[JellyBean] *11.07.13* [4.1.2][LSW] Omega v24 - ONLINE
  • 1.119 Antworten
Also ich habe das Wanamlite drauf (das 3 JB ROM) mittlerweile. Es liegt am JB leute , an nix anderem.
WanamLite ist bis jetzt das Ruhigste! aber sobald Datenverarbeitung besteht saugt er halt!
Wahrscheinlich hockt der NSA, CIA drauf.
Omega v24 online!
Based on XWLSW Android 4.1.2 (Date: 16/05/2013)
New:
Kernel PhilZ 5.07.0
Modem XXMS2
Omega Files app now can be removed
Updated:
AdFree
Play Store
Samsung IAP
Samsung Push Service
Samsung Apps
Dropbox
CPU Adjuster
Flipboard
Gmail
Google Search
Google+
Hide it Pro
Google Maps
SuperSU
ZArchiver
ChatON
Es File Explorer
Hangout
Talkback
Theme:
Omega Theme for aroma installer by our artist anbech
Floating Omegadroids credits to NadMaj - Preview
Removed:
Disable advertisements - you can disable advertisements with AdFree app included in Omega
Download all Files app
All mods and updates from previous Omega JB 4.1.2 versions added
Rom is Deodexed + Rooted + Zipaligned
Rom is No Full Wipe
New version Omega v24:
New:
Kernel PhilZ 5.07.0
Modem XXMS2
Updated:
AdFree
Play Store
Samsung IAP
Samsung Apps
Dropbox
CPU Adjuster
Flipboard
Gmail
Google Search
Google+
Hide it Pro
Google Maps
SuperSU
ZArchiver
ChatON
Es File Explorer
Hangout
Talkback
Theme:
Removed:
Rom is No Full Wipe
Omega Files:
Omega Files Pro:
Direct Links for Omega v24 added to Omega Files Pro
Update repo to Omega Files Pro to get the updates for v24
Please read the following before flashing v24:
1. Make sure to make and keep in a safe place an efs backup, in case you need to restore it.
2. When v24 installation finishes Aroma installer will return to recovery, from recovery wipe cache partition before you restart your device else it will bootloop.
3. Rom is No Full wipe rom, but Full wipe is strongly recommended if you have issues!
4. Please update Omega Files from Play Store.
5. If you want to flash theme or kernel, please make sure first they are compatible with this Omega version.
6. Omega Files Free and Pro will be updated soon with more goodies.
Donation:
If you like and you use Omega v24 and Omega Files app, please consider a donation.
Enjoy the new Jelly Bean Omega
Reaktionen: simonwest und mystery007
Trotz wipe cache partition in recovery,wie in der Anleitung geschrieben ,kein Erfolg.Bleibt im Bootloop hängen :blushing:
Hau dir gleich danach nen anderen Kernel (bei mir siyah) drauf dann sollte es klappen.
Mach einen FullWipe oder nutz das NukeScript. Dann klappt es bestimmt.
Der ursprüngliche Beitrag von 13:22 Uhr wurde um 13:23 Uhr ergänzt:
Oder erst PhilZ und dann dort im Recovery Clean bevore install new rom oder so ähnlich.. unter Wipe Data/Factoryreset
Nuke 2.10 script mehrmals ausgeführt und neuen Dori 8.34 ,immer Bootloop.Jetzt hab ich die CriskeloRom 2.1 drauf :thumbup: Sehr zum empfehlen:thumbsup:
bei meinem S2 genau dasselbe ...
Top Rom! Ist sehr eneriesparend, weil man das Handy nicht nutzen kann!
Der ursprüngliche Beitrag von 15:57 Uhr wurde um 16:02 Uhr ergänzt:
Tipp: führt auf eurem Handy ein kompletten wipe und Format aus (preload usw) und installiert keine Rom! Hat den selben Effekt und ihr müsst nichts downloaden
Nach der Installation, falls Bootlloop, nochmals Wipe Cache und Dalvik.
Dann klappt's auch...
Eigentlich macht man nach der Installation eh einen Wipe Cache und Dalvik.
Also wie ist es denn? Läuft die ROM bei allen mit Wipe Cache und Dalvik.
Backup gemacht, Rom installiert (ohne full wipe), in der recovery wipe cache und dalvik cache gemacht... Läuft!
Reaktionen: beicuxhaven
Der ist gut!!
Sehr gut, aber leider auch total unnötig. Aber gut. Also, bitte postet, wenn es Probleme gibt mit der ROM u der Installation. Ggf muss man das im Post 1 mit auf nehmen.
Reaktionen: spartacus_origin
Neuer Versuch mit Erfolg :thumbup: Allerdings andere vorgehensweise,beim Installer NoWipe ausgewählt und ebenso die Standardversion.Danach wipe cache und unter advanced wipe dalvik .Läuft bin grad am testen :biggrin:
Hatt einer von euch auch gps probleme mit dieser Rom?
nein keine, fix in 5 Sekunden über GPS Status!
hmm komisch.
Hab mir getzt faster gps runtergeldaen und den Ntp Server auf Europe/Germany gestell.
Jetzt gehts auch bei mir paar Sekunden
Hallo zusammen ..
Was mach ich denn wenn ich folgendes Telefon habe : (Bild im Anhang)
Und dann noch mit Orginaler Samsung Firmware aber bereits mit Dem letzen Siyah Kernel : ( Die version wurde per edit von der build.prob verändert )
Ich denk mal das ich lieber nicht flashen sollte oder ?
MFG
Hallo noch mal ...
Ich bin ja jetzt seit ein paar Tagen auf die Omega Rom umgestiegen, aber das läuft wie ein schluck Wasser in der kurve.. Muss manchmal 5 , 6 ,7 und mehr Neustarts hintereinander machen weil die Touch Wiz, und Email app einfach alle 10 sekunden einfrieren.. Das was dann noch funzt ist der Screenlock und danach ist schicht im schacht und ich muss den akku rausholen..
Und wenn es dann mal läuft und ich zb Need for Speed Most Wanted spielen will, hab ich nur noch einen Samsung Dia Projektor mit Touch GUI ^^
Selbst beim Antutu Benchmark, wo ich vorher ca 10000 Punkte hatte, komm ich nun mehr nicht mal auf 8000 Punkte.
Da ich jetzt aber nicht weiss woran das lieg würde
ich jetzt ja gerne nur den Kernel wechseln, und hier nun die Frage des Tages :
Kann ich von dem in der OMEGA v24 Rom mit PhilZ Kernel auf den SiyahKernel S2-v6.0beta5 den ich schon unter der STOCK ROM Hatte Flashen ?? Ich hab mal irgenwo was gelesen das in der Omega v24 nur der Intrigierte Kernel läuft.
( Hoffe das Pic ist nicht zu groß )
Danke..
