Pr0TuRk38
Dauer-User
- 1.551
- Themenstarter
- #101
Es ist wieder soweit:
MIUI ROM 3.11.22 Full Changelog
Phone
Fix - Some of the dial pad keys would display in the wrong place (11-20)
Fix - When dialing different country codes, some were recognized as emergency calls (11-20)
Fix - On Hongmi devices, when dialing an emergency number, the dual-SIM option didn't work properly (11-20)
System
Optimization - System supports changing system fonts (11-22)
Optimization - Increased scanning and connection speed for some hidden SSID routers (11-22)
Fix - Problem with extra sounds on lock screen (11-22)
Fix - Keyboard sounds where out of sync when user typed fast (11-22)
Fix - Sometimes system would FC (11-22)
Fix - Antutu and other apps show the incorrect amount of battery charge (11-22)
Themes
New - Gift codes now supported in the MIUI Theme Store (11-19)
Optimization - Scroll up effect added to comments list (11-20)
Fix - When applying a theme, some of the app icons would not change to the new theme (11-19)
Fix - When a theme had an update, it would open the local theme details page and the changelog wouldn't display (11-19)
Fix - When previewing a theme, when user reached the last page, the image would jump around (11-19)
Lock screen, Status Bar, Notification Shade
New - Don't show screenshot captured in notification option added (11-21)
New - After you delete the last notification in the notification shade, shade will hide automatically (11-21)
Optimization - Status bar displayed when charging and when battery is low (11-21)
Optimization - Xiaomi recommendation notifications now display app names (11-21)
Fix - When there was no SIM card inserted, user couldn't open data usage settings (11-21)
Fix - When an analytic notifications failed, notification shade would FC (11-21)
ContactsOptimization - Accelerated the speed at which calls from unknown numbers are checked (11-19)
Optimization - When you receive texts from your service provider about having a low balance, system will remind you to top up (11-22)
Fix - Removed confirmation for package delivery record check (11-19)
Music
Fix - Sometimes entering the Music app from the Notification shade or from the control panel on the Home screen would cause FC (11-18)
Fix - Sometimes after downloading a song, the download icon would't turn gray (11-18)
Downloads
New - New settings button added (11-22)
Optimization - New Downloads icon style in status bar (11-22)
Fix - Sometimes Downloads app would FC (11-22)
Fix - In edit mode, when user left and came back to Downloads after selecting items, the number of items selected would be incorrect (11-22)
Video
New - Playback on LAN DLNA devices supported (11-20)
Fix - Sometimes the Video details page would FC (11-19)
Fix - Sometimes the Search page would FC (11-19)
Fix - Sometimes after the main page was finished buffering, "Can't load page" would still be displayed (11-19)
Fix - Sometimes viewer history wasn't saved (11-19)
Phone
System
Themes
Music
Downloads
Video
Wow
