaal
Das ist gut. Das gefällt mir :)
Kann man auch den Speicherort der aufgenommenen Fotos/Videos in der Kameraapp bestimmen? (Telefon oder SDCard)
Denn dies ging in CM9 ebenfalls nicht.
Da hab ich leider nicht drauf geachtet, sollte aber eigentlich möglich sein.
FotoMichi
debaki
debaki
mecss
mecss
debaki
debaki
debaki
