[ROM][CWM] DarkyROM2 XXKI3 Base Android 2.3.5
  • 57 Antworten
Du darfst, aber die Banane war schneller - closed.
Flashen auf eigene Gefahr!!! Weder ich noch android-hilfe.de übernehmen Verantwortung für einen möglichen Brick eures Handys!
DarkyROM2 XXKI3 Base​
woot! 2.3.5 finally here
Base ROM with new SuperCore!
Extended power
Glow
CRT-Off
Root
BLN
Talk2
SIP
...... all the usual stuff in Base ROMs
SuperCore 2.0 is build with the latest kernel sources from Samsung and has added BLN to it.
There are lots of changes across the board so we will expect your comments on performance and so on.
ROM REQUIRES WIPE!!!
(use DarkyROM2 Tool to setup WIPE before installing)
Downloads
Orginalthread
DarkyROM2 XXKG6 BASE​
You should already know what this is
Stock XXKG6 made for CWM with added tweaks and so on.
It's themed as closer as it can be to 10.2 but it does not have extended power menu or multiple lockscreens. Also some small glitches in the theme are still present (will fix those and release partial update) some things might not be themed also (phone, contacts...)
Features
  • Inclides SuperCore 1.4
  • KG6 Modem
  • ODEXED farmework
  • ODEXED Browser (no lag)
  • DEODEXED the rest
  • SU
  • BUSYBOX
  • OPENVPN
  • BASH
  • RAM Hack
Short Instructions:
  1. If you are not on one of ficeto base ROMs, flash SuperCore 1.4 (Or any version you can find) using Odin (put tar in PDA). This will get you ready to flash the new ROM.
  2. Put the BASE ROM on your internal memory.
  3. Using the DarkyROM Tool, you can select if you want wipe, no-samsung, skip kernel and skip modem. This choice is yours, but it is suggested that you DO NOT skip kernel and modem for now.
  4. After you are done with DarkyROM Tool, you can go to CWM via the option in the app (Under General tab; Reboot into recovery) or you can use the usual way; shut the phone off then reboot by pressing vol-up+home+pwr.
  5. Install the zip from SD-Card.
  6. Reboot and enjoy.
Now before you download, let me explain what all those packages that you will see are.
KG6-Base-R2.zip -> CWM Flashable Version of the full ROM (odexed fw+browser)
KG6-Base-theme.zip -> CWM Flashable Base Theme (odexed fw+browser)
KG6-Base-stock-theme.zip -> CWM Flashable Base Stock Theme (odexed fw+browser)
KG6-Base-odexer.zip -> CWM Flashable package to return you back to odexed (odexed fw+browser)
KG6-Base-deodexer.zip -> CWM Flashable package to convert you to deodexed (use if you want to flash other themes)
SuperCore_1.4.tar -> GT-I9100 Kernel
Screenshots: Imageshack
Downloads
DarkyROM2 XXKG3 BASE​
The base rom itself is an odexed rom (free of interface bugs), But I also release a conversion CWM zip with it, that you can use and switch from ODEXED to DEODEXED takes 2 minutes
There is no theme or interface hacks added to it those come in R2
Features:
  • ROOT
  • Busybox
  • Bash
  • RAM Hack
Nothing else is added to it yet (I'm sure _JKay_ will not disappoint)
Install:
  1. Make sure you are on SuperCore or CF-Root kernel
  2. Upload the base rom to internal SD
  3. Install DarkyROM2 Tool and select appropriate options
  4. from General section in app select and flash CWM zip
  5. Enjoy
Install:
  5. Enjoy
Downloadlink XXKG3 Base: DarkyROM2_XXKG3_BASE_ODEXED.zip
DarkyROM2_XXKG3_BASE_Converter.zip (192.23 MB)To go from Odexed to Deodexed
DarkyROM2 XXKG2 R2​
Features:
  • Odexed
  • Themed
  • Extended Power
  • GGB Launcher
  • Root
  • Busybox
  • _JKay_ Modified (app included)
  • RAM Tweaked (from litening3)
  • DarkyROM2 Tool Compatible (if you set "no-samsung" not installed apps will be available for install later through the app)
  • Latest SuperCore (CWM 4.0.1.4 homebuilt)
  • Latest Android Market inside
  • FAST!
Screenshots: Imageshack Credits to Darky.
DarkyROM2 Tool:
You can use this app to customize the installation, flash kernels, modems and CWM zips. Also lets you manage the installed system apps.
Skipping Samsung Apps will NOT install the following apps (Samsung Apps):
  • AccuWeatherDaemonService.apk
  • AnalogClock.apk
  • BluetoothPbap.apk
  • BluetoothTestMode.apk
  • BuddiesNow.apk
  • ChocoEUKor.apk
  • Days.apk
  • DigitalClock.apk
  • Dlna.apk
  • DualClock.apk
  • EmailWidget.apk
  • FTM.apk
  • FTS.apk
  • FactoryTest.apk
  • GameHub.apk
  • GenieWidget.apk
  • GoogleFeedback.apk
  • GooglePartnerSetup.apk
  • GoogleQuickSearchBox.apk
  • HTMLViewer.apk
  • HelvNeueLT.apk
  • Kies.apk
  • KiesAir.apk
  • Kobo.apk
  • LiveWallpapers.apk
  • Memo.apk
  • Microbesgl.apk
  • MiniDiary.apk
  • MobilePrint.apk
  • MobileTrackerEngineTwo.apk
  • MtpApplication.apk
  • MusicHub_U1.apk
  • PCWClientS.apk
  • PhotoRetouching.apk
  • PolarisOffice.apk
  • PostIt.apk
  • PressReader.apk
  • Protips.apk
  • ReadersHub.apk
  • SMTEngine.apk
  • SMTSetup.apk
  • SamsungApps.apk
  • SamsungAppsUNAService.apk
  • SamsungIM.apk
  • SamsungWidget_News.apk
  • SamsungWidget_StockClock.apk
  • SamsungWidget_WeatherClock.apk
  • SecretWallpaper1.apk
  • SecretWallpaper2.apk
  • SelfTestMode.apk
  • SevenEngine.apk
  • SnsAccountFb.apk
  • SnsAccountLi.apk
  • SnsAccountMs.apk
  • SnsAccountTw.apk
  • SnsDisclaimer.apk
  • SnsImageCache.apk
  • SnsProvider.apk
  • SocialHub.apk
  • Stk.apk
  • Term.apk
  • TrimApp.apk
  • TwCalendarAppWidget.apk
  • TwWallpaperChooser.apk
  • VideoEditor.apk
  • VoiceSearch.apk
  • VoiceToGo.apk
  • Zinio.apk
  • fotaclient.apk
  • install_flash_player.apk
  • kieswifi.apk
  • lcdtest.apk
  • signin.apk
  • syncmldm.apk
  • syncmlds.apk
  • wipereceiver.apk
Skipping Swype Keyboard will NOT install the following files:
  • /system/app/Swype.apk
  • /system/lib/libSwypeCore.so
How-To:
  1. Make sure you are running SuperCore or CF-Root and you have a working busybox and root!
  2. If not on one of those kernels, flash SuperCore through ODIN
  3. Install DarkyROM2 Tool from Market
  4. Upload the ROM ZIP to your internal SD
  5. Open DarkyROM2 Tool and select the appropriate ROM settings (section DarkyROM, recommended settings in screenshot)
  6. Select the "General" Tab and then use "Flash CWM zip" to navigate to your ROM ZIP file, tap on it and let the phone get flashed
  7. If you miss something after install, open the app and use the "Install" tab to bring back whatever you need
  8. Enjoy!
Downloadlink XXKG2: DarkyROM2_XXKG2_ODEXED_BASE_R3.zip
XDA-Delevopers Thread: [ROM][SGS2][2.3.4] DarkyROM2 XXKG6 BASE & DarkyROM2 XXKG2 Odexed R3 - xda-developers
Das DarkyROM Tool gab's in Google's Play Store
Reaktionen: Hamst0r und Android-Jeck
Spricht in der Regel nichts dagegen, nur eine kurze Info wäre nett gewesen, dann kann man die Threads verlinken und ein paar Zeilen dazu schreiben das die anderen User wissen wie und wo es weiter geht.
Wen du sagst du kümmerst dich um den Thread werde ich den anderen hier her Linken und schließen.
In Zukunft bitte bei solchen dingen eine kurze Info, machen andere auch :)
Sonst haben wir irgendwann 20 Threads zum selben RoM .
Danke
Reaktionen: androidwissen
Sorry habe ich nicht dran gedacht. Danke.
Bilder wurden hinzugefügt.
Ich glaub ich werde dann heute Abend mal mit dem Darky Rom Tool flashen. Bietet sich ja an um KG6 zu testen. Viel Erfolg mit dem Thread!
Danke. Ist echt ein Super ROM! Wenn man z.B. noch wartet bis CM7 eine final oder so veröffentlicht, ist das das beste ROM.
Vielen Dank für die Info
Meine Fragen:
Wäre es möglich das sich jemand der diese Rom drauf hat das Netswidget installiert
https://market.android.com/details?id=de.theinzelmann.networkswitch&feature=search_result
und mal schaut ob es ihm das was anzeigt. Oder ob er zuerst auf Einstellungen, Über das Telefon, Status und auf Signalstärke klicken muss, damits was anzeigt (ist bei allen Signalstärke Widgets so mit/unter Tochwiz)
Edit: Funktioniert nicht.... Habs selbst drauf getan... scheiss Tochwitz
Weis jemand ob es ein grosser Aufwand ist, ein Theme zu erstellen, welches die dBm Signalstärke, wie bei CM7 in der Statuszeile anzeigt?
Brauche Bluetooth und Signalstärken Check... tragisch
(Bin zu lange weg vom Programmieren und etwas überfordert mit dem Eclipse)
Edit: Wäre so dankbar, wenn jemand ein solche Theme erstellen könnte, oder mir helfen könnte in der Eclipse klar zu kommen
Vielen Dank
Schade, hätte gern den Batt Status in % wie beim SGS1 und die Ausschaltanimation war auch nett....
hallo
draky mit R2 oder R3 mit batterieprozentanzeige.
wenn ohne R2 oder R3 keine batterieprozentanzeige.
ich nehme R3 wäre toll bis zufrieden. seit vorgestern verlässt Canogenmod7.
mfg hotroadster1980
Bitte was? ^^ Was bedeutet R2/R3? Ich habe leider auch keine Prozentanzeige.
Edit: Okay R2/R3 sind die releases. Was muss ich jetzt flashen um die Prozentanzeige zu bekommen? Die KG6-Base-R2.zip ?
Habe mein SGS2 mit dem:
CF-Root-SGS2_XW_XEU_KE7-v4.0-CWM4
gerootet.
Kann ich jetzt einfach die:
DarkyROM2 XXKG2 ODEXED BASE R3
draufspielen und alles läuft ?
hallo
mein gerät läuft R3 draky und draufspielen!
mfg hotroadster
Habe ich dann auch wieder den batt Status in % ?
Und ändern der Bootanm auch möglich per "plug n play" ?
schade, dass einige den Antwortbutton nicht kennen und daher nur den Zitatbutton nutzen.
Man muss deshalb alles mehrfach lesen und es wird unübersichtlich...
Hab die gute Darky jetzt seit heute vormittag drauf,läuft sehr gut.
ausser stocken bei HD aufnahme,also ruckler.
vielleicht jemand das selber problem ?
gruss
Habe es auch drauf und läuft bus jetzt ganz gut.
Vermisse lediglich andere Lockereres und das “Tv“ abschalten wenn das Display ausgeht.
Kann man das nachträglich noch einbauen ?
Sorry das war mit Swype ohne drauf zu achten was es da schreibt ;-)
Lockscreens sollte das heißen.
Andere Lockscreens bekommste mit Widgetlocker. Ein muss für jedes Android Gerät. ;)
Reaktionen: Ragnar30
BananenAffe
  • Gesperrt
  • BananenAffe
3 4 5
Kjetal
Kjetal
Masta_Gee81
Masta_Gee81
Masta_Gee81
eybee1970
Popey900
Popey900
