[Sammy-ROM] *01.06.12* [XWLPF]FOXHOUND Revolver Ocelot|ICS|OTA|Performance|Siyah
  • 112 Antworten
Based on the latest official firmware 4.0.3 XWLPD NO WIPE
Deodexed
Zipaligned
Optimized
Themed ICS Domination + personalization’s
Siyah Kernel Last
Removed some Samsung apk’s
AOSP Launcher Apex
AOSP GoogleGallery
AOSP Calculator
AOSP Live wallpapers
AOSP Keyboard Themed Black
AOSP Sounds/Notifications/Ringtones
AOSP Voice Dialer
AOSP Music Player
Insert FoxHound Bootanimation
Added AppWidgetPicker
Added Ad-blocking via hosts file
Added Status Bar Power Widget 15 icons shortcut Thanks Lidroid/Wanam
Insert fix text for Toggles and translate for Italian people
Fujutweaks-> Taken from Latest ICS 4.0.4 build
Sysctl.prop added MANY Tweaks for Memory and Resource Management
Tweaked Speed of Memory card
Phone with Call Recording & No Incremental Ringtone
Noise Suppression enabled
Enabled Conference Call support (Thanks wanam)
Talk black
MMS no MMS auto-conversion -200 contacts per SMS and correct send time stamp
Remover SMS in Call Log
TW Launcher from Galaxy S III
S-Voice from Galaxy S III
Camera Volume Up&down Shutter
MMS Samsung ICS theme
Inverted Music
kahvitahra Mods:
- Torch from lockscreen
- 4-Way reboot mod
- Skip songs with volume keys
- Home button lag fix
- ICS lock on/off
- “Swipe to unlock” -text on/off
Quelle: http://forum.xda-developers.com/showthread.php?t=1162715
Reaktionen: Serioussnape
Meine absolute Lieblings-Rom! :thumbsup:
Habe mal den Thread-Titel angepasst... ;)
Neue Rom :-D
EDIT: Sehr geil die installation! Full/Light/Custom - man kann sich bei custom dann den kernel aussuchen und das modem und noch einige andere sachen, gefällt mir sehr gut :)
FoxHound Revolver Ocelot LPF ICS GSII
Changelog
Based on the latest official firmware 4.0.3 XWLPF NO WIPE
Deodexed
Zipaligned
Optimized
AOSP Launcher Apex
AOSP GoogleGallery
AOSP Calculator
AOSP Keyboard
GSIII Stock themed
GSIII TW Launcher
GSIII Sounds/Notifications/Ringtones
GSIII Dialer themed
GSIII wallpaper
GSIII Widget
Apollo Music Player
Fix CRT animation from xda
Insert domination theme in Aroma installer for jkay UI and framework
And moreeee
Jkaymod: (use apk for full mod)
+ 18 scrollable quick panel toggles incl:
‘Do not disturb’ quick settings button (the notification toggle from tablets)
‘Screen on’ quick settings button (temporary 3 mins of screen on)
‘Auto brightness’ quick settings button (long press to adjust brightness and auto-brightness using a slider)
‘Mobile data’, ‘Airplane mode’, ‘Vibrate’ toggle, Wi-Fi hotspot, Sync, Flashlight and the 4 reboot toggles
Long press on these toggles to go to settings!
+ Original ICS lockscreen
+ Live wallpaper support on lockscreen
+ 6 bars for GSM signal
+ Custom date format on status bar
+ Next Alarm Info on drag bar
+ Transparent statusbar on lockscreen
+ Redesigned Samsungs WiFi icons as I did not like the ICS look from Samsung!
+ Separate Wifi In/out arrows
+ Removed leading zero to hour on status bar (to changed ’09:00′ to ’9:00′)
+ Semi transparent connection icons
+ ‘Fast screen off’ to turn the screen of faster!
+ Toggle flashlight by long pressing Home button on any lockscreen!
+ Toggle sound on/off using volume buttons on any lock screen
+ Disabled ‘Battery full’ notification
+ Disabled ‘Bluetooth’ notification
+ Long press volume buttons to skip track (when music is playing and screen is off, and note: this also works when you have set lockscreen to None!)
+ Connection icons are green when fully connected to google servers
+ Battery with percent (100 steps plus 100 steps charging)
+ Added ‘Reboot to Recovery’ and ‘Reboot to Download’ to the phone dialog panel
+ Enabled fast double click (350ms instead of 500ms)
+ Enabled CRT off effect when screen off
Wo kann ich beim TWLauncher einstellen das sich das Hintergrund beim scrollen nicht mit bewegt? Möchte es schön zentriert haben.
Ich war mal so frei und habe schon mal den Thread-Titel angepasst... ;)
Doofe frage aber wie kann ich ein Screenshot machen?
Home + Power Button
Siehe auch: [OFFURL]https://www.android-hilfe.de/faq-haeufige-fragen-zum-samsung-galaxy-s2/249022-samsung-galaxy-s2-screenshots-erstellen.html[/OFFURL]
Gute Rom läuft nur hat die leider kein Multi DPI Dialer sonst Top im S3 Style.
Kann man das irgendwie deaktivieren das der Bildschirm bei einer SMS nicht angeht sondern nur BLN?
Bei mir geht nur der Bildschirm an aber kein BLN möchte das andersherum haben.
Moin,
hab mal ne frage und zwar bin ich blind oder fehlt in dieser Rom der Musik Player?
Das hier Apollo Music Player ist der Player in der Rom.
Lg
Lg
Der fehlt mir leider.. was kann ich machen?
Hier ist die Apk von dem Player :)
  • com.andrew.apollo-1.apk
Abend,
Ich habe mich jetz auch mal bei euch registriert..:cool2:
Vorab Vielen Dank an den Ersteller des Threads hier auf android-hilfe^^
Ich würde es für großartig befinden, wenn besagter Thread Ersteller
ebendfalls die DEV´s ( Crew-Member. ) mit in seinem StartThread erwähnt!
Team Member FoxHound Factory Extended
Me raffaele88
Developer Rom :p
ToxicOne Themer Rom
ApriliaM3 Big Member Team
Und das nicht nur weil ich einer von Ihnen bin..:winki:
Gokhan
Vertumus
ApriliaM3
Sicopat
_JKay_
89luca89
Waman
Gowind
Lidroid
Matriak31
ToxicOne
Vielen Dank & Viel Spaß mit dieser Custom Rom!
Beste Grüße toxicOne
Wann kann man mit einem neuen Update rechnen? ^^
Wir Arbeiten derzeit an einem Update!
Grüße toxicOne
Reaktionen: Infuso und Serioussnape
Habe die erste Seite Aktualisiert
Reaktionen: Infuso, toxicOne und mecss
Ist das nur bei mir so, oder lässt sich das Bild vom Lockscreen nicht ändern? Bei mir ist das immer das Bild, was ich als Hintergrundbild habe.
Habe schon so ziemlich alles versucht, um das Bild zu ändern.. bleibt aber immer das Selbe.
Danke im Voraus!
In der Google-Galerie ein Bild aussuchen und dann gedrückt halten, dann rechts unten auf "Optionen" und dann "einstellen als" und schlussendlich als "Sperre-Hintergrund" auswählen...dis woas... ;)
Danke für die Hilfe!
Allerdings hat das auch nichts verändert. Schade
rewesun
Steveria
Steveria
debaki
debaki
debaki
beicuxhaven
wolfia
