STaaFF7o
Epsilon Project now enters the world of Samsung S2 Galaxy, having gone through Motorola Atrix, from the beginning being GingerMod and then moving to the new Epsilon was looking to give as always the best for each development. I hope this rom will enjoy it and together we can continue to get always the best for our teams.
I decided to do basing on Ginger as ICS for the moment has a high battery consumption and low flow. There is nothing to envy of ICS ...
Changelog v1:
Base LA4 GB 2.3.6
Modem LPS
Kernel Stock LA4 CF
Rooted
Busybox
Deodexed
PNG Optimized
Auto Zipaligned (system and data apps) (Thks Darky)
Hosts Adblocking
Proximity sensor hack
GPU hack
WiFi battery saving hack
Saves power when phone is sleep
Allows the phone to sleep better
Helps Scrolling Responsiveness
Increase overall touch responsiveness
Increases quality of photo and videos
Change the Dalvik VM heap size 128Mb
Disable usb debugging popup
Render UI with GPU
Optimized internet connection
Less delay in calls
Best download market
Best ram memory management
Enhanced Screen Sensor Delay off
Removed the delay in calls
Improved memory management
Best video streaming
Added Reboot Power Panel
MicroSD Card Speed 1024KB/s
Perfect Mod mount options
Market Connection Speed Fix
Original Visual GB
Added JKay Deluxe v13.6.4 (15 toogles, lockscreens, power extended, etc) (Thks Jkay)
Fast Power
Switch-off the camera when the battery charge 0%
Video/audio profiles 24-20Mbps/192Kbps_44100Hz
Disabling increasing the volume level for incoming calls
Removal of noise reduction options
Removing the delay after talk end
Disabling autoconversion SMS to MMS
Disabling control the number of contacts for the simultaneous sending
Increase the maximum size of send messages with 300 KB to 1 MB
Increasing the speed of response Automatic Brightness Control (ABC)
Increased speed and smoothness of transitions brightness in ABC
Bravia Engine Mod (Thks ykk_five)
SuperCharger Mod (Thks Pikachu01's)
AFTR enabled
Sched_mc disabled
Logger disabled
Custom Brightness
Static Bus Frequencies
Custom Deepsleep Levels
GPS Tweaks (Thks Crypted's)
Dynamic hotplug
Logging disabled
WIFI/3G/4G Tweaks
Hot Plug Thresholds
Sampling Interval & Frequency
Battery 1%
Gtalk 1.3 Mod (VideoChat and more)
Google Play 3.5.16 Mod (Unlimited access to apps in Google Play Store, Removed countries restriction in Google Play Store, Fixed the issue which your device is not compatible with this item in Google Play Store) (Thks Deeco7)
CallRec Mod
Phone Mod
Added CPU Spy
Added Screen Filter
Added FasterFix
Added ScreenMod (Thks wql)
Added Screen Filter
Added Voodoo Screen
Update Google Apps
AutoBackup EFS Folder
Theme ICS Mod Optional (Thks Vertemus)
And More...
Changelog v2:
ICS Animations Stock Theme
Google Play 3.5.16 MOD (Unlimited access to apps in Google Play Store, Removed countries restriction in Google Play Store, and more)
Youtube Mod (Wifi and 3G HD)
Beats Audio + XLoud Mod
Some details of the visual system and the modified
Changelog v3:
Update FasterFix
SD Card Speed 2048 kb/s
Added System Apps Removed in FTP Folder
Camera Volume Up Mod (volume up button for shutter)
Disable SuperCharger Tweaks
Remove Disable Logger
Kernel SpeedMod K2-21 (Optional Phenomenals Kernels UV) (Thks Hardcore)
Fix Bugs
Changelog v4:
Built again from the beginning to solve all the bugs
Fix Bug Sounds
Kernel CF-Root XWLA4
Disable Logger
Google Play Store v3.5.16 MOD Fix
YouTube APK with 720p HD playback (WiFi) Fix (Thks theos0o)
GPS Optimize
Updated hosts Ad-Blocking
Bravia Engine
Remove Fasterix
FuguTweaks ICS in GB (Thks nikademus)
Browser with user agent & bounce effect
ICS Transitions Fix
Old version of Gtalk with video and voice
Google Services Optimize
New Wallpapers
Added UpdateMe (Thks acquariusoft) (Now you can update the rom and install all add-ons/modems/kernels/theme/apps downloaded from the same Epsilon Project)
Download - http://gingermod.grupoandroid.com/SG...ject-GB-V4.zip
It is advisable to be on base before installing GB Epsilon Project. The best way is to do a clean install from the stock rom with Pit XWLA4
Link Rom - Link CF-Kernel.
And then proceed with installation method is traditional to travez of CMW. Previously always take the Wipes Data / Cache / Dalvik Cache, Format System / Data / Cache and then proceed with the installation.
In case you want to have a visual style to leave them as optional ICS installer by CWM. The credits are for Vertemus, I just edited and corrected some bugs of the same to operate properly in all EpsilonProject.
To have a lower battery consumption is advisable to follow these steps:
According to several people testing kernels that consume less battery in GB are the Phenomenal in versions 2.2 and 4.0. We recommend using the Extreme, in case your computer crashes be changing this medium or normal.
Settings> Display> Brightness: put it to a minimum
Settings> Display> Lighting duration: "1.5s"
Settings> Display> Display Power Auto adjust: off
Settings> Applications> Samsung Apps> "OFF"
Settings> Location & security> Ustilizar networks: off
Telephone keypad> * # 9900 #> "Disable fast dormancy"> exit (this comes to swallow a 20% battery usage)
If you have multiple email accounts, disable auto-sync and manually click Refresh on:
Settings> Accounts and synchronization> Auto-sync: off
If you want to continue with the automatic brightness another way to lower consumption is from the application of JKay change the values in the brightness profiles.
Another way is to also play with the different types of modems available and find the best we go according to our area. Remember that to be possible to use 2G connections have a lower consumption than autimaticas. If you need more speed to sail can move to 3G or Automatic again.
It is important to always install after the end of the Rom google open the play and update the UpdateMe because I I will be updated as we get better application and if they do not always updated will not see the improvements that arise and you will see only Rom and Setting
List Update Me
This ROM includes a new application that keeps you informed of updates, and also allows you to get off with just a click all the kernels, modems, issues that need.
Update I called and now includes this:
ROM
This section tells you if you have the latest version and apart from donations (deserved)
KERNELS
All Epsilon Projet compatible kernels
Cleaning Kernel Script
XWLA4 CF-Root
Siyah v2.6.14
K2-21 SpeedMod
N.E.A.K 1.4.2x
2.2 Phenomenal Black Normal
2.2 Phenomenal Black Medium
2.2 Phenomenal Black Extreme
4.0 Phenomenal Black Normal
4.0 Phenomenal Black Medium
4.0 Phenomenal Black Extreme
MODEMS
Modems most used and recommended by the forum
Modem-KG4
Modem-KI1
Modem-KI4
Modem-KL1
Modem-LP3
Modem-LP7
Modem-LPQ
Modem-LPR
Modem-LPS
Modem-LP6
APPLICATION REMOVED
Applications that have been removed to let more light rom. (install themselves alone)
BuddiesNow
ChocoEUkor
Days
dlna
EmailWidget
GameHub
GenieWidget
HelvNeueLT
Kies
KiesAir
KiesWifi
Kobo
LiveWalpapers
LiveWalpapersPicker
memo
Microbesgl
MiniDiary
MusicHub_10
PhotoRetouching
PolarisOffice
Sticky
PressReader
Protips
ReadersHub
SamsungApps
SamsungAppsUNA3
SamsungIM
SecretWallpaper1
SecretWallpaper2
SevenEngine
Signin
SnsAccountFb
SnsAccountLi
SnsAccountMs
SnsAccountTw
SocialHub
Swype
Syncmldm
Syncmlds
Tasks
TrimApp
VideoEditor
VoiceToGo
Wssyncmlnps
Zinio
EXTRAS
AOSP-ICS-Email
Stock-Email
Clear-Email
BeatsAudio-Mod
Browser-Mod
Stock-Browser
VolumePlus
Mod CallRec
Call Mod Stock
Bounce Overscroll
Overscroll Stock
Youtube HD Mod 3G
Youtube HD Mod 3G and Wifi
Youtube Stock
Camera Mod
Camera Stock
Fix FlashPlayer
TW Mod 4x5x5
TW Mod 5x5x5
TW Stock
THEMES
Topics to change the look completely out of the rom
ICS-EpsilonProjet-GB-v4
Theme Stock
SETTINGS
Various configuration options
