[Sammy-ROM] *22.07.12* [4.0.4] Portal Rom v2.0 [Siyah-Kernel][XWLPM]
  • 20 Antworten
Chris1996
Chris1996
Stamm-User
141
After looking at all the current ROMs available I realized there is a big gap currently as you can either go all the way Pure CM9 or no where close to it at all. So I drew inspiration from the missing segment in all the current ROMs available out there.
Features:
[Optional Improvement]Portal Rom 1.3 Kernel Update
-Please update to the latest Siyah Kernel -> Siyah 3.3.1
-The released Kernel with 1.3 version 3.2.8 was giving extremely poor battery life.
[Optional Patch]Portal Rom V1.3a
Status Bar transparency fixed - Complete transparent Status bar will not be supported any more.
Portal Rom V1.3
Kernel Update to Latest Siyah 3.2.8
Complete Status Bar transparent - Fixed Jkay Brightness bar to fit in with the rest of the Drop down
Contacts has been updated to fit with the theme
MMS and Phone has been updated to fit with the theme
Portal Rom V1.2
Made the notification bar Transparent with a dark style as with V1.1
Removed a lot of apps that was not being used to make it semi Slim'd down. ( Damn you S-Voice for being 90mb :p )
Default Alarm clock has been put back
The Dandelion Live wallpaper can be downloaded, copied to your SD card and you can just click it and install it if you want it - From Here
Portal Rom 1.1
Everything listed in Version 1.0
Removed some Apps that can be installed from the Play Store
Settings got new Glow icons to match the rest of the Rom
Full support for JKay Deluxe Edition with his add-on application
S-Voice was included as a default feature including wake up features and Dock features
Changed the Modem to XXLPS as it obtains a Wifi lock quicker and in general seem more stable than the new XXLPX.
3G and Wifi Stability resolved. It was related to the latest modem driver.
Rom got a Performance boost by removing start-up scripts that was running in the background. This is not affecting functionality but you should see better battery and overall performance - Let me know please if it made a difference
TW4 has been updated and it should respond a little bit smoother than before.
Portal Rom 1.0
ICS XWLPF 4.0.3
Siyah Kernal 3.2.6+ Features of Kernal
TouchWiz v4 from SGS3
AccuWeather from SGS3
ICS Lock Screen
Built in Battery meter in Notification Bar
SIP VOIP enabled
CPU min has been set to 100MHz for battery saving
Deluxe Quick Launch in Notification
Quick Launch unique glow Icons for toggle
Hardware Acceleration
Lock screen Live Wallpaper support
Lots of Tweaks and extras eg. Torch, CRT Display off, Skip song volume ect ect ect
To be completed in the next Update/Release:
Contacts Look and feel Update
MMS Look and feel update
Remove unnecessary apps to make a Slimed version as well.
More 3G tweaks
Download Link:
Portal Update to V1.3a - Requires Portal Rom V1.3
Portal Rom V1.3
Installation:
Screenshots:
Hier klicken um zum XDA-Thread zum kommen ;)
Reaktionen: Fn0rd und Kumo
läuft bei mir schon. erster Eindruck: nicht so klickibunti,eher Schwarz-weiß gehalten. Wenn man s-voice nach dem Wetter fragt, zeigt er nur das Wetter von Cambridge....
Aber sonst gefällt es mir bisher.werd es weiter testen
Die Bootani ist ja schon mal nicht schlecht, mal schaun was sonst noch so geht
Der ursprüngliche Beitrag von 00:01 Uhr wurde um 00:12 Uhr ergänzt:
Leider ist bei mir S Voice auf italienisch und das beherrsche ich nun mal nicht. Also zurück zur alten Rom.Schade
S-Voice öffnen, Menü-Taste,Impostaz wählen,dann obersten Eintrag"lingua" und dort auf Deutsch einstellen :biggrin:
Reaktionen: Kumo
Tolles Rom....kann ich nur empfehlen!
Jepp,läuft stabil und Akku hält auch gut durch. Hab mir nur die Systemui von Omega v14 Black-blue geklaut,da mir die Wifi und Mobilempfangsanzeige bei schlechtem Empfang zu wenig war.Fiel kaum auf,wenn da nur ein Pünkchen zu sehen war
Also schwarz-weiß kann ich nicht bestätigen. Bei sieht es eher nach Stock Rom aus. Auch finde ich nicht den Home Hintergrund wie er auf den Screens zu sehen ist...
Hat jemand das screen wie bei der ersten Seite Rom Vorstellung?sieht nämlich richtig geil aus
also bei mir sieht sie auch nicht schwarz-weiß aus,eher wie ne Stock und Wetteranzeige im sperr-modus geht auch nicht obwohl man das einstellen kann.
moin moin
ich hab jetzt schon ein paar rom´s ausgetestet
dieser hier gefällt mir eigentlich ganz gut
nur irgendwie bekomm ich keinen lockscreen
egal ob ich ein muster oder ein pin oder einfach nur gleiten einstelle bei bildschirmsperre
hat einer ne idee was ich machn kann
Kann es sein das die links nicht mehr gehen?
Mit Hermesversand geschickt.
Also bei funktionieren die Links noch.
1.4 online bei xda
Die Version 2.0 auf ICS 4.0.4-Basis ist online. Läuft super. Einziger Wermutstropfen: Jkay funktioniert noch nicht. Folgt dem Link im Startpost.
Version 2.1 online:
Features:
Portal Rom 2.1
Updated to Samsung XWLPT
Siyah 3.5.2+ Kernel
Brand new Boot-up animation
Navigation Pull down Toggles added and working as per Portal Theme
QuickPanel Settings (app) added to manipulate all the Toggles
CRT Off with Fix applied
Transparent Dailer, Contacts and MMS as per Portal theme
MTP Drivers added so you don't have to use mass storage anymore
Lidroid Name fix - It states Portal Rom now (Thanks wanam)
Google Voice search enabled
Home button Lag fix applied
Superuser App replaced by SuperSU for Root access
Bin mit 2.0b schon sehr zufrieden (Batterieleben und flüssiges bedienen) . Lade runter und werde berichten. :thumbup:
Version 2.3 ist online
[ROM][4.0.4] ≈≈≈ Portal Rom V2.3 ≈≈≈ [05 Aug 2012][Siyah 3.5.2][XWLPT] - xda-developers
Portal 2.3 has been completely Rebuild. Please do a complete wipe before installing 2.3
Portal Rom 2.3
  • Updated to Samsung XWLPT
  • Siyah 3.5.2+ Kernel
  • Call Recording added
  • Swype added
  • ICS lock screen with own Portal Animation
  • Fixed Boot-up security pin
  • Fixed Toggle transparency - Little bit darker now
  • Brand new Boot-up animation
  • Navigation Pull down Toggles added and working as per Portal Theme
  • QuickPanel Settings (app) added to manipulate all the Toggles
  • CRT Off with Fix applied
  • Transparent Dailer, Contacts and MMS as per Portal theme
  • MTP Drivers added so you don't have to use mass storage anymore
  • Lidroid Name fix - It states Portal Rom now (Thanks wanam)
  • Google Voice search enabled
  • Home button Lag fix applied
  • Superuser App replaced by SuperSU for Root access
Der ursprüngliche Beitrag von 20:01 Uhr wurde um 20:02 Uhr ergänzt:
Gleich mal testen. Jetzt ist ja call recording und swype mit an Bord:tongue:
Hhmm. Merkwürdig, ich hab' gar keinen Launcher. Schon zweimal geflasht, immer noch keinen. Nur bei mir so?
Japp, daran lag's - jetzt geht's.
