[ROM] Check's Extreme Edition v1 XXKG6
  • 0 Antworten
Gast5050
Gast
Disclaimer :
Please read this post in totality.
Flashing your device isn't 100% secure, you are solely responsible for the risk you take.
This is not a pretentious customROM, this work just allows me to learn the basics.all code modifications have been made by me. I hope some will enjoy it
Support Chat IRC: ☜☆☞ Check's Extreme Edition ☜☆☞: Check's Extreme Edition IRC Channel
(this is a live chat line on my blog which you can use when i am online or when other people are, when you are there just check out some ad's)
About the ROM:
RC2 of the ROM has been Rolled out to Beta Testers, General Public release will be only on 1st September
I have a lot to work on, so please be patient. I seriously don't want to upload unfinished work.
Check ROM is all about releasing reliable and stable work.
So when your checked in your guaranteed a great experience!
I have made this ROM to be Rock Stable and Rocket Fast!
As of now i don't have a SGS2 as mine is coming on the 24th of this month so i am working on the ROM with my Friend's SGS2, so i am limited to the hardware that's the reason why i am Releasing on 1st September so that i can put my ROM to its paces and give you guys the best possible user experience.
Darkyy and Ficieto are the two guys who inspire me so this is dedicated to them
This is my first ROM so guys please be Gentle on me!
I will be working on this ROM closely with Darkyy and Ficieto once darkyy comes back.
I will also be releasing video teasers of my ROM on my Channel (so be Subscribed)
(Sorry for the voice in the video's guys, I had 2 Surgery done on my neck which is the reason for my voice being like it is!)
If you end up using this ROM you have been Checked-in
☜☆☞Check ROM DEV Crew☜☆☞
GadgetCheck ( CheckROM Leader )
Vertumus ( Theme Guru )
doctorcete ( Magic Maker )
buzzboy ( Tester Boy )
Feature List:
(All that are Green have been done)
  • Based on Ficeto's DarkyROM2 XXKG6 Base
    [*]Battery percentage
    [*]CRT Screen-Off Animation
    [*]Overscroll glow
    [*]Better optimised apk's, framework for more speed and free mem.
    [*]GTalk with Video
    [*]better camera
    [*]fixed laggy browser
    [*]Memory tweak
    [*]Kernel tweaks
    [*]SD card read tweak
    [*]Smaller LR logo in notification menu
    [*]New lockscreen wallpaper
    [*]Zipaligned.
    [*]Deodexed.
    [*]Root + Busybox
    [*]speedmod-t22
    [*]Added call recording
    [*]Added go launcher
    [*]Added better battery stats
    [*]Added adFree host
    [*]Removed logsprovider
    [*]No RTL support for now
    [*]BLN- Notification
    [*]Black Theme - Ported form LitePro (now porting)
    [*]Check's Boot animation
    [*]And many more that i am forgetting!
Downloads:
*Comming Soon*
Donate:
Rom's as always will be free
But if you could appreciate my work and donate to my SGS3 Fund for the future i will be great full
*Donation Link will come only after i upload my ROM.*
Credits to people over @XDA:
_JKay_, ChainFire, LitePro, muveszur, potatoman, Lary, YG007, rustamabd, theos0o, Pulser_g2, and many more to come ...
NO OverClock and No OTHER tweaks active for that 4000+ score
(TEASER)
FAQ
Definitions:
- CWM = ClockworkMod Recovery (mostly used to install new ROMs)
- SGS2 / GS2 = Samsung Galaxy SII
- lagfix = makes your Galaxy S fly!
- Firmware = Base System of our Galaxy S II (provided by Samsung)
- Circle Battery Mod = shows your battery in 1% steps
- FC = Force Close (Crash of an App / Component)
- BLN = Backlight Notifications
- more defintions to come, just ask them in the thread
Q: How this ROM is different from others ?
A: This ROM is heavily modded with a custom theme, features, apps etc and also has my personal tweaks and improvements.
Q: I'm coming from a different ROM so which version should i choose wipe or non-wipe ?
A: Choose the Wipe Version.
Q: What is the difference between wipe and non-wipe version ?
A: Wipe version will delete all your apps and settings whereas non-wipe version will not delete your app or settings.
Q: I'm getting bootloops what should i do now ?
A: Follow the steps below:
Get into the CWM recovery
Wipe Data/factory reset
Wipe Cache
Wipe Dalvik-Cache
Wipe Battery Stats
Format Internal SDCard
Install the wipe version of my ROM
Q: I'm coming from a different ROM how can i install this ROM ?
Wipe Cache
Wipe Dalvik-Cache
Wipe Battery Stats
Wipe Cache
Wipe Dalvik-Cache
Wipe Battery Stats
Install the wipe version of this ROM
Q: I'm currently on a previous version of this ROM how do i upgrade to latest version without loosing my apps and data ?
Remove Android related stuff from the internal SD Card
Get into CWM Recovery
Wipe Dalvik-Cache
Wipe Battery Stats
Install the non-wipe version of the ROM
Q: I want to make sure nothing of my previous ROM interferes with my new ROM what should i do
A: Completely wipe your internal SD Card or delete any Android related stuff from it and disable any lagfix. Then do a full wipe from ClockworkMod recovery then install the wipe version of my ROM.
Q: After Installing your ROM I'm getting bootloops/boot issues?
A: Do the following steps:
Take out the battery
Put the battery back in
Get into Recovery
Wipe Everything
Flash my ROM
Done!
Quelle:
[ROM]☜☆☞ Check's Dark Knight Edition>> MOVED TO ORIGINAL DEVELOPMENT - xda-developers
Das ganze ist zur Zeit noch im Beta Test aber bei XDA kann man sich dafür wohl anmelden.
Reaktionen: sensor99
