Kjetal
Mitglied
- 10.214
In Anlehnung an diesen Thread [OFFURL]https://www.android-hilfe.de/custom-roms-fuer-samsung-galaxy-s2/205351-rom-fuer-alle-die-ics-pur-erleben-wollen.html[/OFFURL]
" Danke an Quelle für die Info, war nur leider sehr lieblos "
Ich habe die wichtigsten dinge grob ins Deutsche übersetzt.
download latest version :
Pure ICS Rom & Addons (special thanks to pawmadsen)
changelog version 7.3.1 :
- based on XWLP8 (actually i worked on xwlp9 but its not fast and smooth as xwlp8)
- No wipe method (so u can install it over 7.3 without loosing ur apps)
- syiah kernel 3.2.2
- new ics theme (v4.3) solved over 95% of issue also no balck on grey (thanks to vertumus for new ics theme)
- call recording mod (thanks to wanam & lidroid)
- themed mms app
- update apex launcher to 1.1.1 and modify it (solved messaging shortcut issue)
- percentage battery level
- update gapps to last version (street , google play ,...)
changelog version 7.3 :
- based on XWLP8
- full wipe method (no need to wipe your device , the rom will do that)
- CF-Root BULPC kernel
- new ics theme solved over 95% of issue also no balck on grey (thanks to vertumus for new ics theme)
- update apex launcher to 1.1beta2 and modify it (solved messaging shortcut issue)
- update gapps to last version (google play , google music ,...)
- change status bar icons (send-recive data on wifi visible)
changelog SE v2.0 :
- based on Lidroid ZSLPE
- Multilanguage
- XXLPS Modem
- Aosp contacts,phone,mms,calendar,browser,clock,email...
- Call recording mod
- ICS Lockscreen with home button lag fix
- update apex launcher to 1.1beta4 and modify it (solved messaging shortcut issue)
- Percentage battery+15 Statusbar toggles
Pures Android ICS RoM
[ROM][XXLPQ] Pure ICS v7.0 [16-Mar-2012] - xda-developers
Features : Funktionen
- Pure ICS UI
- Better battery life & smoothness
- Fully deoxed and zipaligned
- Rooted and latest SU
- Apps and framework optimized
- Integrated with Google Addons
- Android ICS stock icons
- ICS keyboard
Added : ( Zugefügt )
- Last Google addons
- ICS Launcher
- Google Music 4.1.511
Removed : ( Entfernt )
- Touchwiz and depends apps
- Clock package days,dlna,sammy email,X-hubs,kies,kobo.maps,minidiary,music player,press reader,zinio,...
Download :
Spike.Pure.ICS-v6.0
MD5: 9E479CAFFFCCFCA5D055EA4848ED1A94
Installation Guide :
- Nand backup
- Full wipe your device (wipe data/factory reset - wipe cache - format system (in mount and storage) - wipe dalvik cache ( in advanced)
- Install rom via cwm recovery
Übersetzt :
- Backup erstellen
- Data / Factory Wipe - Cache Wipe - System Format - Dalvik Cache Wipe
- RoM via. Recovery Flashen.
Be Watchful :
- you must install last sammy ics rom first and then install this rom
- if you have issue like rebooting or many fc use new installation Guide
- if u have a battery draining first full your battery and goto recovery and select wipe battery stats , second use task manager and close runing programs every time you feel its needed
- and finally word that i must say , Do not expect me to do a miracle , sammy ics roms are in beta mod now and they have bugs ....
Übersetzt :
Es muss vorher ein ICS Stock RoM geflasht werden .
Sollte nach dem ersten Boot ein starker Akku verlust auftreten ins Recovery gehen und Batterie Stats wipen.
Bedenkt das alle ICS RoMs noch den Status " Beta " haben, daher kann es nach wie vor zu problemen kommen.
Addon :
Percentage battery+15 Statusbar toggles for version 5 ( special thanks to lidroid & Sboulema )
Changelog :
version 7.0 :
- based on XXLPQ
- ics ui improvement (thanks to vertumus for new ics theme)
- replace trebuchet with apex launcher (fast , more customizable , ...)
- remove crt animation (because of bug in it)
- ics lockscreen (thanks to vertumus)
- ics bootanimation
- change status bar icons (send-recive data on wifi)
- themed mms , tw calendar , tw calculator ...
Download :
Spike Pure ICS v7.0
MD5 : 3B5C9ECD37A4C476F503DE5CCC21E9BA
Mirror for version 7.0 :
Mediafire (thanks to AdaVS)
Rapidshare (thanks to malavan)
Torrent (thanks to marshall39)
version 6.1 :
- based on XXLPH
- back to no wipe method
- ics calendar & calculator
- crt animation
- ics bootanimation
- edit some png in mms
- new wallpaper and lockscreen wall
version 6 :
- based on XXLPH
- back t wipe method
- themed calendar & calculator & my file
- memo back
- update gapps
- change quick launch & status bar icons
- back to sammy music player
- remove bloatware (polaris office,kies ...)
- replace sammy keyboard with ics one
version 5 :
- based on XXLPB
- crt animation
- replace memo with gnote
- update gapps
- change quick launch icons
version 4 :
- based on xxlp6
- replace music player with google music
Credits :
Special thanks to :
google
sammy
dsixda for great kitchen
my forum ,saeid & naser for hosting rom
chainfire for kernel
bigbang hd & vertumus for theming
other i forget
Hier noch ein Video zum RoM .
Quick video of the rom (thanks to sleeves007)
- themed mms app
- based on XWLP8
changelog SE v2.0 :
- Multilanguage
- XXLPS Modem
[ROM][XWLP4] Pure ICS v7.2 [05-Apr-2012]
- Based on latest ics released rom
- fixing known issue of every release
- Pure ICS feeling
- improved battery life
- optimized framework
- fast smooth and stable
- Rooted by proper tweaked kernel
- no sms in call log
- no sms to mms convert
- latest SU update
- latest google apps update
- seprate mods for more personalizing
- removed unnecessary samsung app
- ICS themed including icons crt dialler
- and many more not remember right now
Pure ICS v 7.2
aosp mms&contacts 7.2 (wipe cash and dalvik before install)
addons for 7.2 (creadite go for vertumus wanam sbulema and chatrat) read before installing addon
mirror
changelog version 7.2 :
- based on XWLP4
- update apex launcher to 1.03 and modify it
- full ics ringtone
- home buttone lag fix
- Pure ICS feeling
- latest SU update
Pure ICS v 7.2
mirror
- based on XWLP4
- full ics ringtone
- Pure ICS UI
- ICS keyboard
- ICS Launcher
Download :
Spike.Pure.ICS-v6.0
- Nand backup
Übersetzt :
- Backup erstellen
Be Watchful :
Übersetzt :
Addon :
Changelog :
version 7.0 :
- based on XXLPQ
- ics bootanimation
Download :
Spike Pure ICS v7.0
version 6.1 :
- based on XXLPH
- crt animation
- ics bootanimation
version 6 :
- based on XXLPH
- memo back
- update gapps
version 5 :
- based on XXLPB
- crt animation
- update gapps
version 4 :
- based on xxlp6
Credits :
Special thanks to :
sammy
other i forget
