The Revolution app, will automatically update the displayed option based on the new content uploaded on the server.
For now i prepared the following package (of course if you like to have something else i will try to do it)
-Restore/Backup/Delete Bloatwares from the application
-Rom Themes:
*Revolution Theme v1.0
*Ginger Theme v1.0
*Ginger Theme - Orizontal Battery Mod v1.0
-Market Themes (Old Market Version)
*Black
*Red
*Blue
*Green
-Revolution MODs
*Remove sound notifications for full charge and minimum charge battery
*No boot sound animation
*Remove txt/mms/emails from call logs
*Adv Block Patch
*Gps FastFix Europe (for now it's hardcoded later on will automatically detect your country and config your gps.conf automatically)
*MMs sent time Patch (Display sent time instead of the received time)
*Phone Call Rec Mod + No ascending ringtone (all languages support)
*Potatoman Silent Camera
*Transparent Widget Weather/Clock
*Samsung Stock Boot Animation + sound
-Revolution Apps
*The New Android Market Version
*Theme Settings V6
Kernel Options
*new angelom Kernel
*CF-root XX_OXA_KG3 v4.1
*Jame Bond Care Bear v1.7.3
*Ninphetamine v2.0.2
For now that's it, as i am not superman!!!
boshot schrieb:das gps is auf europa "eingestellt" das langt eigentlich schon.
gps kannst aber auf deutschland einstellen wenn willst, gibt threads dazu, musst halt über die forensuche schauen.
Der mythos der "gps einstellungen auf deutsch = schnellerer fix" wird sich wohl auch ewig halten..![]()
Leo Mar
Guys, we almost finished the Revolution App, in few hours i will test it, and then maybe we will be ready to use it!
In the revolution 2.3 Base Core, i didn't include init.d script because there will be an option in the kitchen as well!
loonyland schrieb:loonyland
hab noch den CRT Effekt vom Lightning und wundere mich ein wenig das er noch da ist nach dem Wipe
