eybee1970
Philosoph
- 5.255
LeoMar75 Rom Revolution v.2.7.1
Download:
1. Kitchen App (zu finden im im XDA Thread [ROM] [XXKI3] LeoMar75 Rom Revolution v2.7.1 - Kitchen App - xda-developers)
2. Link LeoMar75's roms for Galaxy s2 (LeoMar75 revolution) | QA from Celogeek
wollte Euch diese ROM nicht vorenthalten....es ist genial!!! Das beste: der Stock-Browser funzt wieder vernünftig und auch sonst sehr schnell, stabil und akkuschonend:
Link zum Original-Thread auf xda: [ROM] [XXKG6] LeoMar75 Rom Revolution v2.4 - Kitchen App - xda-developers
Details:
Flash Anleitung hier ----> https://www.android-hilfe.de/forum/...355/howto-flashen-von-custom-roms.124639.html
Fix - Schrift Notification Bar -->
xda-developers - View Single Post - [ROM] [XXKG1] LeoMar75 Rom Revolution v2.1 (Browser with HW acceleration)
__________________
LeoMar75 schrieb:[ROM] [XXKI3] LeoMar75 Rom Revolution v2.7.1 - Kitchen App I am pleased to present my Revolution Custom ROM!
you will notice something special in my ROM as the RevolutionRom Kitchen App - Build your Rom as you wish!![]()
(new) Video review 2.5 (in italian)
Revolution Rom v2.7.1 Base
- Based on the latest firmware XXKI3 Gingerbread 2.3.5
- Fully deodexed thanks to Brightidea & JesusFreke for fixing smali/baksmali tools
- Kernel CF-Root-SGS2_XX_OXA_KI3-v4.1
- Arabic support + RTL reading/writing + Samsung Keypad and Swype (available in the Kitchen)
- Overscroll glow (by default)
- Revolution boot animation + custom sound
- Revolution Wallpaper Chooser
- SIP over wifi and 3g
- HTC headset support
- Extended power menu (it's not customizable since i am waiting for the new Jkay v11 release)
- Init.d Scripts Optimizzation (added Juwe11's Ram Tweaks)
- Enhanced Buid.prop config (new tweaks..)
- Google Talk with Video (Kitchen app)
- Multi CSC (XEU, XEO, XEF, KOR, ITV, DBT, CPW)
- CRT Screen off animation fixed
- muveszur's Mms.apk mod
- * no auto converting messages to MMS after 4 SMS.
- * possible to add to the message 200 contacts instead of 20 contacts.
- * display sent time instead of the received time (as option on Rev. App)
- Samsung apps/widgets have been removed
- Quick fix GPS Europe (for other Countries please use FasterFix application)
- WiFi supplicant scan interval has been increased to minimize battery drain. This only affects the case in which there are remembered access points, but none are in range.
- Proximity sensors delay (reduced), changed the time it takes for "black screen" during calls to go away after removing device from face.
- Dalvik Virtual Machine enhanced configs
Brand new Kitchen Plus App has been developed (second post for further details)
Special thanks to these guys to share their knowledge: geistteufel & hunhool (Server Hosting), nikademus (FuguTweaks), kahvitahra (Custom Date Format and DT Tweaks porting), potatoman, _JKay_, juffo, socket84, mobilegalaxy, Zheiko, KLoNe1, lynx2k50, scheichvwe, jazzor, saturn_de.
(If i left you out please let me know and i will add you in the list. Please leave a comment if you'd like to have a donate link in my page)
How to install - Use RevolutionROM Kitchen
Note
Download - LeoMar75 Rom XXKI3 v2.7.1 Revolution CORE BASE
- Make sure you have the latest Revolution Rom kitchen running in your phone
- It may happen that after a package has been installed from the Revolution Kitchen Pro app, on the first boot you phone hangs at the Revolution logo, just long press power button and restart your phone!
- I'd like to point out that i am not responsible for any issue with your phone! Also it's highly recommended to backup efs folder before to start playing with your phone!
Use the Revolution Kitchen Pro in order to automatically download and install any new incoming Roms version!Troubleshooting![]()
Are you coming from another ROM?
No worries, make sure you have a CWM Recovery and use the RevolutionRom Kitchen
If you have some problem you can also use the following links:
Mirror#1
Note:
This is not a full wipe ROM, you won't lose apps, accounts, WiFi passwords, sms, etc
However is hightly recommended a full backup of your system!
Nothing so far
Thanks Meter 2756
Recognized Developer |OP|
The Following 279 Users Say Thank You to LeoMar75 For This Useful Post: Show/Hide
LeoMar75![]()
16th July 2011, 01:42 PM![]()
Brand New Kitchen Pro Application has been developed my me!
Version: v1.05 (Original Logo)
updated on 09/22/2011 3.20 PM
Screenshoots:
ROM Changelogs
Changelog v2.7.1
- Installation script has been fixed (issue with some permission)
- Fixed "su" (problem with TI Backup and superuser 3.0)
- Removed tweaks in build.prop for WiFi (in accorder to me this tweaks results in bad signal) also removed some DalvikVirtualMachine config:
Code:
dalvik.vm.execution-mode=int:jit dalvik.vm.dexopt-flags=m=y- Fixed issues with black screen on Application FC (hopefully we do not have anymore FC for phone and so on)
- Fixed the Login issue with Stock Samsung Email
- I can't remember other stuff i have modified...
ROM Changelogs
Changelog v2.7
- Added back USB HOST and USB OTG (this wasn't included on the 2.3.5 OS)
* display sent time instead of the received time (as option on Rev. App)- Samsung apps/widgets have been removed
ROM Changelogs
Changelog v2.6
Changelog v2.5
- Based on the latest firmware XXKH3 Gingerbread 2.3.4
- Added cf-root KH1 Kernel as default
- Proximity sensors delay, changed the time it takes for "black screen" during calls to go away after removing device from face.
- Overscroll glow
- Extended power menu (it's not customizable since i am waiting for the new Jkay v8.1 release)
- Plus everythings you can see to the kitchen Revolution App
Changelog v2.4
- Added angelom Tundkernel 22 (it supports ntfs usb mount like cf-root)
- Added BLN control for stock Samsung Mms
- Added XEU CSC
- Added modules for ntfs external drive mounting support
- Added scripts for mounting and unmounting ntfs usb drive
- Added GscriptLite app (needed for mount and unmount)
- Added Revolution theme v3 Circular battery mod with support for EDT Tweaks
- Included EDT Tweaks,BLN Control, Jkey Theme settings in /data/app
- Reverted back home wakeup..
- Enabled sip voip by default
- installation script has been modified it won't wipe your batterystats even if this rom is fullwipe!
- Added Samsung keyboard with 'all' available languages.. (still working on it
- Fixed Jkay Themesettings app, now you won't loose settings after reboot!
Changelog v2.2
- Based on the latest firmware XXKG6 Gingerbread 2.3.4
- ninphetamine Kernel 2.0.2
- Multi CSC added
- Revolution themed
- New JKAY ThemeSettings V7 app is fully supported!
- Lockscreen (AOSP JKAY Deluxe, Samsung stock, Glass Deluxe)
- Fully customizable Extended Power Menu
- Revolution Bootanimation + sound (thanks to Zheiko)
- Added working OpenVPN support (now it works with Ninphetamine-2.0.2 Kernel)
- Added working wpa-supplicant ad-hoc
- Added VOIP for Wifi
- Removed Samsung Apps/Widgets
- Stock Phone.apk
- Bluetooth audio fix
- Added mod to support HTC headphones
- CRT Screen Off fixed
- GTalk with Video Working!
-Based on the new XXKG2 firmwareChangelog v2.1
-Fully ODEXED Rom!! ( super fast and less memory compared to the deodexed one)
-Framework has been optimized and compressed
-New Angelom Kernel 10.0 (changelog ASAP)
-Added Call rec Mod
-Fixed CRT-Screen off (pixelated Animation)
-Fixed Extended status toggle bar (text displayed over icons)
-Modded stock Loockscreen (camera, Mms/Sms, Dialer, unlock)
-Complete Silent Camera
-OpenVPN is working now
-Reverted to old Market version (the new one is laggy and has still some problem)
-Added all features as per XXKG1 (v2.1)
Initial release! (on XDA)![]()
sind 'nur' Änderungen in der systemUI.apk und der framework-res.apk...
