[ROM][KL1]Batista70 FOXHOUND EDITION 3.0|Jkay 13.4.1|Zoule Theme|10-01-2012 +RETURNS+
  • 394 Antworten
Regius
Regius
1) Copy the ZIP file (not unzip) Batista70 ROM memory of the phone sdcard
2) Unplug the USB memory and restart the phone in recovery mode
3) Now select the "Install zip from sdcard" and then the "choose zip from sdcard" and select the Rom Batista70
4) After the installation select the "reboot system now"
XWKL1 Batista70 FoxHound Edition 3.0
-Based on the latest official firmware 2.3.6 XWKL1 WIPE
-Deodexed
-Zipalinged
-Abyss 3.0 Kernel by Angelom
-Tw 4.5 English By Fr4ggor
-Browser NO Lag no Over scroll + User agent
-Added the Mod-Battery with incremental rate of 1%
-Delete the sound notifications full charge and minimum charge battery
-GPS Quick-Fix
-All Framework DEODEXED zipaligned and optimized PNG and has been compressed to save space
-Mms.apk no MMS auto-conversion -200 contacts per SMS – fixed received time thanks to (muveszur)
-Added the Mod rom to improve the bitrate audio / video
-Romoved the Wifi-sharing
– Added VOIP for Wifi
– Added multilingual T9 Dictionaries
– Camera Stock is better NOW on 2.3.6
-NEW Sony Bravia mod included to improve quality photo (really work)
-Sony Xloud enable to default to improve audio
-Improved Audio
-Transition animations ICS
-Updated hosts to eliminate advertising and web apps
-Phone.apk CallRec integrated (No Auto Rotation + No Increasing Tone ) FULL SCREEN
-Ringtones ICS
-Notification ICS
-New Market 3.4.4
-New Bootanimation SnakeS
-Video and Audio Gtalk Front Camera 2.3.6
-Torch app
-Last Titanium Backup app
-Gtalk app 1.3
-EmailWidget trasparent
-Added CWM app
-Removed some apk samsung
-SparePart plus
-Agile Lock
-Zoule B&B theme included
-App Manger (includes many mod to customize)
-DSP Manager
-Clock Ice Cream
-Included DownloadALL app
-Ram Scrip added
-Included app_process and system_server from Android(improves scrolling)
-Build.prop tweaks
-Jkay 13.4.1
-NEW Pulldown Animation in StatusBar
Abyss Pluss 3.0
Thanks Zoule and Gowind For support and
Test ROM
AOSP theme FoxHound 2.2 Download
AOPS theme universal - work fine FoxHound 2.1 Download
AOSP Theme only for FoxHound 2.0 Download ---- preview
Zoule's Theme for FoxHound 2.1 Download and prewiev
Blak blue theme by lexullde HTC Mania Download and preview after install theme flash this (9scroll)Download
Stock Theme Universal fix Download
SistemUI clock white by zoule HCo foxhound 2.0 Download
Theme Style 2.7.2 UNIVERSAL ROM Download
Battery C Style universal
Bubble Battery Universal Download
Space Battery Universal Download
Ubuntu Fonts flashable to recovery (more big) Download --- Preview
Bootanimation Batista70 Download --- Preview
For Expert on SetCPU
If you want longer battery life, I recommend using SetCPU set the frequencies that are suitable for your chip
My configuration is:
25MHz - 800 mV
50MHz - 825 mV
100MHz - 850 mV
200MHz - 875 mV
500MHz - 950 mV
800MHz - 1025 mV
1000MHz - 1100 mV
1200MHz - 1250 mV
Min 50Mhz - Governor OndemandX
Test for now)
Please note not all processors support this frequency,so this is not good configuration for all,each processor has its own frequency, so you have to try try try until you find the optimum configuration for your chips
GUIDE FOR ACTIVE EXTRA APP OTA UPDATER
(perform this step only the first time)
Changelog FoxHound 2.7 No wipe
No Wipe
Includes Jkay13.1
Flashing script runs a global fix permissions at end of flashing to avoid Permission management issues (Thanks Androimeda Team ROM)
New ICS animation included (thanks Capez)
Added Fujutweaks (2.3.7 app_process & system_server)
Added CyanogenMod libsqlite.so and libsqlite_jni.so
Added script to remove lag when answering phone calls [Test]( Part ThunderBolt tweaks )
New BLN app
Fix lag to recorder 1080dpi [Test]
Trasparency Mms.apk to stock ROM
Change Battery icon
Changelog Foxhound 2.6
Based on the latest firmware XWKJ3
Added new Abyss 2.0 Pluss:
-Changedrange frequencies:
-25-50-100-200-500-800-1000-1200-1304-1400-1536
-Frequency boot and 1200-200 standard voltages for compatibility
-Added tweak to the screen sharpness
-Revamped all governor
-Updated BFQ i / o scheduler to version 3
-memcg fix
-added tweak to GS2
-Fix Usb thetering
-Fix Kies drivers
Removed script Undervolt (now you do not have bootloop)
Posted Polar Office
Email app Samsung restored
Adding Keyboard gingerbraend in SDCard
All functions including the 2.5 Foxhound
HTC Keyboard (not installable to recovery)Download
1_Fix_Clock_FoxHound per FoxHound 1.0 by Guidox: Download
Fix Alarm clock 3.7.5Download
Calibrate Battery fix drain
-Charge the phone fully charged (100%)
-Download this application from the Android Market: Battery Calibration
Make-download the phone will never connect to PC USB charging otherwise ..
-Do a full charge without interruptions.
-After a few-cycle charge / discharge the battery should be recalibrated
If you also want to put my signature, copy this code
Code:
http://img257.imageshack.us/img257/2470/firmafoxhound.png
esk02k
Gorran
LeoMar75
Sicopat
Paul Modaco
ZeuBug
Angelom
_JKay_
89luca89
fenomeno83
Waman
Gowind
Sileshn and Lidroid
Matriak31
Ein gutes stabiles ROM das zu 100% eine gute alternative zu Leomar oder Litening ist.
Reaktionen: SGS II, mg140981, Simuur95 und 6 andere
@Regius,
Die Rom habe ich heute installiert und bin begeistert wie sauber und schnell diese rennt. Der Explorer ist sehr schnell im Gegensatz zur Litening v6.1 und auch so ist einiges besser gelöst. Also eine gute, ja sehr gute Alternative. Habe im Forum gelesen das man bei der KI4 die JIG USB Funktion des Counter resetten ausgehebelt hat?
Dieses konnte ich nicht erkennen und konnte bei KI4 ebenso meinen Counter wieder resetten. Also ich kann die ROM Batista70 wirklich wärmstens empfehlen.
:thumbup::thumbup::thumbup:
man kann es per software nicht fixen mit dem counter resetten, grund ist einfach das der counter auf ein flashspeicher liegt was man mit software nicht resetten kann, der usb jig kann es nur weil ein kleiner kurzschluss entsteht der den flashspeicher wo der counter liegt komplett resettet wird.
man müsste schon nen anderen micro usb anschluss einbauen damit das nicht mehr geht.
ja iss schon klar.
Mich wunderte die Aussage in Zusammenhang mit dem was du beschrieben hast und daher konnte ich es nun dementieren.
moin^^ wollte es für alle nochmal sagen nicht das irrgend jemand fragt das habe ich im miui thread schon genug^^
Joooo habe ich auf dem Zettel und bin auf dem Laufenden. Manche Wortwahl war nicht so pralle, aber nun man sollte es nicht so Ernst sehen und cool bleiben.:thumbup:
Ist es bei euch auch so das die 1200er zeit so hoch ?
Akkuverbrauch ist aber gut bin bei 95% bei 30min display
Habe mir heute auch das ROM geflasht, bin aber wieder auf die letzte Version von Batista70 (...7.7 Fixed Final) zurück gegangen, weil nach nem Reboot die SIM nicht mehr erkannt wurde, auch nach mehrmaligem rebooten. Bin auch von der Lite'n'ing6.1 zu Batista70 gewechselt, weil das ROM echt viel flüssiger läuft, Spare Parts+ drauf und die Animationen auf fast...ist echt ne Rakete. Mir gefällt der neue TW Launcher mit dem 5er Dock. Leider ist die Sprache in den TW-Settings auf italienisch, geht aber, meine Frau kommt aus Sizilien... :) . Die Batista ROMs sind auf jeden zu empfehlen!
Neue Rom wird heute veröffentlich...
27/09/2011 XXKI3 Batista70 Foxhound Edition 2.0
-Based on the latest official firmware 2.3.5 XXKI3 WIPE
Deodexed-
Zipalinged-
- Kernel 1.6 Abyss By Angelom
• Adding CW Recovery 4.0.1.5
• Added patch's zimage
• Prevention revive syscall due to multiple
• Fix wrong address after relocation SP kernels
• Changed the levels of brightness
• Added patch EXT4
• Adding classic RCU
• Change the tuning options
• Added support MDNIE
• Lowered the value of the automatic brightness
• Added smartass governor
• Added V (R) I / O scheduler
• Based on Samsung kernel Update2 Source (XXKG5) + adj. 2.6.35.11
• Updated to version XXKH3 initramfs
• Fixed problem vibration degradation
• Fixed problem proximity sensor
• Fixed problem WiFi
• Fixed Deep Sleep
• Change frequency (Available: 1536, 1400, 1304, 1200, 1000, 900, 800, 600, 500, 300, 150)
• Voltage adjustable via SetCPU Table (up to 1.5 volts), the voltages are standard default
• Posted ReadAhead tweak
• Updated to version 3 JHash
• Added small tweaks in the Conservative and Ondemand Governor
• Modified Table range and improved contrast and sharpness
• Added fix multitouch
• Enabled ThumbEE
• Enabled by default BFQ V2 I / O scheduler (possible noop, deadline, CFQ, BFQ, v (r))
• Enabled BLN (activated by the application BLN Control)
• On Interactive Governor
• Submissions: Form cifs.ko, tun.ko, fuse.ko, ntfs.ko, nls_utf8.ko
• Changed value of polling battery
• Added custom boot screen
• Submissions and Battery Memory Tweak
• Added ability change GPU clock
• Configuration Optimization
• Imported tweak the kernel to save battery Abyss AOSP
• Changed the kernel optimizationAdded OndemandX Governor
• Added Simple I / O scheduler
• Posted Tweak for Touchscreen
• Added SmartassV2 governor
• Added InteractiveX governor
Tw-Italian 4.5
Old-CRT-TV Fix
-Added Overglow
Multi-CSC
-Black and Blue Theme
Browser-NO Lag
-Added new fonts
-Delete the sound notifications full battery charge and minimum charge
GPS-Quick-Fix
All-Framework DEODEXED zipaligned PNG and optimized and compressed to save space has-been
With Gtalk-Submitted Video
-Modified the app Mms.apk:
• Added The blue theme Transparent
• Added New emoticons
Added the Mod-ROM to Improve the bitrate audio / video
Romoved-the-Fi sharing
- Added VOIP for Access
- Added multilingual T9 Dictionaries
- New Hack Camera (take pictures by pressing VOL + / -, Mantero focuses drop down takes the picture)
• support 1080p/30fps
• Better sound 64kbps/16khz -192kbps/44.1Khz meet the standards instead of mp4 and 3gp
• Ability to take pictures with a short touch on the volume buttons.
• Ability to zoom (pinch zoom) video mode by holding down the volume and sliding fingers.
-Improved Audio
-New functions loockscreen Jkay 10.1 (thanks to _JKay_)
Transition-animations
Updated-hosts to eliminate advertising and web apps
New phone.apk CallRec-integrated (No Auto Rotation Increasing Tone + + No boring suppression) Translate
Transparency-in contacts and text messages
New DialPad-transparent (thanks Criskelo)
New-Ringtones (FFVICTORY-fringe intro-melody-newborn-Sorcerer-Vanha-V for Vendetta)
New-Notification (confirm-long-silent-shotr speed.bubbles)
New Market-3.1.5
New-Bootanimation
Video and Audio Gtalk-Front Room 2.3.5
Transparent wather-Added Widgets
Adding-Torch
Adding Backup-Titanium
EmailWidget-trasparent
Added app-CWM
Removed some samsung-apk
Agile Add-Lock
Add DSP-Manager
Fix-red line instead of the call
New icons status-bar taken from Criskelo Rom
-Added ability to download youtube
Added to change font-Fontomizer thanks Guidox
Astro-Added file manager
Reaktionen: Simuur95, smosch und BlazinStylz
Ich finde den Link nicht zur 2.0, kann den jemand evtl. bitte posten...Danke!
Es gibt auch noch keinen Link dauert wohl noch etwas aber morgen ist ja auch noch ein Tag.Oder hast du Flash Entzug? :razz:
CRT-Effekt funktioniert nicht beim Bildschirm ausschalten. Reset bring nix und neu drüber/-flashen bringt irgendwie auch nix, kp :) aber egal nur ungewohnt mittlerweile :)
Ansonsten ein wirklich sehr sehr schnelles ROM. Warten wir mal auf die 2.0, da ja 2.3.5 nochmal 'n Tick schneller sein soll.
Das lässt sich in JKay settings einstellen.....
Reaktionen: Me-Virus
So habe die [ROM][KI4] Batista70 FOXHOUD EDITION 2.0 drauf sie läuft wie zu erwarten sehr schnell,habe einige Apps getestet und es gab mit keiner probleme.
Es ist die beste rom im moment und ich hab sie alle getestet...
Sent from my GT-I9100 using Tapatalk
Es läuft sauber aber das tun viele andere auch, dennoch ein gutes rOM
Hab die auch mla drauf, ist ganz nett und flüssig. Aber wieso synct der nicht alle meine Kalender? Ich habe Kalender von Freunden eingebunden, diese werden mir aber nicht angzeigt und stehen nicht zur Auswahl?
Es ist die/das(?) beste Rom!!! Ich habe fast alle getestet :D
Im Ernst: Akkulaufzeit scheint gut/normal. Ich finde, dass WLAN und der mobile Empfang besser geworden sind. Heute früh im Zug wurden die Seiten schneller geladen hatte ich den Eindruck.
Dann ist es noch extrem flüssig, die Auflösung ist höher (oder die Schrift kleiner??? Egal, sieht super aus), die Jkay Mods sind drin (heute entdeckt: Musiktitel Skip mit den Lautstärketasten!!!! :thumbup: )
Fazit: das beste Rom zur Zeit
Läuft bisher super das Teil. Aber ich hab immer noch das Problem, dass ich nicht die Kalender (Feiertage, Wochen, Geburtstage, Kalender von Freunden) angeziegt bekomme noch diese einbinden kann. Any ideas?
