FireS24208
Stamm-User
- 361
[ROM][LPF]FOXHOUND Revolver Ocelot|ICS|OTA|Performance|AROMA|31 May
Hier Die Neue Batista auf ICS Basis
AOSP theme FoxHound 2.2 Download
AOPS theme universal - work fine FoxHound 2.1 Download
AOSP Theme only for FoxHound 2.0 Download ---- preview
Zoule's Theme for FoxHound 2.1 Download and prewiev
Blak blue theme by lexullde HTC Mania Download and preview after install theme flash this (9scroll)Download
Stock Theme Universal fix Download
SistemUI clock white by zoule HCo foxhound 2.0 Download
Theme Style 2.7.2 UNIVERSAL ROM Download
Battery C Style universal
Bubble Battery Universal Download
Space Battery Universal Download
Ubuntu Fonts flashable to recovery (more big) Download --- Preview
Bootanimation Batista70 Download --- Preview
Gokhan
Vertumus
ApriliaM3
Sicopat
_JKay_
89luca89
Waman
Gowind
Lidroid
Matriak31
ToxicOne
Hier Der Link von XDA [ROM][LPF]FOXHOUND Revolver Ocelot|ICS|OTA|Performance|AROMA|31 May - xda-developers
FoxHoundFOXHOUND Revolver Ocelot
Boot into recovery mode
2. Format System / Factory Data Wipe
3. Wipe cache and also wipe dalvik cache
4. Install FoxHound ICS 0.9 zip file. You will get install completed message.
5. Select to Restart System Now and let the phone boot up to an Android setup screen. 6. Setup the phone as requested including Google setup.
7. Once Android Setup is complete, Reboot the phone into Recovery Mode again
8. Wipe cache and wipe dalvik cache again
9. Select to Restart System Now
10.Now if you want install AOSP package
Changelog FOXHOUND Revolver Ocelot
Based on the latest official firmware 4.0.3 XWLPF NO WIPE
Deodexed
Zipaligned
Optimized
Removed some Samsung apks
AOSP Launcher Apex
AOSP GoogleGallery
AOSP Calculator
AOSP Keyboard
GSIII Stock themed
GSIII TW Launcher
GSIII Sounds/Notifications/Ringtones
GSIII Dialer themed
GSIII wallpaper
GSIII Widget
Apollo Music Player
Fix CRT animation from xda
Insert FoxHound Bootanimation
Added AppWidgetPicker
Added Ad-blocking via hosts file
Added Status Bar Power Widget 15 icons shortcut Thanks Lidroid/Wanam
Insert fix text for Toggles and translate for Italian people
Fujutweaks-> Taken from Latest ICS 4.0.4 build
Sysctl.prop added MANY Tweaks for Memory and Resource Management
Tweaked Speed of Memory card
Phone with Call Recording & No Incremental Ringtone
Noise Suppression enabled
Enabled Conference Call support (Thanks wanam)
MMS no MMS auto-conversion -200 contacts per SMS and correct send time stamp
Remover SMS in Call Log
Insert domination theme in Aroma installer for jkay UI and framework
Camera Volume Up&down Shutter
And moreeee
Jkaymod: (use apk for full mod)
+ 18 scrollable quick panel toggles incl:
Do not disturb quick settings button (the notification toggle from tablets)
Screen on quick settings button (temporary 3 mins of screen on)
Auto brightness quick settings button (long press to adjust brightness and auto-brightness using a slider)
Mobile data, Airplane mode, Vibrate toggle, Wi-Fi hotspot, Sync, Flashlight and the 4 reboot toggles
Long press on these toggles to go to settings!
+ Original ICS lockscreen
+ Live wallpaper support on lockscreen
+ 6 bars for GSM signal
+ Custom date format on status bar
+ Next Alarm Info on drag bar
+ Transparent statusbar on lockscreen
+ Redesigned Samsungs WiFi icons as I did not like the ICS look from Samsung!
+ Separate Wifi In/out arrows
+ Removed leading zero to hour on status bar (to changed 09:00′ to 9:00′)
+ Semi transparent connection icons
+ Fast screen off to turn the screen of faster!
+ Toggle flashlight by long pressing Home button on any lockscreen!
+ Toggle sound on/off using volume buttons on any lock screen
+ Disabled Battery full notification
+ Disabled Bluetooth notification
+ Long press volume buttons to skip track (when music is playing and screen is off, and note: this also works when you have set lockscreen to None!)
+ Connection icons are green when fully connected to google servers
+ Battery with percent (100 steps plus 100 steps charging)
+ Added Reboot to Recovery and Reboot to Download to the phone dialog panel
+ Enabled fast double click (350ms instead of 500ms)
+ Enabled CRT off effect when screen off
Deodexed
Zipaligned
Optimized
AOSP Launcher Apex
AOSP GoogleGallery
AOSP Calculator
AOSP Keyboard
GSIII Stock themed
GSIII TW Launcher
GSIII Dialer themed
GSIII wallpaper
GSIII Widget
Apollo Music Player
And moreeee
Hier sind auch noch ein Paar und Themes zur Rom
Die Rom hat auch wieder eine OTA App
GUIDE FOR ACTIVE EXTRA APP OTA UPDATER
(perform this step only the first time)
Team Member FoxHound Factory Extended
Me Developer Rom
ToxicOne Themer Rom
ApriliaM3 Big Member Team
Me Developer Rom
ToxicOne Themer Rom
Gokhan
Vertumus
ApriliaM3
Sicopat
_JKay_
89luca89
Waman
Gowind
Lidroid
Matriak31
ToxicOne
