Chris1996
Stamm-User
- 141
Pure Look S3
Pure look S3 - simple - Fast - smooth _ stable - battery friendly !
System Details:
Changelogs:
Update 6/6/2012 : v3.1.1 final XWLPG
—» Stock dialer + no call big picture
—» Remove Jkay setting ( buy here here or here)
—» added googleSeachWidget S3
—» Fixed icon camera
—» Fixed theme of Task manager & Video player ( stock theme)
—» Syiah kernel v3.3.1+
—» more Build.prop and tweak in init.d
—» disable MTP ( USB stogare is defaul)
...and other things i don't remember.
and much more... you can find in my rom
Falls ihr keinen Lockscreen-Wallpaper einstellen könnt downloaded touchwiz UX 1.5.1 oder 1.4 und das Problem ist behoben
Downloads:
-Pure Look S3 v3.1.1
Mods:
Battery Green %
GreenCircle
Stock Battery - no %
XDA-Thread
System Details:
- Rooted
- Busybox
- Deodexed
- NO WIPE
- Hosts Adblocking
- Improved Touch Sensitivity
- GPU Acceleration
- WiFi tweak saving battery
- Scrolling improved responsiveness
- SONY BRAVIA: Increase the quality of photos and video
- Modified Dalvik VM 180MB heap size
- The user interface rendering with GPU
- Internet connection ottimizzat
- Fewer delays in calls
- Sensor Screen Delay off
- Memory management improved
- Added Power Panel: Reboot
- Download
- Hot boot
- MicroSD Card speed 1024KB / s
- Market connections Fix Speed
- Switch-off the camera when the battery charge 0%
- Video / audio profiles 24-20Mbps/192Kbps_44100Hz
- Disabled increased volume for incoming calls
- Removal of the options for reducing noise in call
- Off SMS to MMS
- no autoconversion
- Deactivated limit number of contacts for the simultaneous sending
- Increase the maximum size of messages sent with 300 KB to 1 MB
- Increase the response speed automatic brightness control (ABC)
- Faster and smoother transitions of brightness (ABC)
- Custom Brightness
- static bus frequencies
- DeepSleep custom levels
- Tweaks GPS
- Tweaks WIFI/3G/4G
- AutoBackup EFS Folder
- YoutubeHD Mod (Wifi-3G)
- Mod LockScreen
- Tweak your SD card for added control features: Lock Screen:
- ICS / SAMSUNG
- Text display screen unlock: ON / OFF
- Torch lock screen when you press the home button: ON / OFF
- Delay action to pressure the home button: ON / OFF
-Changed Sound Power - Added pach font characters
-Call Recording no Full Screen
-15 toggles the status bar + battery percentage %
-Silent Camera - eliminated sound battery
-Mod. Play Store
-Other extras: Audio Beats with a better sound quality and power thanks to
-app volume + - youtube hd that is 3g wifi and much more ....
-Added apk:Touchwiz Galaxy S3, 80 pack font, SwiFTP, CMW Manager,
-FasterFix
-Added soung notification Galaxy S3
-rom nowipe
-fixed boot and many Fc ( Pm me if you still Fc )
-syiah v3.2.6.4 ( newest)
-NELP3 modem ( better battery life)
- Busybox
- Deodexed
- NO WIPE
- Hosts Adblocking
- GPU Acceleration
- Download
- Hot boot
- Off SMS to MMS
- no autoconversion
- Custom Brightness
- Tweaks GPS
- Tweaks WIFI/3G/4G
- Mod LockScreen
- ICS / SAMSUNG
-Mod. Play Store
-FasterFix
-rom nowipe
Changelogs:
Downloads:
Mods:
Battery Green %
GreenCircle
XDA-Thread
