[ROM] [XXKI3] LeoMar75 Rom Revolution v2.7 - Kitchen App
  • 4.447 Antworten
Wo kann ich Leomar 2.7 noch runterladen
So, dann flashen wir mal :)
Vielleicht jemand so nett, den Changelog hier zu posten ?
Revolution Rom v2.7 Base
  • Based on the latest firmware XXKI3 Gingerbread 2.3.5
  • Fully deodexed thanks to Brightidea & JesusFreke for fixing smali/baksmali tools
  • Kernel CF-Root-SGS2_XX_OXA_KI3-v4.1
  • Arabic support + RTL reading/writing + Samsung Keypad and Swype (available in the Kitchen)
  • Overscroll glow (by default)
  • Revolution boot animation + custom sound
  • Revolution Wallpaper Chooser
  • SIP over wifi and 3g
  • HTC headset support
  • Extended power menu (it's not customizable since i am waiting for the new Jkay v11 release)
  • Init.d Scripts Optimizzation (added Juwe11's Ram Tweaks)
  • Enhanced Buid.prop config (new tweaks..)
  • Google Talk with Video (Kitchen app)
  • Multi CSC (XEU, XEO, XEF, KOR, ITV, DBT, CPW)
  • CRT Screen off animation fixed
  • muveszur's Mms.apk mod
  • * no auto converting messages to MMS after 4 SMS.
  • * possible to add to the message 200 contacts instead of 20 contacts.
  • * display sent time instead of the received time (as option on Rev. App)
  • Samsung apps/widgets have been removed
  • Quick fix GPS Europe (for other Countries please use FasterFix application)
  • WiFi supplicant scan interval has been increased to minimize battery drain. This only affects the case in which there are remembered access points, but none are in range.
  • Proximity sensors delay (reduced), changed the time it takes for "black screen" during calls to go away after removing device from face.
  • Dalvik Virtual Machine enhanced configs
Problemlos mit der Kittchen App über Litening drüber geflasht, alle Einstellungen erhalten. Mal sehen...
Startpost + Thread-Titel angepasst auf v 2.7
Reaktionen: niknase und smosch
Hi was ist besser das Handy neu auf setzen oder über die App laden
und welche müsste ich beim neu auf setzen nehmen Die KH3 oder die KI3
lg
So, nachdem ihr alle so positiv von dem Leomar Rom berichtet habt, habe ich soeben über die Kitchen App das update gezogen und ohne fullwipe drüber geflasht. Ergebniss perfekt,
kein reboot, Daten alle übernommen, Apps alle übernommen, GoLauncher einstellungen übernommen. Bin mal auf die Akkulaufzeit gespannt, komme von der Exynos Rom 6.0!
Hab gerade geupdatet.. Läuft sehr smooth..
Kann ich jetzt trotzdem den Nimphkernel flashen?
Oder geht zurzeit nur der Cf-kernel?
Bei mir hat sich wohl alles zerlegt nach dem update auf 2.7 über die Kitchen...
Bei mir bleibt mein SGS beim Startscreen stehen kommt nichtmal zur Bootanimation.
Recoverymodus geht noch aber habe aus Eile kein backup gemacht.
Hat jemand Rat ?
oder muss odin ran ?
Ja kannst du
Reaktionen: gRe
Hat jemand Rat ?
ins recovery gehen Wipe Sache und Dalwik dann wieder neu flachen (zip Datei liegt in download Ordner)
Reaktionen: chris2603
Hat jemand Rat ?
Versuch erstmal nen Fullwipe. Wenn es dann nicht startet eventuell nochmal über Pc runterladen auf die Sd karte schieben und nochmal Flashen. Wenn das auch nicht klappt dann halt Odin. Denk mal der Fullwipe dürfte funktionieren. Oder beim Download ist was schief gelaufen.
Pech ist nur das die Daten dann weg sind. Also deine SMS/Apps und Einstellungen.
Viel Glück
Habe ich gemacht also, wipe cache und wipe Dalwike hat nich gereicht habe nochmal.zip drüber gehauen hmmm...
werde nochmal factory reset probieren..
Servus ... bei mir alles supi version läuft smoothi! kannst updaten leomar 2.7 bringt eigenen kI3 kernel mit somit ist dein nymphitamin kernel überflashed! Passt auf das ihr die aktuelle kitchen habt! einfach in der kitchen unter einstellungen ganz recht unten auf "download rom" klicken dann seht ihr ob er euch die leomar 2.7 anbietet!
Liebe grüsse von der wiesn in münchen
sophie
also bei mir wird immer noch die v2.6 in der kitchen angezeigt.
Pr0TuRk38
Widar
Widar
nightwatchdog
Simuur95
Kjetal
Kjetal
