[ROM][SAMMY-ICS 4.0.3]MJ ROM-version 1.2[XWLP7_XENLP3][15.04.2012]
  • 4 Antworten
Deadboy
Deadboy
Greetings!
I have decide long enough and here i am, trying to build my own ROM and share with you guys.
I am still new in creating my ROM, yet i wanna challenge myself and try to have fun with it. To be honest, it is harder than i thought with no complete tutorial out there.
I am planning to start things slowly and learning as i go along. Thus, i start with the basic, modifying stock ROM, and de-odex them. Clear all the bloatware or what i think is not necessary.
Please take note this is just a trial. If you are interested, do try out, and let me know how or where i can improve. I am noob, please don't flame me.
Current Release
MJ ROM: Trial Version 1.2 - 15.04.2012
Firmware: I9100XWLP7
CSC: XENLP3
Kernel: current LATEST Siyah Kernel v3.1rc3 (dual boot supported
Coming Soon:
add in call recording feature
add in toggle bar - Postpone! Seems like Lidroid method will supercede my translucent status bar.
will fine other method to make both thing works.
planning to switch launcher, as i am not too fond with Apex (suggestion please)
create my own logo and bootanimation (might take times, still figuring out)
Beats audio, anyone? (some claim it doens't work, does it?
Change Log - trial version 1.2 - 15.04.2012:
latest siyah kernel v3.1rc3 with dual boot supported!
50% translucent status bar
open up hidden samsung cool wallpapers! more selection available!
add in cool boot animation (android destroy apple!)
add in big android battery mod - Done! All you need to do is to download the zip file from below link and flash it with CMW recovery option. Simple and easy.
Change Log - trial version 1.1 - 14.04.2012:
SuperSU (FULLY ROOTED NOW!
CWM with touch menu!
latest siyah kernel v3.1rc2 with dual boot supported!
old bootloader for use of USB jig (fully tested, remove yellow triangle and remove binary counter!
overclock to 1.4ghz
Change Log - trial version - 13.04.2012:
Apex Launcher v1.5 (Touch Wiz launcher remove due to force close)
Fully Deodexed
Zipaligned
BusyBox
SuperSU (not really working, i lost the root access, not sure why
NO WIPE
remove all bloatware and unnecessary apps
Benchmark scores for reference:
Quadrant Benchmark(1.2ghz): 3866
Antutu Benchmark(1.2ghz): 6399
WARNING: i have tried running overclock to 1.4ghz, but the score is opposite. i got very ridiculous low score in quadrant benchmark. bug in new firmware?
Don't try to overclock unless you know how to fix it.
WHO SHOULD TRY
-Those who want total stock ROM experience with root access,
-Those who is kind enough to train a new developer for S2 and keep the development alive!
Installation Guide
- Download the ROM (don't unzip)
- Copy the .ZIP file to your INTERNAL SD card
- Boot your phone into CWM (hold Vol Up, Home & Power Button)
- Wipe data/factory reset
- Wipe cache
- Wipe dalvik cache
- Select 'Install ZIP from SD Card'
- Select 'Choose Zip from SD Card'
- Then select the the rom .zip file you downloaded
- Reboot
Battery Mod Installation Guide
1. Download the Battery_Mod.zip.
2. Put it in your internal SD card.
3. Open CMW from your app drawer.
4. Choose "Flash update" (Flash and update .zip).
5. Browse for the Battery_Mod.zip file.
6. Flash it and enjoy!
DOWNLOAD
MJ ROM TRIAL VERSION 1.2 IS UP FOR FREE!
CLICK HERE TO DOWNLOAD
Download Big Android Battery Mod Here!
Screenshot as per below.
NEW Battery MOD with Big Android!
New screenshot for new release added (MJ - Trial version 1.2)!
Credit:
Currently quite busy with modification. Will add in every help i got from this xda shortly.
Credit back to respective developers!
Quelle:Klick
Guten Abend :D
Ich habe grade diese relativ "nackte" Custom Rom entdeckt, der Benutzer ist ein ganz neuer Rom Ersteller :) Ich lade mir die Rom grade runter und werde dann noch Screenshots und erste Eindrücke posten :) Nicht vergessen, das ist der erste Release, also give em a try :) Und geht nicht zu hart mit der Rom um :)
Der Link funktioniert einwandfrei, ist nur etwas langsam (bei mir zumindest :D)
Happy Flashing :thumbsup:
Startpost aktualisiert, V1.2 online :)
Moinsen,
kann mir jemand das Wallpaper, was oben gepostet ist, hier mal anhängen? Das sieht geil aus... :D
Keine Ahnung, ob das richtig ist.
Habe gerade nur mal auf die schnelle gesucht ^^
Reaktionen: mecss
Jo, dat is es... :thumbsup:
Thoddü
Thoddü
Deadboy
Jamen
debaki
debaki
debaki
