[ROM][KL1]Batista70 FOXHOUND EDITION 3.0|Jkay 13.4.1|Zoule Theme|10-01-2012 +RETURNS+
  • 394 Antworten
Der Blueocean Theme wird wohl nicht kompatibel sein oder? Leider gibt es nicht grad viel Auswahl für Bastia, oder übersehe ich da was?
Einfach mal testen vielleicht eybees version für sein rom, aber ohne gewähr ich mag das batista theme.
XWKI8 Batista70 FoxHound Edition 2.2
-Based on the latest official firmware 2.3.5 WIPE
-Deodexed
-Zipalinged
- Abyss Kernel 2.1 By Angelom
• Added patch's zimage
• Prevention revive syscall due to multiple
• Fix wrong address after relocation SP kernels
• Changed the levels of brightness
• Added patch EXT4
• Adding classic RCU
• Change the tuning options
• Added support MDNIE
• Lowered the value of the automatic brightness
• Added smartass governor
• Added V (R) I / O scheduler
• Based on Samsung kernel Update2 Source (XXKG5) + adj. 2.6.35.11
• Updated to version XXKH3 initramfs
• Fixed problem vibration degradation
• Fixed problem proximity sensor
• Fixed problem WiFi
• Fixed Deep Sleep
• Change frequency (Available: 1536, 1400, 1304, 1200, 1000, 900, 800, 600, 500, 300, 150)
• Voltage adjustable via SetCPU Table (up to 1.5 volts), the voltages are standard default
• Posted ReadAhead tweak
• Updated to version 3 JHash
• Added small tweaks in the Conservative and Ondemand Governor
• Modified Table range and improved contrast and sharpness
• Added fix multitouch
• Enabled ThumbEE
• Enabled by default BFQ V2 I / O scheduler (possible noop, deadline, CFQ, BFQ, v (r))
• Enabled BLN (activated by the application BLN Control)
• On Interactive Governor
• Submissions: Form cifs.ko, tun.ko, fuse.ko, ntfs.ko, nls_utf8.ko
• Changed value of polling battery
• Added custom boot screen
• Submissions and Battery Memory Tweak
• Added ability change GPU clock
• Configuration Optimization
• Imported tweak the kernel to save battery Abyss AOSP
• Changed the kernel optimization
• Changed the kernel optimizationAdded OndemandX Governor
• Added Simple I / O scheduler
• Posted Tweak for Touchscreen
• Added SmartassV2 governor
• Added InteractiveX governor
• Changes in ondemand governor:
• Removed iowait-is-busy-queues tunable
• Added Samplig down factor tunable queues
• Minimum sampling rate set to 10ms
• Enable fast start
• Cpufreq: optimized (removed some unnecessary loops)
• Faster out of the deep sleep
• Optimized Jhash 3
• Modified Wireless: fixed memory leak in case of failure of dhd_bus_init
• modified TCP
• SLUB: Order slub_max set to 0
• modified workqueue
• EMMC put to sleep before the suspension
• Modified ondemand governor
• Modified driver vibration
• Added low-power idle notifier
• Other minor changes to improve compatibility
• Updated to 5.0.2.3 recovery CW
• Input-hotplug tweaks pm
• CK2 patch inserted
• added cpufreq scaling smooth
• ARM optimized algorithm RWSEM
-Theme Original Stock
-NEW Tw 4.5 English By Fr4ggor
-CRT Old-TV Fix
-Added Overglow
-Browser NO Lag
-Added the Mod-Battery with incremental rate of 1%
-Delete the sound notifications full charge and minimum charge battery
-GPS Quick-Fix
-All Framework DEODEXED zipaligned and optimized PNG and has been compressed to save space
-Submitted Gtalk with Video
-Modified the app Mms.apk:
• muveszur_Mms_mod full mod
-Added the Mod rom to improve the bitrate audio / video
-Romoved the Wifi-sharing
- Added VOIP for Wifi
- Added multilingual T9 Dictionaries
- Camera Stock is better NOW on 2.3.5
-Browser no lag with user agent
-Improved Audio
-Jkay 11 not included (for now)
-Transition animations
-Updated hosts to eliminate advertising and web apps
-New phone.apk CallRec integrated (No Auto Rotation + No Increasing Tone ) Thanks Leomar ---Translate
-New Ringtones(FFVICTORY-fringe intro-melody-new born-Sorcerer-V for vendetta-vanh)
-New Notification(confirm-long-shotr-silent-speed.bubbles)
-New Market 3.1.5
-New Bootanimation
-Video and Audio Gtalk Front Camera 2.3.5
-Adding Torch app
-Adding Titanium Backup
-EmailWidget trasparent
-Added CWM app
-Removed some apk samsung
-New Status Bar with 12 button (thanks sileshn and ledroid )
-Remove vibrate icon
-Add Agile Lock
-Add DSP Manager
-Fix red line instead of the call
-Added to change font Fontomizer thanks Guidox
-Added Astro file manager
-NEW Clock Ice Cream
-NEW Music player Ice Cream
-App removed flashable with this ZIP
DOWNLOAD 2.2 XXKI8:BATISTA70 FOXHOUD EDITION 2.2 WIPE
Theme Batista70 FoxHound Edition Download
Klingt interessant....werd ich gleich mal flashen...
Habe es mir auch schon geflasht und läuft gut zumindest was ich bis jetzt feststellen konnte.Wenn man das neue Batista Theme haben möchte muß man es mit dem 2ten Link laden und flashen ansonsten ist es das Stock Theme.
Nur darf man sich nicht Wundern das Baseband KI4 in den Telefoinformationen steht. Jkay Settings habe ich auf anhieb keine gefunden, so wie bei der 2.0 bzw. 2.1. Das nun die vielen Quick Settings doppelt sind genau obwohl man diese auch hat wenn man etwas länger auf den Power Button drückt find ich Persönlich nicht so toll.
Hat jemand eine Idee, wo ich den Foto-Editor und den Video-Editor herbekommen kann?
EDIT: Okay, hat sich erledigt...hab sie von einer anderen ROM genommen... ;)
Das mit den den schnellstartleisten ist wohl ein momentaner Trend bei einigen ROM`s. Meine Apps laufen alle hatte bis jetzt kein FC während des testens und GPS klappt auch wunderbar.
Ich hatte heut morgen mal eine anderes ROM drauf weil ich langeweile bei der arbeit hatte, das war ganz schnell wieder runter und Batista wieder drauf.
Ansonsten ist das Galnet MIUI von Sakaschi echt klasse,bis auf ein paar kleinigkeiten, aber leider macht er da im moment nicht weiter.
^Hi, dieses RoM hmmm,.. ist für mich momentan am interessantesten!! :blink:
Vorallem das Theme Update.zip (Theme_Batista70_FoxHound_2.2_Universal) gefällt mir gut, zum bearbeiten. Zeige morgen ein paar screenshot´s ,)
1.Grund, hat jemand schon bemerkt das die apk im (zip)entpakt sind ..ich konnte es zu erst nicht glauben und dachte das ist ein fehler jedoch funktionierte die Installation einwand frei!)) Die installation dauerte einwenig länger, es schien mir als würde es das zip wärend der installation compilen.:blink::ohmy:
2. So ist es noch ein bisschen einfacher das Theme zu bearbeiten:thumbup:
3. Guter gRund weiter zu testen..jeah..
p.s weiss jemand was der rote punkte ober halb der app, im apdrawer zu bedeuten hat...siehe..Anhang:confused2:
edit;
mfg poza
Das neue Theme ist nicht mein Ding, aber ansonsten mein Favorit
edit;
mfg poza
Der rote Punkt sind Apps die im Hintergrund laufen.
Reaktionen: Poza und BlazinStylz
Also ich bin gut begeistert. Hatte zwischenzeitlich mal das LeoMar drauf, weil das Batista ein paar Zicken gemacht hat, aber wo ich heute gesehen habe, dass es eine 2.2 Version gibt, konnte ich meine Finger nicht still halten...und es läuft klasse. Absolut glatt und schnell (dank Spare Parts+ :) ), alle Apps, außer der DSP Manager funktionieren einwandfrei. Habe mir AudioMasterPro für die Musik installiert, der DSP Manager lief noch nie auf meinem SGS2...hmmm, wie sieht das denn bei euch aus? Wifi und 3 G ist auch OK, im XDA wird die Geschwindigkeit bemängelt, was ich nicht bestätigen kann. Wundern tun mich auch die kleinen roten Punkte...keinen Plan. Das Theme habe ich mir auch gezogen, finde es super, ich stehe auf feine exakte Symbole. Alles in allem irgendwie runder und besser als das LeoMar, obwohl die Kitchen natürlich in der Praxis unschlagbar ist, aber ich glaube ich bleibe erst mal wieder bei Batista.
@m3dd0g...danke wegen den roten Punkten...ist gerade kein Danke-button da?!?
Welches Theme habt ihr gezogen?
Danke habs auf XDA nicht gefunden ...
mal wieder super arbeit mitn 2.2 vorallem der nachtmodus super idee, und der rote punkt damit man sieht was im hintergrund läuft. desweitern kann ich mal wieder nicht den Abyss Kernel 2.1 nicht mit installieren da bleibt mein handy im boot hängen wie im beitrag 186 im diesem thread.
was für kernel hab ihr so laufen und wie gut sind die mit diesem rom ( 2.2) ?
ich hab jetzt auch die 2.2 version drauf, hab mir aber wieder den abyss kernel 1.8.1 draufgetan, mit dem hab ich einfach die beste akkuleistung ( ohne UV oder sowas). weiss nicht voran das liegt, aber mit den nachfolgenden kerneln is meine akkuleistung eindeutig schlechter.
die Akku Prozentanzeige ist eher ungenau nicht wircklich immer um eins absteigend... könnte das Theme_Batista70_FoxHound_2.2_Universal schuld sein???
Bei mir deckt sich die anzeige mit meinem Batt App.
wieso eigentlich er schreib eigentlich :
"Added the Mod-Battery with incremental rate of 1%"
Hmmmm
Lehrer
FireS24208
beicuxhaven
beicuxhaven
debaki
smooth 123
