beicuxhaven
Ehrenmitglied
- 10.437
Biftor™ Rom V14 NOWIPE
[FONT=&]based:XWMS1[/FONT]
[FONT=&]Modem: XXMS4[/FONT]
[FONT=&]CSC:[/FONT]
[FONT=&]Kernel: Jeboo 2.3a+
[/FONT]
[FONT=&]CSC:[/FONT]
[/FONT]
Removed many apps&widgets if you want that flash removed app patch from optional section(LSN Version is not avalable now)
4 Way Reboot
Enabled All Languages For Samsung Keyboard
Added scheduled messages option
Added Save messages option
Added Draft messages
Added correcttime of messages
Added Aokp Navigation Bar Style
Remove sens style task manager from Default
Added Biftor Wallpapers
Move Any App to Data(samsung weathers app, memo app, Google Talk,Google search, and another app you if you will do wipe data after flash my rom this apps will remove if you want give all of them back you must open my zip file and exteract data/app folder after that install which apps you want same normall app)
TW task manager Biftor(No shortcut af this app sammy TW task manager Exactly)
Added Beanbang Systemui App
Enable Portable Wi-Fi Hotspot Icon
Enable tethering And Portable Hotspot Icon
Enable Hidden settings Widgets
Enable Smart Network toggle
Fix Multi Windows resize
Fixed Brightness Slider Toggle
Added Dropdown,Dropdown header and statusbar wallpaper you can set any wallpaper you want for this you need to Read this post http://forum.xda-developers.com/show...postcount=4512
Added no alert for battery low in camera(Aroma V6)
Added Flash under 15% battery in camera(Aroma V6)
Aokp Battery Bar added with Full customizable
Added Ability For switch between 23 Toggle status bar and stock one
Added Ability For Change Number Of Toggle In View in Land Scape and Portrait For 23 Toggle Statusbar And Stock Toggle Statusbar 23 Toggle From 1-15 And stock From 1-10(but if you select "1" ypur toggle will be hide)
Added Ability For Change Statusbar signal location left or Right
Added Ability For add date to statusbar and added 2 style for that 29 June 2013 or 29/06/13
Added Ability For Change location Of date in Statusbar Left/Right Or Center
Added Ability For Change Color of date in Statusbar
Added Ability For Change Color of All Things about Statusbar
Added Ability For Change Color of All Things about Statusbar Drop Down
Added Ability For Change Color of All Things about Your Phone Text And BG And Icons all of Them is Toggle able for Enable or Disable(Disable=Sammy Stock Colors)
Added Ability For Change Color of All Button of Dialer
Added Ability For Change Dialer BG Transparnet 0%-100%
Added Ability For Add your wallpaper For Dialer BG for this you need to Read this post http://forum.xda-developers.com/show...postcount=4512
Added Ability For Add your wallpaper For Contact BG for for this you need to Read this post http://forum.xda-developers.com/show...postcount=4512
Added Ability For Add your wallpaper For Call Log BG for this you need to Read this post http://forum.xda-developers.com/show...postcount=4512
Added Ability For Add your wallpaper For Navigation Bar BG for this you need to Read this post http://forum.xda-developers.com/show...postcount=4512
added Ability For Change Color and Transparncy of all Wallpepers You have For(Statusbar,Dropdown Header,Notification Panel,Dialer,Contact,Call Log,Drop Down Drag Bar)Toggle able for on or Off
Added All Color Piker Ability From other lock Screen To Xperia Z Lock Screen Same OTher Lock Screen
Added Ability For Show or Hide "Hint" Text on Xperia Z Lock Screen
Added Ability For add Screen Shot Button In Power Menu
Added Ability For Show or Hide All Power Menu Items(Option)You Can Make Your Power Menu
Fix All Problems Of Xperia Z Lock Screen
Added Ability For Change Color of Main Settings Text and Icons From Biftor Rom Control/Color Control/Phone Theme/Phone preference Titel,Summery and Icon Color
Added Multi dpi dialer
Added Multi dpi tw launcher(you can't put dpi under 182 for tw launcher)
All other Things From V7,V8,V8.2,V9,V11, V12 Added to V14 And updated for XWMS1
and Here is Quick Change log Of Biftor™ rom V14:
I spent too many time for v14 and aroma mod v6 more than all other versions!
I had re write too many things from zero!
I learned many new things!
I hope you will Love this version!
Color piker or transparency for:
Custom drop down Text BG and text
back BTN on apps headers you can make that to any colors or transparency you want
recent app panel
recent app panel bottom 3 BTN
recent app panel text
recent app panel wallpaper toggle able for enable or disable
signal text and db image
quick panel toggles background 4.2 Ui Only
each quick panel toggles background 4.2 Ui Only
Phone Toast text toggle able for enable or disable
Phone Toast text BG color toggle able for enable or disable
All elements Of 4.2Ui(For Ex:toggls BG,sliders bg,sliders text,image,toggles and...)
Changed All Toggles Color for stock and Toggle mods
Fixed Toggles Inductors Color
Fixed Power Menu Inductors Color
S4 Lock Screen and Stock Old Sammy lock screen
Drop down header
Drop down close drag handle bg
Drop down close drag handle wallpaper for this you need to Read this post http://forum.xda-developers.com/show...postcount=4512
Drop down close drag handle texts
Drop down notification on going title bg and text
Drop down header shortcut BTN(setting/home/power/recent) and divider lines
Statusbar Internet speed
Stock toggle bg
Statusbar ticker text
Navigation bar bg
Navigation bar btn
Replace search btn to power btn in navigation bar
Ripple clock " : "
Phone progress Bar toggle Able
Phone Check Box toggle Able
phone Button BG (OK,No,yes....Button BG) toggle Able
Phone Over Scroll Color
Power Menu Text
Power menu icons (all Icons)
Power Menu BG
Change all Colrs Disable By def
Change All Def Colors
HTC Lock SCreen
Honey Lock Screen Logo
Honelock Screen wave logo
Dialer BG
Dialer BG Button
Dialer Search BG
Dialer Text
Dialer All BTN And Top Bar Image!
And More...
Toggle for Show or hide:
toggle for show or hide header clear BTN
brightness slider to quick panel windows*Toggle able
all volume sliders one by one and remove all by one click!
Drop down header btn (settings/power/home/recent/dividers)
Drop down notification and ongoing and no notification
Drop down Header Clock And Date
Drop Down notification items and ongoing items
Toggle Image/Text/Indc
And More...
Added:
Added Skip song delay buttons for skip tracks fixed and added time piker value to hold volume buttons for skip tracks.
Ability for customization Navigation bar BTN portrait and landscape no need to restart systemui
Ability for customization space between navigation BTN
Ability for change navigation menu BTN
Ability for Change Signal icon to stock JB or Black Dimond
Ability for put 2 wallpaper for each(statusbar, drop down and...) BG one for portrait and one other for land scap
Ability for add signal strength db text and db image and you can set that left/Right or Hide
Ability for hide db imag
Ability for hide signal icon only
Ability for change Custom text size
Ability for change battery icon location left or Right no need to restart systemui
Ability for change statusbar panels which windows show to default quick panel windows or default windows working perfectly
Ability for change Stock toggle bg to Black Dimond BG
Ability for Change Close drag handel BG to Black Dimond BG
re made 4.2 UI,now thats same as Aosp 4.2 UI I hope you will love it.
Added 3 new theme for statusbar
Added 4.2 UIs With swipe for change drop down panels(quick panel toggles mod or notifications..)
Added swipe to left on drop down header for remove all headers text and BTNS and swipe to right all of them will come back
Added 2g/3g/auto toggle to quick panel and toggle mod statusbar thanks to @_Sale_
Added Custom carrier label for lock screen*
Added Custom phone header label
Added Custom phone apps headers label
Added custom Ongoing, Notifications and No Notification text
Added Custom Text to drop down toggle able for show or hide you can write your important daily not In your Drop Down
Added Custom Text Title Toggle able for show or hide you can write your text for replace with default Title
Added " % " symbol to battery text
Added text size piker for 99% of Status bar and drop down text you can change all of them to your size you want just from my Rom control/text control and all of them will change immediately
wallpaper piker for recent app panel*
Added 4.2 status Quick panel no need to flash anythings from cwm for 4.2 Ui just select from my Rom control yes this is my work
Added 3 New Statusbar Theme Statusbar 4.2 , Statusbar 4.2+stock Toggls and Statusbar 4.2+Toggls Mod
Added sliders panel To 4.2Ui DropDown
Added around of 40 toggles and shortcuts to toggles mod and 4.2 quick lunch panel
Added apps shortcuts yes apps Shortcuts with controlers for order or show or hide to your quick panel or your Toggles mod
toggle for switch between Stock Style Recent App and Senc Style
toggle for Always Show menu key on Naviagtion Bar
Added Ability To Change Biftor Rom Control,Color Control and app Restarter Theme To Holo,Holo Light,Holo Dark and stock
Added Internet speed in statusbar you can replace that to inout logo,toggle able
Added toggle for Show or hide wifi or data inout logo and internet speed too
Added date on Drop Down close drag handle you cam set location to left/Right/center or hide that
Added clock on Drop Down close drag handle you cam set location to left/Right/center or hide that
Added internet speed on Drop Down close drag handle you cam set location to left/Right/center or hide that
Added wallpaper piker for Drop Down close drag handle you can set your logo for this you need to Read this post http://forum.xda-developers.com/show...postcount=4512
Added HTC Lock Screen
Added Honey Lock Screen
Added about9-10 Honey Lock Screen logo Thanks To Masoud @ PDA-Planet For Logos
Added Out Side Ring Honey Lock Screen Logo(you can Change it to Stock/remove/heart 1/heart) Thanks To Masoud @ PDA-Planet For Logos
Added Slide Tab Lock Screen
Added S4 Flare Lock Screen
Added Quick Unlock Pin
Added 4 new battery icons you have more than 24 model statusbar battery icon
Removed navigation bar control app
Because we don't need it I added toggle for enable or disabled navigation bar just need hotboot
And More...
4 Way Reboot
recent app panel
Drop down header
Stock toggle bg
Navigation bar bg
Navigation bar btn
Ripple clock " : "
Power Menu Text
Power Menu BG
HTC Lock SCreen
Dialer BG
Dialer BG Button
Dialer Search BG
Dialer Text
And More...
And More...
Added:
And More...
Biftor Rom v14 download link :
Biftor™ Rom-V14-JB-XWMS1-No Wipe.zip - 454.21 MB
Biftor Aroma mod v6 download link :
{ Der Aroma dienst dazu, eine bestehende LSD/LSE etc. ein wenig auf Biftor Aussehen und Features, zu pimpen }Biftor™ Aroma-Mod-V6-JB-LS8-LSD-LSE-LSN-LSS-LSW-LSZ-MS1.zip - 309.42 MB
Link zur Seite
Link zur Seite
1. Wer Probleme hat und die Recent Apps nicht auswählen kann, also lange HOME gedrückt halten und dann eine bereits geöffnete App auswählen, der sollte mal in Biftor ROM control unter
Status bar setting
general show or hide
Haken machen bei recent app panel und dann System UI neu starten
2. Zum Aroma Installer: Ja, der macht leichte Probleme weil { Der Aroma dienst dazu, eine bestehende LSD/LSE etc. ein wenig auf Biftor Aussehen und Features, zu pimpen }. Nach der Installation ist kein Neustart möglich. Einfach ein wenig warten und dann die POWER Taste länger drücken (ca. 8Sek.)
3. V12 Es kann passieren, dass beim Spielen kein Anruf möglich ist. Zur Behebung: Biftor™RomV12&AromaV5_Games&Call_Forwarding_Fix.zi p - 4.49 MB
4. DPI App habe ich noch nicht zum laufen gebracht. Also einfach über RootExplorer in der BUILDPROP ändern
5. Speichern und Wiederherstellen der Biftor Einstellungen ( Farben etc. )
Backup der beiden Apps mit Titanium Backup: Biftor Rom control / Biftor color control
und der beiden ROM-Settings siehe Bilder
6. Achtung für Biftor Rom v14 and Aroma v6:
Diesen Patch über die V14 flashen oder vom aroma mod "Biftor Rom Mod+xxxx theme"
Biftor™Rom_V14&AromaV6_Color_Control_Fix.zip - 306.66 KB oder diese APK Biftor_Colorcontrol.apk - 191.13 KB mit einem root browser nach system/app danach hotboot
Erklärung siehe hier:
http://forum.xda-developers.com/show...php?p=46942634
7. Biftors SETTING APP siehe hier
8. Added Ability For Add your wallpaper For Dialer BG for this you need to Read this post http://forum.xda-developers.com/show...postcount=4512
8. Probleme mit Umstellung der Systemsprache auf Englisch?
https://www.android-hilfe.de/forum/...orjb-rom-v14.340147-page-23.html#post-6747065 und weitere post darunter
Status bar setting
Biftor Rom Aosp themes v3 (withe, blue, full transparnts )
Biftor™_Aosp_Theme_V3.0.zip - 47.86 MB
Biftor™_Full_Teransparnt_Aosp_Theme_V3.0.zip - 17.58 MB
Biftor™_White_Aosp_Theme_V3.0.zip - 47.70 MB
Biftor™_Full_Teransparnt_White_Aosp_Theme_V3.0.zip - 17.57 MB
für Screens siehe hier
for restore all deleted app XWMS1 flash this: Biftor™ rom V14-JB- XWMS1-RemovedApps.zip - 179.16 MB from cwm
for maps XWMS1flash this: Biftor™ rom Maps.zip - 4.56 MB from cwm
for SecEmai,SecExchange XWMS1flash this: Biftor™ rom Email&Exchange.zip - 13.91 MB from cwm
for transparent weather widget install this app
for no transparent weather widget install this app
for Biftor wallpapers install this app
for stock multi windows-no bug(NO transpernt) flash this from cwm
for signedmultiwindow edit app install this app this app is from legendk thanks
legendk95
if you want USB mass storage by defult flash this from CWM.
if you want MTP by defult flash this from CWM.
legendk95
[FONT="]
[/FONT][FONT="]* BACK UP, BACK UP, BACK UP[/FONT]
[FONT="] * Copy Biftor™ Rom auf ext. SD[/FONT]
[FONT="]* Recovery mode (turn off your device and hold volume up + home + power)[/FONT]
[FONT="]* Wipe data factory reset & wipe cache
*Format SYSTEM
*FORMAT EMMC
[/FONT] [FONT="]* Advance: wipe dalvik cache and battery status[/FONT]
[FONT="]* Install zip from sd card Biftor™ Rom[/FONT] auswählen
*Format SYSTEM
*FORMAT EMMC
alle BIFTOR Arbeiten hier
FullWipe und Wipe Script
Änderungen und/oder Anregungen gerne per PN an mich, DANKE!
