[ROM] [XXKG6] SensatioN 1.2
  • 14 Antworten
MadMurdoc
MadMurdoc
Ehrenmitglied
6.047
Hab vorhin ein wunderschönes ROM gefunden welches richtig schön anzusehen ist. Dieses will ich euch hier vorstellen :)
Hier mal ein paar Informationen.
In SensatioN ROM you will find a very stable and battery friendly ROM, but with awesome User Interface, featuring SensatioN 2.0 theme, developed specially for this ROM.
Because I wanted to solve once and for all the compatibility problems with different ROMs I decided to bring to life a new ROM along with SensatioN 2, so nobody will have problems applying using the theme.
The development has started on 1’st July and since then I made great efforts to bring SensatioN 2, SensatioN ROM for both Galaxy S and Galaxy S 2. I looked back for all the bugs remained unsolved in SensatioN theme and I tried to find a fix for each of them and mainly I succeeded doing that.
Designing the new theme was a challenge for me, as I had to take care of all the promises I made to the users regarding the visual parts they hated on SensatioN 1 and also I had to take care of my personal taste, as I hate to create something that I don’t like
It may not look much to you, but I have worked for over a month more than 10 hours a day, and If you would like to help me continue the development, show your support with a small donation. Thank you!
With this being said, the features of SensatioN 2 are:
Dropdown menu:
Transparent
Darker, so I can satisfy those who were afraid that the white menu eats battery life
New status bar
Removed AM/PM
Added Data Toggle 
Redesigned UI
Music Player
New professional layout
Properly fixed landscape mode(themed)
New layout for album art, with glass effect over images and rounded corners
New buttons layout and visual elements
Dialer
I have redesigned the layout; a black version comes soon
New dock with reflection for calling buttons
Proper landscape mode this time
Phone
New calling panel
Larger caller image than before
New design
Framework
Created new panels
Integrated extended power menu with removed header for all languages
CRT animation
Thinner volume bar than before
Replaced almost all important elements with brand new ones, created by me
Fixed loading circles
Faster loading animations
1% battery and charger (good old evolution – when I will have time I will come with a new one, but for now I will be keeping this one )
ROM features
• Based on KG3 firmware (KG3 MODEM)
• Deodexed
• Zip-aligned
• Extended power menu
• CRT animation
• Ninphetamine 2.0.2 kernel
• Removed Samsung hubs
• Rooted + SU by Kernel
• TW4 alphabetically sort
• Removed Samsung Hubs
Tools added to the ROM
• Tiny flash light
• Flash Player 10.3
• XDA App
• Android Market 3
• SensatioN Help
Hier einige Screenshots:
CHANGELOG
07.09.2011
-fixed phone rotation
-browser with user agent setting thanks to intronauta
-Jkay 9.1
-fixed wrong text
-new camera with no sounds thnks to potatoman
-removed chargin sound
-volume sound back
-the new battery
-new statusbar background
-removed zeam launcher
-TW 4.5 as default
-fixed widgets and missing apps
-MMs without conversion to Multimedia Message thank to muveszur
-Added CWM manager
-remove sound from discharge notification
-fixed the bluettoth icon confusion
-added gingerbread keyboard
-old market
22.08.2011
-No Wipe fixed properly (checked personally and 2 testers)
-Added missing apps (DLNA and stuff)
-Proper RTL support
-Patched android.policy.jar for faster wake up
-Fixed Google Maps
-Fixed Swype
-Fixed the graphics for pop-up boxes (like the recent apps header)
-Old Touch Wiz Launcher, themed
-Added Zeam Launcher as an alternative
20.08.2011
-Based on XXKH3
-ninphetamine 2.05 kernel
-Added back original Tw4 sorted alphabetically to fix widget problems
-Added new icon pack
-Updated youtube app
-small framework images fixes
-new Phone.apk with call recording + themed landscape
-Added JKAY's MOD
-3 LockScreens
-Customisable extended power menu
12.08.2011
-Fixed browser
-Fixed dialer letters (no more shadow)
-Fixed Dialer small font problem
-Changed kernel to ninphetamine 2.05
-Fixed FC on phone.apk when open conference call
-Arabic support integrated in the fixed framework.jar
-Added TW4.5 Launcher by Fr4gg0r
-Removed BuddiesNow as it FC's with TW4.5
-NO-WIPE version with Criskelo's scripts
-Small update pack for 1.2 to 1.3
03.08.2011
-Integrated Ninphetamine kernel 2.04 (BLN READY)
-Integrated BLN app by neldar
-Wipe/No wipe versions with fixed scripts
-Integrated RTL support provided by Death_Keeper
01.08.2011
-Based on KG6 (kg6 modem)
-all samsung apps back
-added Maps 5.8 with online navigation
-Talk 2 with video
-maybe something else but I don;t remember.
31.07.2011
-Initial release
Download:
Wipe Version
UPDATE PACK - USE OVER SensatioN 1.5
Installation:
Für Leute die noch kein ROOT haben:
1. Downloaded Odin und den CF-Kernel
2. Schaltet euer Telefon in den Download Modus. Schaltet es dafür aus und drückt dann Vol - und Power und Home
3. Packt die gedownloadete zip bei Odin unter PDA und flasht
4. Lasst das Telefon rebooten
Wenn ROOT vorhanden ist:
1. Rebootet ins Recovery wenn ihr das ROM auf den Speicher des Telefons gepackt habt
2. Install Zip from SD Card -> Choose ZIP from SD Card
3. Wählt dor das SensatioN ROM aus und bestätigt mit yes
4. Lasst das Telefon neustarten, und wartet bis es komplett durchgebootet ist, kann etwas dauern
Habt ihr einen Bootloop, versucht einfach die nowipe Version zu flashen.
Sonstiges:
Hier der originale XDA-Thread
Ich werde vielleicht noch eine Version hochladen ohne Samsung Apps. Da dieses ROM mit ausgeliefert wird. Ich persönlich mag keine Samsung Apps daher würde ich eine Version hochladen und anbieten die nur die Samsung Apps nicht mehr hat, für all die jenigen die keine Samsung Apps nutzen möchten.
Reaktionen: Paefix
Hm ok. Aber ich hatte nach einem Diskussions thread gesucht und keinen gefunden gehabt. Vielleicht kann man das hier ja genau dafür nutzen. :)
Gesendet von meinem Samsung Galaxy S2 mit Exynos 3.6
gibt es das auch auf Deutsch?
Jap. Entweder stellt es sich selbst beim ersten Start auf deutsch oder du stellst es ein.
Stimmt gab noch keinen diskussion thread von daher passt es :)
Sent from my GT-I9100 using Tapatalk
Finde ich auch nicht schlecht. Gefällt mir vom Theme her ganz gut.
Hatte auch schon länger überlegt, dass mal auszuprobieren. Bin aber derzeit eigentlich sehr zufrieden mit meiner Config.
Mal sehen, vielleicht habe ich mal Langeweile. Kommt selten vor, aber manchmal klappt es. :)
naja ich habs mal drauf gemacht!
Viele Änderungen sind da nicht zu sehen, ähnelt sehr stark den Original ROM!
Ich bleib lieber bei meinen schönen MIUI!
@Kjetal
Muss ich heute Abend nur noch mal kurz überarbeiten dann passt das auch besser. :)
@Mimmo
Nun das liegt sicher daran das es ein gemodetes Samsung rom ist. :D
würd ich gerne als theme für die RevolutionROM Kitchen haben. ;)
Mittlerweile ist schon version 1.5 draußen, auch wenn der Thread Header auf 1.2 zeigt :D
Also das ganze sieht echt schick aus, müsste man mal testen...
bin noch relativ unerfahren was rooten und Custom Roms angeht. Ich habe mein SGS2 nach Anleitung mit dem CF Kernel gerootet und mir dann die Sensation 1.5 aufgespielt. Mein Akku wurde darauf hin ziemlich schnell leer. Deswegen habe ich mal den Jeffrey-SpeedFrey 3.0.0 Amazing battery life
draufgespielt, aber keine besserung. Kann das aa dieser Rom liegen? Der größte Akkuverbraucher ist mit Abstand das Android OS. Ich habe schon so gut es geht mit Titanium Backup Apps gefreezt oder gelöscht, die nicht unbeding laufen müssen.
Hat jemand ähnliche Erfahrungen gemacht?
Bert1323 schrieb:
Kann ich nicht bestätigen. Lief bei mir normal gut. Akku hielt ca. 1 1/2 Tage mit ungefähr 90min. Display, viel whats app und Tapatalk, ein wenig surfen, Telefonieren usw.
Ich weiss natürlich nicht was bei dir "schnell leer" bedeutet :)
Auf die anzeige von Android kannst du nicht viel geben. AndroidOS verbraucht nicht viel aber die Liste muss ja irgendwie 100% erreichen.
Damals hatte ich das ROM mit den nine Kernel, nutze eigentlich nur diesen Kernel und habe bis jetzt keine Probleme.
Gesendet von meinem Samsung Galaxy S2 mit LeoMar75 Rom Revolution 2.5
Deadboy
mecss
mecss
Gast5050
blasen187
