[JellyBean] *22.04.13* [4.1.2][LSN] Turkbey V4.1 S4 Edition FINAL
  • 263 Antworten
Pseudofreak
Stamm-User
519
[Sammy-ROM][JellyBean] *22.04.13* [4.1.2 LSN] Turkbey V4.1 S4 Edition
Danke an das gesamte Turkbey Team
-Turkbey
-Agabey
-Moonlight
-CQNSTANT!NE
-Yasayan27
-Pendroz
-Axxo
Download Links
v4.1 S4 Edition
XDA Thread
Originalthread (Google Translate)
Features
Modem: XXMS2
CSC: OXXLS8 Multi
Kernel: XWLSN-4.92.3-PhilZ
Fully Deodexed
Zipaligned
Rooted
BusyBox
SuperSU
EFS auto backup
NO WIPE
Disabled boot sounds
Increase Contacts adding for the message (1000 contacts instead of 10 contacts)
No Auto Converting messages to MMS
Disabled Home Button Lag
Enabled Camera Sound Menu
MultiWindow (Enabled all Apps) Thanks to master_droid
Transparant Status Bar
Ripple Lockscreen
No Call Ring Delay
Enabled All Languages For Samsung Keyboard
Faster GPS Lock
Enabled Sensor Aiding For Fast GPS Lock
Enabled More Contacts (999)
Disabled Scrolling Cache
Large Apn List
Removed Bloatware
Init.d Support
More Init.d Tweaks
Build.prop Tweaks
Black Status Bar
Ripple Lockscreen
New Arabic Font Thanks to handasoft
More Init.d Tweaks
More Build.prop Tweaks
Enabled Usb Mass Storage
Fixed USB Unmount Wakelock Thanks to master_droid
Media Scanner Fix Thanks to shoman94
S4 Wallpapers
S4 Theme
S4 Keyboard
S4 Launcher
S4 Auido
S4 weather Widget eklendi
S4 Calculater eklendi
S4 Samsung App
S4 File Explorer
S4 Memo
S4 Voice Talk
S4 Statüs bar
TürkbeyTeam Wallpaper
SecWallpaperChooser
Contact Fix
Music Player Fix
New statusbar
New Framework-res
and many more...
TurkbeyTeam Rom V3.0
Modem: XXLS8
Kernel: XXMS1-OXA-4.53-PhilZ
Fully Deodexed
EFS auto backup
Ripple Lockscreen
No Call Ring Delay
4 Way Reboot
Faster GPS Lock
Large Apn List
Removed Bloatware
Init.d Support
More Init.d Tweaks
Build.prop Tweaks
New statusbar add
New Settings add
New Lg Launcher Add
and many more...
TurkbeyTeam Rom V2.1
keinen Changelog gefunden
wrs. wurden nur paar unnötige Apps entfernt
TurkbeyTeam Rom V1.4
Added-AOSP Camera
Ram usage and battery tweaks applied for
Added-AOSP Gallery
Fixed the issue Posts
5 Was added to the lock screen shortcut
And the reported bugs have been fixed (Equlizer error, I need to start rum ...)
TurkbeyTeam Rom V1.3
TurkbeyTeam Rom V1.2
New Android.policy
New TurkbeyTeam Settings
New systemui
New Lidroid-res
Torch Add Lockscreen and statusbar
New Dpi 200
New Statusbar %25 Transparant
New Aosp Phone
New Aosp Contacts
New Aosp Browser
New Quick Sms
Dorimanx Kernel (Thanks Dorimanx)
New Keyboard
And New.....
TurkbeyTeam Rom V1.1
New SecSettings
New Android.policy (Turkbey Policy)
New SecPhone Aosp
New SecContact Aosp
New SecMms (Quick Sms) Aosp
New Browser Aosp
New Dpi 200*
And....
Installation / Step by Step / Full Wipe Empfohlen !
-Zip/Rom herunterladen und auf ext/int. SD Karte kopieren
-Kernel Cleaning Script herunterladen und auf ext/int. SD Karte kopieren
-CWM Starten (Handy ausschalten, Vol Up & Home & Power)
-Kernel Cleaning Script flashen (zip Datei)
-Recovery neu starten (unter Advanced)
-Optional: bei bereits installierten Philz/Jeboo Kernel: unter Philz Settings / Clean Before Flash New Rom durchführen
-Wipe data
-Wipe cache
-Advanced / Wipe dalvik cache
-Mounts and Storage / Format system
-Optional: Mounts and Storage / Format emmc (interne SD Karte wird gelöscht !!!)
-Zip/Rom installieren (hier selbst ist ein Installation ohne Wipe empfohlen)
-Rebooten, sollte länger als 5 min der Samsung Bootschleife nicht enden, Akku raus, in CWM gehen und erneut Cache und Dalvik Cache löschen.
-Beim booten selbst kommt ein Adroidmännchen, dann hat man es nach wenigen Minuten geschafft, die Rom startet, Grundeinrichtung/Startassistent durchführen
-Erneut Rebooten, erst dann eigene Apps installieren
-Vorsicht bei Wiederherstellung von Systemapps über Titanium Backup oder ähnlichen Backup Programme (CWM Backup zuvor erstellen)
-APK Batch Installer, wenn APK Dateien zur Installation vorhanden sind (Anleitung)
-Fertig :thumbup:
Reaktionen: TomCat966, roflloler, Don_Pedro und 13 andere
RainboxRom Thread[End of Live]
-New Systemui
-New Framework-res
-New Secsettings and Settings icons (small)
-New Lidroid-res (flashlight No bug)
-Walkman add
-Siyah Kernel add
-Multiwindow (No bug)
-SuperSU Fix
-Allshare add
-CRT OFF add (Thanks Mirko ddd)
-4 Away restart
-2 Lock screen (Aosp lockscreen) (Note2 Lockscreen)
-Skip sound
-Kernel: Siyah Kernel b3
-Modem XXLS6
-CSC: XXLS1
-20 toogle buttons
-Call Recorder
-Phone with no increasing ringtone
-Faster GPS lock
-Battery % mod
-Home Button Lag fix
-Added Ripple on settings
-Multi Windows
-On/Off button For Multiwindow in settings
-Smart stay enabled on settings
-4 shortcuts to lock screen
-No MMS/SMS Log In Call LOG
-Note II POPUP Browser
-Camera Mod v8
-Accuweather Widget transparent
-and....
- New SystemUi
- Aosp Keybord + IME
- JB lockscreen + original (Thanks MirkoDDD)
- Full integrated NFC support ( only for i9100P )
- New Secsettings
- New setupwizard(thanks neme77)
- New Accuweather (transparan thanks Bezke)
- New Battery icon
- New Framework-res
- New RainSony Theme
- Add Acid Soundmod
- Add Acid tweaks
- Add Sony Bravia Tweaks
- Add Dolby mobile Tweaks
- Add Email
- Fixed Usb mode
- Removed Xperia Launcher
- New icons
- And....
-New Lidroid-res
-New Secphone theme
-New Systemui
-Statusbar torch fix
-Nova launcher removed
-Sony Launcher add
-Battery tweaks
-Speed tweaks
-New Build.pro tweaks
-and....
CHANGELOG v8
CHANGELOG v7
-Neue framework-res
-Neue twframework-res
-Neue Status-Bar (Rainbox status bar)
-Build Pro wurde optimiert
-System-ui erneuert
-System wurde optimiert
-4.2 Gallerie und Kamera hinzugefügt
-the application has benn remove Big issue
-und vieles mehr
CHANGELOG v6
-Aroma installer (No. Wipe und Wipe Full support (Thanks nguyenxuanhoa))
-4.1.2 XXLSJ basiert auf VK JellyBean
-PhilZ-XXLSJ-OXX-3.5 kernel
-Deodexed, rooted, zipaligned
-Rom wurde vollständig optimiert
-Alle unnötigen Samsungs apps entfernt
-Tweak für schnelle GPS satelliten Verbindung
-Android 4.2 Kamera
-Unbegrenzte SMS Liste
-MMS und SMS in einem
-Automatische SMS Encoding
-Große Stock Statusbar
-Tweaks für Speed und längere Akkulaufzeit
-Feinabstimmung für Touch Sensitivität
-Scroll cache geschlossen
-Samsung Apps wegen unnötiger Akkubelastung gelöscht
-Ansteigende Klingellautstärke
-Call Recording möglich
-S3 Lockscreen mit Ripple Effekt
-Home Button Lag behoben
-Build.prob Datei wurde optimiert
-MultiWindow Funktion hinzugefügt (TRANSPARENT) Anpassung & Abschaltung möglich
-Statusbar überarbeitet (Thanks nguyenxuanhoa)
-three-way lock screen
-Turn on and off the status bar added to the Smart stay and MultiWindow
-Aroma Installer wurde optimiert
-4-way set rotation
-Note 2 AND JB Galerie ist dabei
-Framework wurde optimiert
-SecSettings and Systemui files optimiert
-S Planner bugfrei
-4 Shortcuts auf Sperrbildschirm
-4 Way Reboot
-Songs (Lautstärketaste) im Sperrbildschirm überspringen
-Multi Window abschaltbar & Bearbeitung möglich
-Zwei Launcher vorinstalliert (Startbildschirm & Touchwiz)
-Und .......
Rainbox Rom Rom´s & Mods - Wuala Dev Mirror
Auf Anfrage kann ich die älteren Roms hochladen
1- Full Transparant (thanks nguyenxuanhoa) CWM İnstall
Dev-Host - Rainbox Rom V5 Full Transparan.zip - The Ultimate Free File Hosting / File Sharing Service
Hiermit werden SMS & Telefon & Kontakte durchsichtig
2- Who do not like icons in the icon for the original install from CWM.
Dev-Host - Rainbox paket.zip - The Ultimate Free File Hosting / File Sharing Service
Hiermit werden die Original Icons für Apps und unter Einstellungen wiederhergestellt
3-Motorola and time both as a normal install apk. open smoothly
Dev-Host - Rainbox Motorola Launcher ve saat.rar - The Ultimate Free File Hosting / File Sharing Service
Ist ein alternativer Launcher als *.rar Datei, wird mit ROM bereits mitinstalliert
4 - CWM install video search button on the keypad!
Dev-Host - Phone.zip - The Ultimate Free File Hosting / File Sharing Service
Tastatur und Kontakte werden geändert
5- CWM install the battery% from the status bar in stock! (Pendroz)
Dev-Host - Blue Circle by pendroz.zip - The Ultimate Free File Hosting / File Sharing Service
Ändert Batterieicon und Empfangssymbole, der Lockscreen und Homebutton werden gelöscht.
Zudem wird die Uhr nach rechts verschoben
6-Transparente Statusbar mit blauen Icons
xda-developers - View Single Post - [ROM] Turkbey Team V1 ROM [Turkbey Team Settings][TurkbeyTheme][Aroma]
Reaktionen: roflloler
Moin.
V6 online
Rainbox V6
Der ursprüngliche Beitrag von 14:14 Uhr wurde um 14:59 Uhr ergänzt:
Rainbox V6
• XXLSJ 4.1.2 Neat lite JellyBean üzerine kurulu
• JB Font
• Transparan Status Bar (Vk toogle thanks)
• 13 Toggles in Status Bar
• Multiwindow - Fully Worked - %50 Transparan
• Toggle for Multiwindow in Settings
• Toggle for Multiwindow in Status Bar
• Smart Stay
• Toggle for Smart Stay In Status Bar
• Increase Contacts adding for the message (1000 contacts instead of 10 contacts)
• No Auto Converting messages to MMS
• Disabled Home Button Lag
• Enabled Camera Sound Menu
• No Call Ring Delay
• 4 Way Reboot
• 4 Icons On Lockscreen
• Enabled All Languages For Samsung Keyboard
• Faster GPS Lock
• Enabled Sensor Aiding For Fast GPS Lock
• Enabled Media Widgets
• Skip Song
• Ripple Lockscreen
• Toggle For Ripple Lockscreen In Settings
• Enabled More Contacts (990)
• Enabled Scrolling Cache
• Flash Player
• Large Apn List
• Removed Bloatware (49 Apps)
• Init.d Support
• Init.d Tweaks
• Build.prop Tweaks
• Updated YouTube to v4.1.47
• Updated Google Maps to v6.14.1
• Updated Google Search to v2.1.12
• Updated Google+ to v3.2.2
• Updated Google Play Store v3.10.9...
• New System İcons
• New App İcons
• S3 gallery add
• New task maneger
• Optimize edildi
• Stock Launcher (4.2 launcher ) add
• Transparan Weather widget
• Aroma İnstaller kaldırıldı.
• and many more...
Reaktionen: Pseudofreak, Blackman1945 und micas350
Thread-Titel aktualisiert...Rest ist TE-Sache...
ich lade jetzt seid 2 stunden. verdammt ist das langsam...
Lade auch schon 2 h naja wen ich nacher Zeit hab lade ich es mal nach meinem dropbox hoch
Leider ist die Rom (v5 und v6) nicht gerade stabil.....
gestern als ich ein Anruf bekommen habe (v5) ist irgendeine App abgestürzt, nur noch schwarzer Bildschrim, abheben war so nicht möglich. Ging glücklicherweise dann übers BT Headset (war grad im Auto)
Bei der V6 stürzt die Galerie ab, wenn man versucht über den Homescreen das hintergrundbild zu wechseln. Geht man manuell in Galerie, sucht ein Bild und ordnet es dann als Hintergundbild zu, geht´s
schade, das Design der Rom ist schon recht schick, aber laufen / Alltagstauglich sollte es schon sein.
Stimme zu.da müssen noch Verbesserungen gemacht werden
Hallo!
Kann mir bitte mal jemand verraten,wie ich dieses Double-Klick-Feature loswerde?Also meim Problem zB beim GoLaucher ist,daß wenn ich eine App geöffnet habe und ich einmal den HomeButton betätige,ich gleich im Screeneditor lande(statt auf dem Homescreen),was ja eigentlich zwei klicks entspricht.
Rainbox V7
• New StatusBar
• The new notification screen, the icons on your page and so on.
• New text font, Sony
• The new system icons
• New Systemui
• New Secsetting
• Toggle Pin 15 added (Thanks Neme77)
• New Framework-res
• system has been optimized
• Build-pro and has been optimized meta-inf
• Apex Launcher add
• Note 2 Gallery add (free bug)
• and more ....
Rainbox V7.zip - Wuala
Reaktionen: flatulenzius, Blackman1945 und beicuxhaven
Hallo Zusammen,
habe jetzt mal die V7 geflasht!
Muss sagen sieht richtig schön aus.
Habe auf der XDA Seite in den Screen Shots diese Uhr im Anhang gesehen!
Wo bekommt man die?
Hallo
Die Uhr ist bei den Widgests zu finden. Nach dem reinholen kann man diese Konfigurieren
Reaktionen: osmotoletto
das design ist schick, aber wie schaut es mit den funktionen aus ???
hast du schon Probleme gehabt (Galerie, telefon etc...)
Ich habe es gestern Abend durch die Wanam 13.0 ersetzt, war nicht so toll ausser vom aussehen.
Ich habe mal den Titel auf v.7 aktualisiert.
Falls das Datum nicht stimmt, bitte selbst ändern TE. Solltest du nicht wissen wie, erkläre ich dir gern per PN. :D
Topas
Ach! Ich probier schon den ganzen tag downloaden. Aber immer wieder: fehler beim öffnen der datei!
Kann denn jemand bitte n mirror erstellen? Währe sehr dankbar dafür!
Habe aufm xda post n mirror gefunden, scheinbar funktionsfähig: falls jemand interesse hat, und wenns erlaubt ist:
https://rapidshare.com/#!download|108p2|1791711708|Rainbox V7.zip|541029|0|0
Hat denn jemand bitte n mirror für die V5 oder V6 version? Das thema gefällt mir viel besser als V7. Danke.
Genau!
Nach einem Tag nutzen, keinerlei Probleme :)
