[ROM][30NOV][2.3.6 XWKK5] symphony 3.1.0 [JKAY][ROOT][UNTHEMED]
  • 9 Antworten
Gast5050
Gast
attachment.php
In the past, I have used ROMS from various developers (i agree her work).
Occasionally, some of these ROM's containing bugs it took to be resolved, and was a little disappointing.
Therefore, I decided to make my own ROM, designed for my daily use, including optimizations that seem more appropriate and allow for greater stability and durability.
Finally, I decided to make available to users with the ROM, if I could be of interest.
Symphony is a (practically) close to stock ROM, that includes the Samsung Galaxy S2 base rom, but with a lot of features, in order to increase the specs and battery life.
The ROM is (practically) unthemed (I like the default Samsung graphics and colors)
BASIC FEATURES
Rooted - Deodexed - Zipaligned
Siyah 2.2-i kernel [Thank's to gokhanmoral]
init.d scripts folder support
BLN Support (MMS included)
Ads removed via hosts file (hosts file from cyanogenmod)
Boot sounds disabled
AppWidgetPicker (Widgets control, for those that [like me] are not using the TouchWiz)
Cron enabled support info
CHANGELOG
3.1.0
XWKK5 rebase (Android 2.3.6 inside)
All 3.0.0 features applied
Full changelog: http://forum.xda-developers.com/show...25&postcount=2
DOWNLOAD
http://forum.xda-developers.com/show...25&postcount=3
KNOWN BUGS
3.1.0
Having issues connecting to CISCO wireless routers. Seems a XWKK5 bug, not a ROM bug. Ir you're using a CISCO router, try to use symphony-3.1.0 and, if you suffer a connection error, use symphony-3.0.0. Is Android 2.3.6 based, also.
SCREENSHOTS
attachment.php
attachment.php
attachment.php
attachment.php
* For the people obsessed with the scores: The 4388 quadrant score was reached with the gpu overclocked to 400 mhz.
THANK'S
All XDA-developers users
and specially for KixMe for our great logo
SPANISH USERS
Los usuarios españoles pueden seguir la evolución de esta
ROM en HTC Manía: htcmania.com/showthread.php?p=3056339
Changelog:
3.1.0 (Nov 30, 2011)
XWKK5 base ROM (Android 2.3.6)
3.0.0 (Nov 29, 2011)
XWKK2 base ROM (Android 2.3.6)
All 2.5.0 features applied
Quelle und Download:
[ROM][29NOV][2.3.6 KK2] symphony 3.0.0 [JKAY][ROOT][UNTHEMED] - xda-developers
Reaktionen: kiriakos1963
Habe ich noch nie was von gehört ..
@maestro
laut signatur hast dus ja schon drauf :)
Läuft sie gut ?
Hab von kk2 ja noch nie was von gehört :D
laufen tut sie gut und schnell, habe nur den Eindruck das der Akku etwas schnell geleert wird aber dazu kann ich morgen was sagen.
Akku läuft nun auch super nur musste ich den Märker updaten da die Version die dabei war,nicht ging ansonsten Top.
Sent from my GT-I9100 using Tapatalk
Symphony 3.1 ist raus !
Based on KK5 ...
Woher kriegt der die ganzen base roms ?
Nachher gleich mal testen
Von Sammobile (Samfirmware) bekommt er die :)
Reaktionen: Simuur95
läuft super wie die 3.0
findest du sie besser als Criskelo v32 , finde da nämlich die Icons nich so gut, gefallen mir bei der symphony besser ;) geht jetzt auch der Market ?
Das ROM ist halt sehr nah am Stock ROM, suche aber noch nach nem schicken Style. MAg das Criskelo nciht wegen der großen Icons und weil es bei mir noch nie wirklich rund lief.
vivalasven
husvun1875
Simuur95
Masta_Gee81
Masta_Gee81
beicuxhaven
beicuxhaven
